Date/Time: Wed, 28 Oct 2026 06:00:09 +0000
user defined fields with orders
View Count: 1457
[2015-10-21 19:43:14]
onnb - Posts: 666
hi - I have a string that I need to assign to an order and later identify that order with the same string - like a user defined field so to speak. I need to set and get via acsil. Is this possible?
[2015-10-21 20:39:46]
We do not currently support this, but it could be added.
How important is this?
[2015-10-21 20:52:52]
onnb - Posts: 666
Currently using files as a workaround (storing orderid's/user data pairs).
So on a scale of 1-5, importance is 2-3 (medium).
Have a much bigger project that is starting which requires this type of thing and that would make the priority higher. This type of field is useful to have in general I am sure you understand why.
That said, do have a workaround so its not a show stopper at all for now.
[2015-10-23 04:08:49]
OK we will see about this. But we cannot promise when this would be done.
[2015-10-23 09:57:05]
Refer to the ACSIL Trading documentation for:
s_SCTradeOrder::TextTag
That will be in the next release.
[2015-10-30 21:30:35]
T29_Dev1 - Posts: 22
I set TextTag field in s_SCNewOrder when I submit a new order, but GetOrderByIndex returns an empty string in TextTag for this order.
Also I can see my text in "Orders and Positions" window in "LastOrderActionSource" column and "Text Tag" column is empty.
Version: 1317
[2015-10-30 21:49:18]
We have now fixed this. We will have a new release out before Monday.
[2015-11-06 21:14:59]
It's still not working with v1321.
[2015-11-07 01:21:53]
We see the problem. This will be fixed in the next release.
