Date/Time: Wed, 28 Oct 2026 19:08:31 +0000
Sierra DOM Scaling no good solution for me
View Count: 4091
[2016-03-11 20:51:09]
OK good.
[2016-03-11 22:42:57]
Japhro - Posts: 120
The other issue has been that the recenter trading doms menu item does not recenter the doms. This may be something you guys want to look at as well, a lot of this issue could have been minimised if that had worked
[2016-03-11 22:56:43]
The re-centering does occur, but as we demonstrated during remote assistance, if you have used Interactive Scale Move to change the center of the scale then it may not appear to center.
In the next version, the changes to the scale from Interactive Scale Move will be reset as well.
[2016-03-12 19:38:47]
Japhro - Posts: 120
I've tried every permutation of every setting that I can find and none allow recentering of all DOMs, but perhaps I am missing something
[2016-03-12 23:36:40]
Wait for the next release coming out Monday. This will do what you want.
[2016-03-14 14:31:52]
Japhro - Posts: 120
Huge improvement with recentering of all DOMs now with one command, thanks for that. The other DOM recentering/scaling functionality I do not understand yet, I suppose we'll have to wait for documentation but it appears there is no way that they can have a free range of movement then recenter on a user-definable # of ticks from center?
[2016-03-14 16:33:31]
We are still working on the new Constant Range centering capabilities. This is still under development.
[2016-03-22 02:03:13]
Japhro - Posts: 120
I see that you have implemented this in version 1385. Many thanks for this, it looks quite good off the bat but I need to see it in a moving market. thanks again - J
[2016-03-22 02:38:21]
Let us know if you need any more help.
[2016-03-22 13:53:28]
Japhro - Posts: 120
It works fantastic, just what the doctor ordered
[2016-03-22 17:22:16]
This is good to know.
