Date/Time: Wed, 28 Oct 2026 02:25:55 +0000
lmax demo unable to connect
View Count: 1196
| [2015-09-23 18:50:25] |
| sierra28 - Posts: 120 |
hello, i have open a demo account with lmax and try to connect sierra with lmaxdemodatafeed. unfortunately it doesn't works and i don't know why see configuration and message log thanks for your help. |
| [2015-09-23 19:10:40] |
The problem is your computer's clock is not set accurately. Refer to help topic 38: Http://www.sierrachart.com/index.php?page=doc/helpdetails38.html But you need to use your own direct account: Direct Sierra Chart Account We have activated your Sierra Chart account that you are using on this Support Board, for a week for testing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-23 19:15:04
| [2015-09-23 19:15:21] |
The prior post has been corrected.
