Date/Time: Sun, 04 Oct 2026 17:39:29 +0000
Session Vertical Line
View Count: 4599
| [2015-09-23 13:07:17] |
| bwalks123 - Posts: 122 |
I am trying to figure out how to set my chart up so that the vertical line that represents the each new session/day plots on a particular time different than 00:00:00. I am in AZ mountain time zone. I would like the session time (vertical line) to start at 14:45:00 instead of the 00:00:00, I tried changing the session time in chart settings to start at 14:45:00 and end at 14:00:00 but that didnt work. How do I go about doing this? Any help would be great. Thanks |
| [2015-09-23 17:56:47] |
In the Vertical Grid settings in Chart >> Chart Settings make sure you are using Start of Trading Day. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#VerticalGridLinesAtEvery Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-23 17:57:05
| [2020-03-27 10:22:41] |
| Fabio - Posts: 153 |
Where can I change the shape/color of this vertical line if it can be done? Thanks, Fabio |
| [2020-03-27 11:15:51] |
| Ackin - Posts: 1865 |
Fabio) try this: Graphics Settings: Chart Grid |
| [2020-03-27 13:17:38] |
Found it. Thanks mate
