Date/Time: Mon, 29 Apr 2024 08:04:45 +0000
[User Discussion] - hourly opening range
View Count: 5166
[2017-10-01 11:52:21] |
User541842 - Posts: 34 |
thanks for your efforts tomgilb, but its not working. no plot on the chart Date Time Of Last Edit: 2017-10-01 11:52:36
[2017-10-01 13:11:51] |
got it working. had to open a new chartbook AND it somehow does not want to plot the first range of the day. but thats fine, thanks tomgilb |
[2017-10-01 14:56:27] |
TechTrader - Posts: 116 |
Ensure the Spreadsheet Study 'Settings and Inputs' > 'Number of Rows' is set large enough.
[2017-10-02 01:51:47] |
Sawtooth - Posts: 3982 |
In hindsight, this can be done without a spreadsheet study, using only multiple instances of the High/Low For Time Period - Extended study. You would use an instance for each time segment. -Set the 'Start Time' and 'End Time' to the opening range duration of each segment. e.g. With 5 min bars: 09:30:00 09:34:59 -Set 'Use Line Stop Time' to Yes. -Set 'Line Stop Time' to the end time of the segment. e.g. With 30 min segments: 09:59:59 -Set the Draw Styles of SG1 and SG2 to Fill Top and Fill Bottom, respectively. -Repeat for subsequent segments, adjusting the times accordingly. |
