Date/Time: Thu, 17 Sep 2026 04:44:28 +0000
SC DOM vs TradeStation DOM (Matrix)
View Count: 4482
| [2013-06-14 04:26:58] |
Yes. Please see this section here: https://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#ChartDOMPositionPLColumn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-06-15 04:02:43] |
More precisely describe the issue you see with Profit and Loss values. It is not clear. You can provide an image, by following the instructions here: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Also, please refer to this page here: http://www.sierrachart.com/index.php?l=doc/helpdetails77.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-06-15 13:28:26] |
| Carl71 - Posts: 125 |
The background addition of the P&L based on a positive or negative variation should be very interesting IMHO
Date Time Of Last Edit: 2013-06-15 13:29:01
