Date/Time: Wed, 28 Oct 2026 02:25:21 +0000
Crosshair - Always active when selected - Gone
View Count: 1812
[2015-08-29 12:53:34]
Hieronymus - Posts: 51
Hi, in the newest pre-realese the Chart Values menu has changed the option from 'always active when selected' to 'always on when chart values tool selected'. This may be slightly hard to explain, but when the hand tool is on and after single use tool switch to hand is on, and then always active when selected is on for the crosshair, all I have to do is click on the chart and the crosshair turns on, one more click and it's off. That was a nice feature and it seems to be broken now, please correct me if there is another way to do this.
[2015-08-31 19:32:15]
We are checking on this.
[2015-09-08 00:20:27]
I still can't figure out how to do this, basically the hand tool is always on and crosshair is on/off every left mouse click.
Date Time Of Last Edit: 2015-09-08 11:20:57
[2015-09-08 05:26:47]
The Chart Values tool when used with other tools was not designed to work this way.
However, we have not had time to look into this to see how best to do this.
While working on this functionality, obviously something has changed.
[2015-09-08 11:18:41]
Seems like an easy fix would be the option to have the hand tool always on when using crosshair.
I have to upgrade for the enhanced pitchfork and lose this or stay with the old version. Damn customers can never be pleased.
[2015-09-24 05:23:40]
Update to prerelease version 1299.
This now should work as we think you expect when you have Global Settings >> Tool Settings >> Chart Values >> Always Enabled When Using Other Tools selected from the drop-down list box.
