Date/Time: Sun, 29 Nov 2026 12:19:36 +0000
ACSIL - Currency Value Format question
View Count: 1960
| [2015-08-21 20:58:43] |
| ejtrader - Posts: 689 |
SC Team - What is the equivalent function to display the number of decimals for currency? Looking for something similar to graph values - sc.BaseGraphValueFormat - but for currencies. For example - USD - would have 2 decimal values ( not sure whether it is true for all currencies or not ). Noticed this enum value and not sure whether it is the correct one or not - VALUEFORMAT_CURRENCY - There are no associated functions for this. thanks |
| [2015-08-22 23:29:13] |
This is not an easy question. But for most currencies of the world, two decimal places is sufficient and that is what Sierra Chart uses.
| [2019-03-13 03:36:30] |
| enemyspy - Posts: 307 |
Hmm I have the same question, Is there a function that gives how many decimal places the ticksize is. For instance ticksize on the eur/usd is several decimal places.
| [2019-03-13 04:04:49] |
nvm got it.
