Date/Time: Fri, 26 Apr 2024 10:05:46 +0000
Number bars
View Count: 1730
[2013-06-12 18:39:42] |
Select Help >> About in Sierra Chart. What is the Current Service Package? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-12 21:56:29] |
Restart Sierra Chart and also ask your broker about this if you are not on package 5.
[2022-06-15 08:07:49] |
User712596 - Posts: 2 |
Hi, I can't see number bars while loading btcbusd. By oil it works but btc is invsible. Is anything connected with the chart settings and data limiting? Tick size is 1, days to load 7. any other ideas can influence my issue? thank you. |
[2022-06-15 18:34:03] |
John - SC Support - Posts: 31131 |
In general, you should not have nothing. But the crypto data tends to be very dense, and as such you should use a Volume at Price Multiplier and set it to a value around 100 to start. Refer to the information here: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) What is the exact symbol you are using? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
