Date/Time: Tue, 07 May 2024 07:44:28 +0000
[User Discussion] - Who can code this Indi for Sierras ?
View Count: 9352
[2018-05-03 13:46:01] |
User964132 - Posts: 93 |
Dear Mkata, I am using your TMA indy a lot, and although it repaints, it is very useful to point out a possible area of overboard-oversold. Is it possible to update the indicator with a second ATR multiplier, in the same indicator? So you have two top-band lines, two bottom-band lines and one middle band line.(see attachment) Again, THANKS A LOT! Nicolaas |
Oil TMA bands.PNG / V - Attached On 2018-05-03 13:44:25 UTC - Size: 197.2 KB - 911 views |
[2018-05-03 18:47:55] |
mkata - Posts: 103 |
Wow, blast from the past. I have literally never looked at this in years. I didn't like this back then and honestly still don't. However adding a couple bands is no problem, so here you go. |
TMABands.dll - Attached On 2018-05-03 18:46:31 UTC - Size: 808 KB - 531 views |
[2018-05-03 19:27:12] |
Hi Mkata! whoo you are fast!! THANKS a thousand times, Christmas came very early this year :-) I really enjoy working with this indy, it just gives you a "heads up" for an area where a turn is expected. This in combination with the Block moving average (StepUp) indicator : Converting MT4 indicator StepUp for Sierra charts is really a winning team. Again Thanks a lot! You made my day! Nicolaas |
TMA with double bands.PNG / V - Attached On 2018-05-03 19:26:11 UTC - Size: 186.05 KB - 1069 views |
[2018-06-13 14:06:38] |
Hi Mkata, Since I upgraded to the 64 bit version of SC, could you make the cpp file, or a 64 bit version from the TMABands.dll available? THANKS a lot! Regards, Nicolaas |
[2018-06-14 18:53:13] |
Here it is.
TMABands_64.dll - Attached On 2018-06-14 18:52:28 UTC - Size: 836.5 KB - 500 views |
[2018-06-14 20:10:08] |
Dear Mkata, Thanks!! Wishing you all the best! Keep smiling, |
[2018-09-27 09:42:43] |
heart1010 - Posts: 8 |
@mkata Thank you for this! If you have some free minutes can you please make another version of your TMABands_64 which uses a slightly different logic to build the bands (from the "popular TMA+CG mladen" variant of the TMA for mt4, see source code here https://glot.io/snippets/f56tw0ahrx ). I think only the wuBuffer/wdBuffer part which is added/subbed to the buffers is different from the one you've already built (iMA instead of iATR). Thanks! |
[2020-11-02 10:03:58] |
Dear Mkata, Could you compile your latest version for the latest Sierra Chart (Version 2182 64-bit) The last version you shared does not work anymore, since the last revisions from SC :-( Thanks a lot! Regards, Nicolaas |
[2020-11-02 17:32:40] |
Here you go. I didn't change anything just recompiled.
TMABands_64.dll - Attached On 2020-11-02 17:29:07 UTC - Size: 896.5 KB - 410 views |
[2020-11-02 18:32:25] |
THANKS Mkata, that is just what I wanted! A big THANKS!
[2020-11-05 10:21:23] |
Hi MKata, When I put your new Dll in the data folder, it does not show up in my "Custom Study" list, can I ask for which version did you compile this dll? I have version 2182 64-bit for Sierra Chart. I tried several things now, since I thought the problem might be on my side, but so far no luck. Rgs, Nicolaas Date Time Of Last Edit: 2020-11-05 10:22:34
[2020-11-05 15:02:53] |
Before I recompiled I downloaded the latest version which was v.2191. However the dll says version v.2188. I'm surprised by the trouble. I literally changed nothing and it is working fine on my end. |
[2020-11-05 18:11:54] |
Just updated to version 2191, and now it works as a charm, sorry for the confusion! AGAIN THANKS A LOT! Keep smiling! Nicolaas
Date Time Of Last Edit: 2020-11-05 18:16:48
[2020-11-07 07:03:12] |
User90125 - Posts: 715 |
@mkata, great work on updating this indicator. Is there a working source code (.cpp) that you can share to the community? Thanks. |
[2021-02-21 01:22:18] |
jeden8l - Posts: 46 |
Hi @mkata. Any chance you could share a .cpp file to recompile file on our own? Would be great, .dll is out of date as for this moment. |
