Date/Time: Tue, 27 Oct 2026 21:13:39 +0000
Data feed connection problem
View Count: 1397
| [2015-08-06 23:47:57] |
| User26445 - Posts: 6 |
Will not connect to data feed provided by AMP Message Log sent using send for analysis button on message log screen Thanks Dave |
| [2015-08-07 04:28:04] |
Your Message Log indicates that you tried to connect to Rithmic and TT. With Rithmic you got the following error: Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" For possible solutions refer to step 17 here: Rithmic Trading Platform Service: Setup Instructions With TT, you got the following error: TT FIX Data: Received a Logout message. Text = Unable to login to FIX Adapter AMPNON1ORPR: TTUserSetup Error - DGIBSON is not authorized to use FIX Adapter. Please contact your TT User Setup Administrator. You will need to contact AMP, and inquire which trading platform service your account is set up for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
