Date/Time: Tue, 27 Oct 2026 21:13:39 +0000
New spreadsheets question
View Count: 1202
[2015-08-04 16:41:12]
bekitz3 - Posts: 83
Is there a function within the new spreadsheets that can look at each number within a range and compare it to a single value?
Example: All #'s within a range are less than the compared value
Range A3:A13 -- all of the values in this range are less than A14.
[2015-08-04 17:44:49]
All of the available functions are documented here:
Spreadsheet Functions
What should also the result be. Although it does not sound as though this function exists.
