Date/Time: Tue, 27 Oct 2026 21:13:41 +0000
Compact Tool Values Window
View Count: 1503
[2015-07-30 23:45:41]
normal guy - Posts: 16
"Save CTV Window Position for Each Chart" does not work after 1276.1 to recent update.
I also checked "Use Horizontal Compact Tool Values Window Layout".
CTV opens where it opened at last position.
Thanks.
[2015-07-31 01:14:10]
This does work but we do see some problems with it that we are solving now.
Also if the Compact Tool Values Window is not visible select Chart >> Reset Child Windows.
When you enable that setting, it is necessary to change the focus to a different chart window to cause it to go into effect.
[2015-08-01 22:08:58]
Updated 1280,
The horizontal CTV window still appears on the last chart where it was highlighted.
It works fine if I un-checked "Auto Hide Charts Title Bar And Scrollbar".
Thanks.
[2015-08-01 22:24:54]
OK we do see this. We are not going to commit development time to this. At least not now. This will be reviewed later on.
This is just one of those scenarios that is very difficult to resolve and is a consequence of using "Auto Hide Charts Title Bar And Scrollbar". Using "Auto Hide Charts Title Bar And Scrollbar" can and does lead to an unusual behavior.
Date Time Of Last Edit: 2015-08-01 22:35:31
[2015-08-01 23:18:34]
This might actually be a simple solution. We are testing this now.
[2015-08-02 02:36:26]
We think we may have this solved. Update to the latest prerelease again with Help >> Download Prerelease (New Spreadsheets).
Hopefully it is solved.
Date Time Of Last Edit: 2015-08-02 02:36:37
[2015-08-02 03:43:09]
Updated,
It works with "Auto Hide Charts Title Bar And Scrollbar" or without it.
Thank you for the quick fix.
