Date/Time: Tue, 27 Oct 2026 20:28:53 +0000
Dialog box
View Count: 1505
| [2015-07-30 11:53:11] |
| User742670 - Posts: 43 |
Hello Support team, Can you please navigate me how can I disable the dialog box showing all the info like volume price,whenever I draw line or use a point tool? Please see screenshot Thanks David |
| [2015-07-30 12:53:40] |
| JayShea - Posts: 93 |
With the chart showing, press F5. Click on the second from left option "Advanced Settings". Click on the box that says "Settings". Not any of the 4-options at the top left. This will let you limit the items shown in the Dialog Box. Otherwise unclick the 2nd line down that starts "Display Main Price . . . " Cheers JD |
| [2015-07-30 17:18:49] |
This is best explained in this help topic: Hiding Study and Main Price Graph Names and Values from the Values Windows and Region Data Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
