Date/Time: Sat, 12 Sep 2026 11:29:32 +0000
Adding range bar button to Toolbar 1
View Count: 1181
| [2015-07-25 22:45:40] |
| User133711 - Posts: 9 |
In Toolbar 1 I see the 1m, 5m 1hr etc buttons. I know how to add line buttons to the toolbar (Global Settings/customize toolbar/Toolbar 1 but can someone tell me how to add a 4range bar button to Toolbar 1? Thanks. |
| [2015-07-26 00:18:09] |
You can add custom buttons for bar time frames. This is documented in this section here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-07-26 00:53:24] |
That did it - thanks.
