Date/Time: Tue, 27 Oct 2026 20:30:36 +0000
Incorrect CL historical data
View Count: 1159
| [2015-07-24 08:58:51] |
| User240686 - Posts: 86 |
I am on rithmic feed and also have Ninjatrader. NT is showing a low on 18 March 2015 of 47.03 Sierra is showing low of 49.69...totally way off. confirmed with users of Tradestation as well |
| [2015-07-24 09:12:55] |
Is this a Continuous Futures Contract chart? If so, are you using the back adjustment option? To confirm the data is good, re-download the data following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading There must be some problem with incomplete data or you should be using the back adjustment feature or not. It is one or both of these. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-24 09:13:20
| [2015-07-24 09:38:01] |
i dont know if its continuous. CLU15 on rithmic. Historical data reload does not change anything |
| [2015-07-24 09:47:32] |
If I change continuous contract to Volume based rollover I lose data between 17th Feb 2015 and 18th May 2015
| [2015-07-24 10:00:40] |
In response to post #4, refer to the instructions here to re-download the data: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading And be sure to carefully follow through the instructions documented. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-24 10:01:24
