Date/Time: Tue, 27 Oct 2026 20:29:32 +0000
Compact tool values window V1276
View Count: 1302
[2015-07-23 14:13:48]
ertrader - Posts: 698
The compact tool does not stay where I put it in V1276. If I simply go from one chart to the next and back to the first, it has moved.
I do have save tool values position for each chart. I also have it set to horizontal.
Can you please take a look?
[2015-07-23 14:17:19]
Initially place
http://www.sierrachart.com/image.php?l=1437660993544.png
Go to another chart and back
http://www.sierrachart.com/image.php?l=1437661032833.png
[2015-07-23 17:37:32]
We will solve this.
[2015-07-23 17:45:07]
tobi - Posts: 351
In version 1276, is it possible to have the Compact Tool Values Window visible all the time, yet?
[2015-07-23 17:46:09]
No.
[2015-07-24 11:44:42]
Letting you know this has been solved what is described in the first post. Update again to the latest prerelease. The version is the same.
