Date/Time: Tue, 27 Oct 2026 19:37:57 +0000
SierraChart CTS demo supporting
View Count: 1182
[2015-07-20 18:53:36]
User270987 - Posts: 9
Hello! can i ask, after CTS all weekend problem, SierraChart can't connect to CTS demo account
CTS letter: (10 mins ago)
"Please contact sierra for any issues with their software.
Your sim account is enabled for Sierra Chart you will need to contact them to get set up for their software."
What happening?
Thank you very much!
[2015-07-20 19:02:45]
Update Sierra Chart to the latest release following the instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
After the update you will now be able to connect.
Date Time Of Last Edit: 2015-07-20 19:03:04
[2015-07-20 19:08:44]
Thank you for reply!
I need a Current Version: 1269 (Jun 10, 2015) or Pre-release: 1274 (Jul 21, 2015)?
[2015-07-20 19:13:06]
Either one. We recommend the Current Version 1269.
[2015-07-20 20:12:56]
Wow! Really worked with latest version! Thank you very much.
I think CTS made some changes after weekends, and older version of Sierra not working more.
[2015-07-20 20:14:59]
Yes. Apparently they removed support for older SSL/TLS versions.
[2015-07-20 20:19:48]
Wow! And when it was (if i can ask)???
[2015-07-20 20:21:50]
Well apparently this happened over the weekend with CTS where they removed support for older SSL versions.
Sierra Chart began about a year ago to support a new SSL/TLS version for CTS.
Date Time Of Last Edit: 2015-07-20 20:25:46
[2015-07-20 20:24:09]
Thank you very much! i c now!!!
