Date/Time: Tue, 27 Oct 2026 19:38:01 +0000
[User Discussion] - Trial Demo not working
View Count: 1103
| [2015-07-20 18:26:09] |
| User929392 - Posts: 11 |
Please help. When I choose any of various selections from the Trade Window configuration drop-down list, then the same orders (an OCO that I did NOT select) always get attached to my parent entry order. This attached OCO is one that I have deleted from the file, yet it still attaches to all my orders as if be default, rendering the SC trading interface UNUSABLE for me, as bracketing is important to my trading. I've read the instructions in the Using Attached Orders and Attached Order Settings section of the user guide documentation many times and I hope I'm following the instruction correctly. Thank you. |
| [2015-07-20 19:31:25] |
This is the result of using a Trade Window which is not associated with the particular Chart/Trade DOM you are using. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#SettingsNotApplying Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
