Date/Time: Tue, 27 Oct 2026 19:37:56 +0000
Question about Sierra Exchange Data Feed
View Count: 1151
[2015-07-20 17:36:08]
User911705 - Posts: 89
Hello, I think I understand this correctly, but want to verify something so as not to mess up my live trading.
Here is the scenario: 1st instance of Sierra (and I assume that means also it has to be the first one started if I restart my computer)is connected to Interactive Brokers but also is using the Sierra Real Time Exchange data feed. It is running a live automated system.
Now, I start a second instance of Sierra (to do backtesting using the Sierra historical data and/or to do something like using the IB paper acct to test the IB Gateway). Can I safely assume that starting this second instance will in no way effect the first instance (where the system is running)?
Thank you.
[2015-07-20 19:27:08]
Yes. Make sure Global Settings >>Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds is disabled in this particular instance.
Date Time Of Last Edit: 2015-07-20 19:27:16
[2015-07-20 21:34:49]
This is where I'm just a little bit confused. If I disable the Support for Sierra Chart Data Feeds, won't that also disable the Sierra historical?
[2015-07-20 22:32:05]
No. Only if you are connected to Interactive Brokers. From Interactive Brokers documentation:
Enable Allow Support for Sierra Chart Data Feeds to use Sierra Chart Historical Data for major futures contracts and US stock symbols. Sierra Chart Service Package 3 or higher is required for this.
