Date/Time: Tue, 27 Oct 2026 19:37:56 +0000
New Control Bar to replace ToolBar and Status Bar
View Count: 1109
[2015-07-20 16:25:52]
jimnovak - Posts: 42
first, thank you. this was much needed.
i am sure you are aware that pre release version 1273 displays a disabled new toolbar and doesnt work. i understand this might take a while before you release a production version. can just just confirm this or am i doing something wrong?
just wanted to point out that you are going the right direction with this new development and i have already started amending icons and using my own tailor made icons. i have however noticed that not all icons are picked up from graphics/buttons folder, in particular all the ones that have texts instead of icons.(ie exit, reset, end of chart, RR and so on). also anytime i update to a new version, my amended icons get overwritten by standard ones which is a bit of a pain. have to copy them again manually. is it possible NOT to overwrite that folder or allow the application to point to at a particular path for picking up icons?
[2015-07-20 18:10:57]
We were not aware of this until this morning. This was caused by a bug in version 1273. It is now fixed. We are going to be releasing 1274 in about 15 to 20 minutes.
The ability to customize control bar icon buttons, is not formally developed yet. But it should be over the next month.
