Date/Time: Tue, 27 Oct 2026 19:38:00 +0000
SC Short-cut
View Count: 1164
[2015-07-20 16:03:19]
User78442 - Posts: 260
Hi, I upgraded my version from 1233 to 1269 but every time I try to reload from the short-cut it loads ver. 1233. This has never happened before. I don't want to save the new version in a different folder as it will not then be able to access the stored configs. Any ideas?
[2015-07-20 16:46:12]
Sierra Chart - Max - Posts: 5984
It seems that you have installed the newer version of Sierra Chart in the wrong folder.
Once you startup Sierra Chart, just go through the Update process by selecting Help >> Download Current Version.
Sierra Chart Support
[2015-07-20 16:50:25]
No, I did the above and when prompted I saved in the same folder.
[2015-07-20 18:09:16]
Follow the instructions here to update:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
If there is a problem updating refer to this help topic:
Unable to Install the Newest Version of the Software
Let us know if you still have a problem.
