Date/Time: Tue, 27 Oct 2026 19:37:53 +0000
Chart Linking->Trade Window CheckBox
View Count: 1084
| [2015-07-20 11:37:32] |
| User386687 - Posts: 53 |
If I check it and the do Apply & OK and then if I open the window again (F5) the checkbox if cleared. I cannot set it permanently. Other options such Symbol and Scroll Position works ok. I also tried to find more information about this option in help but did not find any. So what is the meaning of this option? |
| [2015-07-20 17:57:21] |
This is still under development. It is not complete.
