Date/Time: Tue, 27 Oct 2026 19:37:55 +0000
ASCIL to draw a least-squares moving average
View Count: 1871
| [2015-07-20 08:01:04] |
| User431614 - Posts: 4 |
I have been trying to find the right incantations to draw a Least Squares moving average with ASCIL, but it seems to be escaping me. At first I thought I would be able to access it through sc.MovingAverage(), but that doesn't seem to be the case (it isn't listed as a MovAvgType, below): http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#MovAvgType How can I access the least squares function from ASCIL? |
| [2015-07-20 08:28:01] |
The documentation has now been updated. This is the moving average type you need to use: MOVAVGTYPE_LINEARREGRESSION Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
