Date/Time: Fri, 30 Oct 2026 12:55:15 +0000
Import global settings?
View Count: 1210
| [2015-07-18 10:02:30] |
| User60518 - Posts: 106 |
Hi, If I install a second instance of Sierra Charts on my PC is it possible to import the global settings (like my preferences for tools etc.) into the second copy? I currently have AT Charts and need to install another copy so I can use the Sierra DOM (Blocked in InfinityAT Charts) Thanks |
| [2015-07-18 10:12:33] |
Yes this can be done. Refer to help topic 15: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
