Date/Time: Fri, 30 Oct 2026 12:55:14 +0000
Rollback
View Count: 1142
| [2015-07-18 03:50:24] |
| User78442 - Posts: 260 |
Is it possible to rollback to a specific SC version?
| [2015-07-18 05:35:23] |
Yes. Select Help >> Install Previous Version for instructions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
