Date/Time: Fri, 30 Oct 2026 12:54:00 +0000
How to show bar's OHLC and volume data
View Count: 3387
[2015-07-16 22:09:30]
User513952 - Posts: 85
1. When the mouse cross was put on a price bar, how to show its Open/High/Low/Close and Volume data(and other related information)?
2. I overlapped two MACDs with two sets of different parameters, but for some intra-day or EOD period, the short-time based MACD can not been shown on the chart.
3. How can I apply all chart settings (including Main settings and advanced settings 1/2 and Horizonta/Vertical grid settings) to a newly opened chart (when I use FS button)?
[2015-07-17 03:37:28]
1. Refer to the documentation for this here:
Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools
2. What happens if you set it to display in and Different Chart Region?
3. This is documented here:
File Menu: Find Symbol (File)
[2015-07-17 05:31:29]
2. It is normal if the 2 MACDs are in different chart region.
[2015-07-17 05:43:47]
With the studies in the same Chart Region, post an image of the chart when it does not look correct so we can have a better understanding of this.
[2015-07-17 12:26:40]
Chart1 is ADBE's daily chart with 2 sets of MACDs.
Chart2 is its weekly chart with the same sets of MACDs.
Chart3: 5-minute chart.
Chart4: 10-minute chart.
Chart1: http://www.sierrachart.com/image.php?l=1437135671551.png
Chart2: http://www.sierrachart.com/image.php?l=1437135800746.png
Chart3: http://www.sierrachart.com/image.php?l=1437135868997.png
Chart4: http://www.sierrachart.com/image.php?l=1437135919576.png
In above charts, all have the same MACD settings.
Please advise.
[2015-07-17 20:22:56]
There must be something about the chart data and the long exponential moving average length which is the cause of the problem.
What happens if you change the MACD Moving Average Length from 999 to 100. Does it solve the problem?
Date Time Of Last Edit: 2015-07-17 20:23:22
