Date/Time: Tue, 17 Nov 2026 18:41:02 +0000
NFLX Stock Split
View Count: 2202
| [2015-07-16 21:27:39] |
| LadyTrader - Posts: 19 |
How do I adjust for the stock split on the Hourly charts and below? I got the info on how to adjust the data, but when I put in a 7:1 and the first date of July 14 and the second date of July 15 - the charts come up with the correct price but the candlesticks are all in one line as the price drops from 720.00 to 116.00 |
| [2015-07-16 23:57:59] |
Part of this data comes from our own server and we have adjusted the data for NFLX. The easiest thing to do is to go to the chart and select Edit >> Delete All Data and Download. This only needs to be done once per symbol. This should correct the data. Also when manually adjusting for a stock split, the starting Date-Time would be the very first Date-Time in the data file itself and should not be adjusted for a stock split. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
