Date/Time: Fri, 30 Oct 2026 12:09:30 +0000
OEC FIX Currency Value per Tick
View Count: 1524
[2015-07-16 16:45:01]
User230181 - Posts: 9
When I update Symbol Settings using Update From Server I don't get currency value per tick specification for some futures markets. Not all of them. Do I have to manually set each symbol to correct value or can OEC fix it?
Date Time Of Last Edit: 2015-07-16 16:45:42
[2015-07-16 17:04:42]
We have to set these. Please let us know what symbols you are using where this is not set. This way we can get those ones done first.
Date Time Of Last Edit: 2015-07-16 17:04:49
[2015-07-16 17:21:17]
50% of symbols do not have this set correctly. All zeros and there are many to list here.
Examples ZT, YI, FGBS, FGBX, FTSEurofirst 100 EF100, 6N, 6S, HE, micro FX and many others ...
Also how can I have Currency Value per Tick set with futures time spread strategies like "HE FTS +5Q,-V5". Do I have to create symbols for them too?
[2015-07-16 18:04:50]
It is not likely we are going to set Currency Value per Tick for all of them because many of those contracts that do not have this setting, are not commonly traded. We will set it for the contracts you have mentioned here.
For futures market spreads, you need to manually set the Currency Value per Tick in Chart >> Chart Settings >> Advanced Settings 2.
You can also set up a Symbol pattern for this in the Global Symbol Settings:
Date Time Of Last Edit: 2015-07-16 19:58:48
[2015-07-16 19:58:11]
We have set the Currency Value per Tick for the mentioned symbols. Update the Symbol Settings as explained here:
Global Symbol Settings: Update Symbol Settings
