Date/Time: Tue, 27 Oct 2026 19:37:54 +0000
SC transfer
View Count: 1199
| [2015-07-15 19:46:45] |
| Dennis B. - Posts: 303 |
Is there a link for setting up SC (3 instances) on a new computer. Can I keep all my current settings, charts etc. thanks.... |
| [2015-07-15 22:35:54] |
Yes. Refer to help topic 15: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-07-17 12:53:03] |
You have to be kidding, all this to install SC and transfer current settings. Probably easier to just start from scratch.
| [2015-07-17 17:33:24] |
When you go through the steps, you will actually see the process is very straightforward and easy. The page is detailed for reason. It is to include all the information that you might need for all possible cases and to explain in detail many of the relevant files. So it is important not to jump to a fast conclusion and take a few minutes to go over it. We are certain, you will see it is a very simple process. Far easier and trouble-free than other kinds of programs. For example, step 7 through 10 are just informational or not critical and step 5 just contains a lot of detail which you do not even have to read through. And step 6, and just says start Sierra Chart. We probably do not even have to say that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-17 17:37:34
| [2015-07-20 20:41:07] |
A bit of a follow-up....can I install SC on 2 computers at one time. Only one will be online at a time. Called DTN and they said I could have DTN on 2 computers but can only have one online. Which is fine with me cuz I know setting things up with a new pc, Win7, video card. etc. will take some trial and error.
| [2015-07-20 20:58:13] |
Yes you can install Sierra Chart on as many computers as you need and you can use two of them at the same time. This is explained here: Sierra Chart Purchase and License Information: Licensing / Number of Systems Also if you use the Sierra Chart Exchange Data Feed it supports using it on up to 3 systems at a time. The cost is only 20 USD per additional system more: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
