Date/Time: Sat, 12 Sep 2026 12:22:38 +0000
Indicator for MA's
View Count: 1078
| [2015-07-14 20:43:54] |
| User623839 - Posts: 108 |
Is there an indicator or can I code this. I have several moving averages that I am looking for a signal when the are all very tight and close together?
| [2015-07-15 02:44:58] |
For this, you would want to create an Alert Condition Formula to give you a signal when this is the case. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html You will have to determine the appropriate formula. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
