Date/Time: Sun, 20 Sep 2026 05:02:37 +0000
Log Scale Vertical Drawing Issue...
View Count: 1041
| [2015-07-12 05:42:44] |
| esMike - Posts: 83 |
I have labels which work on a linear scale chart, but get screwed up on a log scale chart... Any ideas what to do here? See attached... Vertical is set for tools with... Tool.BeginValue = 99.5; Tool.BeginValue = 95.5; |
| [2015-07-13 20:39:09] |
We will look into this.
| [2015-07-15 16:40:51] |
| Al SC Developer - Posts: 434 |
This is addressed in the next version.
