Date/Time: Thu, 29 Oct 2026 23:09:23 +0000
Sierra Chart shows a price range for trades where volume is 1
View Count: 1171
| [2015-07-12 03:30:35] |
| User534053 - Posts: 25 |
Hi, I'm looking at the data for CLQ5-NYMEX (with auto rollover) and specifically at the data for 10:30 AM EST on June 10, 2015. This was a point in time where several hundred trades were executed in less than a second. I'm using the Number of Trades per Bar chart with trades set to 1, but the candlesticks are showing a price range 61.27 to 61.62 for the whole set of trades, even though each trade has a volume of just 1 or 2. It seems like a single trade of a single contract should be executed at a specific price. Do you know why the chart is showing a price range instead of a single price? Thanks, Markus |
| [2015-07-12 03:51:51] |
After a little more digging, it looks like the problem is that the chart doesn't have tick data for CL on days before June 10th. Does the Sierra Chart data feed have a 30 day limit on tick data, or is there a setting that I need to change? I have the "max days to download" for 1-tick data set to 1000 days.
| [2015-07-12 03:59:49] |
Ok, found the solution! You can mark this issue as resolved. This very helpful doc had the solution: http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html I had already tried deleting and re-downloading the data file, but my mistake was to click Yes when it asked if I only wanted to delete the specific contract I was looking at. I overlooked the fact that it wouldn't download the older contracts in the continuous series. Thanks for the great software and data feed! |
| [2015-07-13 17:08:05] |
Here is the reference for re-downloading Continuous Futures Contract data: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
