Date/Time: Tue, 27 Oct 2026 18:54:10 +0000
Set Currency Value
View Count: 1306
| [2015-07-10 07:41:29] |
| User96015 - Posts: 55 |
Hi, I imported a Csv File and I did a Autotrade System Bar Based BackTest. But Currency value isn' t correct. I changed it from Chart Setting, in Advanced Settings 2, but when I watch in Trade Activity Log the currency value for tick isn' t correct. How can I set the correct currency value, in such away that Profit and Loss in Trade Activity Log are correct? Thx, and bye. |
| [2015-07-10 07:58:45] |
Refer to this page: https://www.sierrachart.com/index.php?page=doc/helpdetails77.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-07-10 09:27:24] |
Ok thx. Bye
