Date/Time: Tue, 27 Oct 2026 18:55:06 +0000
intraday data
View Count: 1266
| [2015-07-09 11:12:35] |
| jimnovak - Posts: 42 |
i cannot get fx intraday data beyond 3/12/2007. i am connected to sc forex data feed, set intraday number of stored time and sales record, non-tick data and 1-tick data , chart settings> days to load all to 3500, but somehow data only goes back to 03/12/07, for any symbol. am i overlooking something or doing something wrong, or does intraday data only goes back to that date? regards |
| [2015-07-09 18:09:17] |
The Forex Intraday data does not go back further than this.
| [2015-07-09 18:36:49] |
ok. i thought so. maybe this an issue for you to raise with fxcm? why not at least cover ten years of intraday?
| [2015-07-09 18:39:27] |
This limitation has nothing to do with FXCM. The data is just not available and will not be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-07-09 18:40:24] |
then what causes it?
| [2015-07-09 18:40:56] |
oh i just read the rest of your reply
| [2015-07-09 18:42:18] |
do you mean it dont matter who supplies data, forex intrady is not available that far back for anybody?!
| [2015-07-09 18:43:41] |
Yes, this is correct. The data is maintained by our own systems and that data collection began at the time you see it start.
