Date/Time: Tue, 27 Oct 2026 18:54:12 +0000
Reward/Risk from ACSIL
View Count: 1397
| [2015-07-09 08:29:51] |
| User67732 - Posts: 11 |
Hi Support, I've tried everything I can think of to draw a reward/risk tool DRAWING_REWARD_RISK from my custom study but I cannot get it to work. There is very little in the documentation on how to set up the s_UseTool struct for this tool and there does not seem to be specific members related to this tool although I assume the BeginValue, EndValue and ThirdValue are used for the stop, entry and target prices. I am using version 1265 and have also tried version 1268. Please can you confirm or otherwise that this tool is available to draw from ACSIL code in custom studies. Many thanks. Larry Anderson |
| [2015-07-10 01:20:18] |
We need to test this and create an example function.
