Date/Time: Tue, 27 Oct 2026 18:55:03 +0000
alert log message misleading
View Count: 1074
| [2015-07-09 06:06:10] |
| dmh - Posts: 9 |
I had an alert on a drawing tool that was triggered. The alert has send SMS enabled and SMS enabled on account. My phone got the SMS message no problem. However, log had this message There is no SMS telephone number specified. Alert SMS message not sent. | 2015-07-09 00:01:37 * There is no SMS telephone number specified. Alert SMS message not sent. | 2015-07-09 00:01:38 * this happens every time I use SMS on an alert, is there some way to fix? Also drawing tool alert triggers on historical data (eg chart reload) is that expected? |
| [2015-07-09 08:26:50] |
This was a programming error that has now been corrected. It will be out in the next release. Also drawing tool alert triggers on historical data (eg chart reload) is that expected? Reloading a chart can trigger Chart Drawing alerts. However, they should not trigger when historical data is being downloaded. We have checked the code and see this can happen. This will be solved in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-09 08:27:39
