Date/Time: Tue, 27 Oct 2026 18:55:03 +0000
Sierra Chart Version 1268 Status Bar
View Count: 1262
| [2015-07-08 16:38:40] |
| User964792 - Posts: 4 |
Updated to Version 1268. Status bar is not included. Table of contents explains it's function and location but not how to turn it on or off. Nor is it shown in the Menu. Did I miss something? No disrespect intended.
| [2015-07-08 17:26:20] |
This has been removed. And the new Control Bar containing a Status window is going to be released today or tomorrow. You should be fine without it for a day or two because you can see the current data feed status on the title bar of the main window. And when using the Chart Values Tool or one of the drawing Tools you can see the chart values in one of the Tool Values windows. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ToolValuesWindow Also the Compact Tool Values window can be set to be displayed horizontally. The documentation explains how to do that here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#HorizontalCompactToolValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-07-09 01:59:41] |
| SgtJ - Posts: 154 |
The horiz compact tool seems decent, but would you be willing to add to DF/ST counts and green/red connectivity status to it?
| [2015-07-09 14:04:29] |
| SgtJ - Posts: 154 |
Please add # of trades too.
