Date/Time: Fri, 25 Sep 2026 01:01:27 +0000
Text PersistVars
View Count: 1392
| [2015-06-29 21:23:10] |
| User53601 - Posts: 107 |
Hello, Seems there are no Text PersitVars implemented for use in ACSIL. Is there a way how to takeover a text value through loops? Situation: For every bar I display a text using s_UseTool. In some cases I need to use the same text value as was used in previous bars, so I wanted to use PersistVar text type, to hold text value through loops. However as I found out, Text PersistVar it is not available. Thank you Date Time Of Last Edit: 2015-06-29 21:23:58
| [2015-06-30 12:38:51] |
| jackw - Posts: 57 |
There is a 512 byte block of permanent memory where you can store your text strings. See documentation for sc.StorageBlock. If that is not enough space then you can allocate your own block of persistent memory. See http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#DynamicMemoryAllocations |
| [2015-07-03 23:44:17] |
We will add text persistent variables.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-03 23:44:29
| [2015-07-04 06:51:49] |
Great.
| [2016-05-21 18:43:52] |
Anything new in text persistent variables?
| [2016-05-21 23:30:17] |
Apparently this had gotten overlooked. We are going to review it in the next few days and add this capability if there are no complications.
