Date/Time: Sat, 19 Sep 2026 11:41:27 +0000
DIDI INDEX
View Count: 1936
| [2015-06-22 19:32:16] |
| User379459 - Posts: 9 |
Hello, how can I setup a specific index in sierra chart? i like to setup 3 average moving line. 3,8 and 21 but the 8 EMA, should be flat in horizontal. its possible to do it? thanks Vitor |
| [2015-06-23 18:10:09] |
how can I setup a specific index in sierra chart? To add moving averages to the chart, follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingModifyingStudies The same moving average can be added more than one time to the chart. but the 8 EMA, should be flat in horizontal. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-23 18:10:30
| [2021-12-05 22:47:24] |
| User569346 - Posts: 4 |
Hi The 'DIDI indicator' was designed by the Brazilian trader Didi Aguiar, composed of 3 simple moving averages (3MA, 8MA and 20MA) being the 8MA plotted as a straight line instead of a common moving average line. The Didi indicator looks and works similar to the DMI (Directional Movement Indicator) technical indicator, invented by J. Wells Wilder. The Didi crossing lines provide you with the buy and sell entry signals. It’s a typical crossover trading system. The indicator is composed of 3 moving averages with different periods. The 3 MA periods could be adjusted in Sierra Chart from the "Drawn Style" as a "Straight Line" option inputs menu. Regards, Helio Reference: https://www.sealtrader.com/didi-index-buy-sell-metatrader-4-forex-indicator/ |
| [2021-12-05 23:16:14] |
Ok we will look into this.
