Date/Time: Thu, 15 Oct 2026 17:40:14 +0000
Replay stock historical tick by tick
View Count: 1806
| [2015-06-16 01:20:05] |
| Kinobe - Posts: 86 |
hi I want to replay stock like NQ, IDRA, ICLD, ISR, etc with tick by tick data. I have the Sierra Chart Real-Time and Historical Exchange Data Feed. I want to replay them lets say for june 2013. 1 - is it possible? 2 - If so how should I do? by setting the number of days to dowload to 726 days? after by using the function Goto datetime? thank you |
| [2015-06-16 04:58:07] |
1. No because back at that date of June 2013 approximately there is not tick by tick data for stocks. Only 1 minute data. 2. Refer to: Replaying Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-06-16 12:22:44] |
tick data for stocks can go back to what date?
| [2015-06-16 16:35:03] |
About 6 months back.
