Date/Time: Sun, 11 May 2025 13:34:29 +0000
Missing Sunday afternoon and Sunday night data YM and ES
View Count: 839
[2015-06-08 06:01:37] |
User33743 - Posts: 83 |
Similar issue. i noticed problem on several computers. Plis check it
[2015-06-08 06:10:11] |
Problem is on every instrument.
[2015-06-08 07:30:19] |
This is now solved. Right-click on the chart before the missing bars and select Delete And Download Data.
