Date/Time: Tue, 27 Oct 2026 22:05:27 +0000
[Locked] - Force SC to use SC data service
View Count: 2286
| [2015-05-17 19:38:57] |
| User69487 - Posts: 21 |
I have the SC data service and IB setup. I have found when loading historical data SC uses IB which only supports 1 second intervals for its' data vs SC's service which supports tick data. How can I force SC to only use the SC data exchange and ignore IB for equities? I cannot disable IB as it is providing futures data. |
| [2015-05-17 20:16:26] |
You need to pay for and activate the Sierra Chart Real-time and Historical Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-17 21:47:54] |
I have, or at least I think I have...it says the following is active: First Real-time data connection. Sierra Chart Real-Time and Historical Exchange Data Feed (Non Refundable). And is @ $35/month |
| [2015-05-17 21:51:34] |
OK then you need to activate the US Equities exchange or the BATS exchange. If you do not want to trade from the charts and just use the charts for charting, then you can activate the BATS exchange and save some money. However, the symbols are a little different. For example: AA.BZ. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-17 21:52:12
| [2015-05-17 21:59:59] |
I activated it, and restarted SC: - The 'BATS (NYSE, NASDAQ)' exchange has been internally activated, and will be renewed. You need to restart Sierra Chart to access the exchange. Pulled up $AAPL, intraday, deleted/re-download and still see it coming out of IB: HD Request # 24 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ib | 2015-05-17 17:58:41 HD Request # 24 | Download start Date-Time: 2015-05-15 19:59:50.0 | 2015-05-17 17:58:41 HD Request # 24 | Requesting a total of 1 days and 83931 seconds. | 2015-05-17 17:58:41 HD Request # 24 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 83931. | 2015-05-17 17:58:41 HD Request # 24 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-05-16 19:49:50 for AAPL | 2015-05-17 17:58:41 HD Request # 24 | Processing historical data message from TWS | 2015-05-17 17:58:42 HD Request # 24 | Receiving Intraday data for AAPL starting at 2015-05-15 19:50:00 | 2015-05-17 17:58:42 HD Request # 24 | Received 2880 records and wrote 0 records from 2015-05-14 12:00:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:42 HD Request # 24 | IB Backfill - Seconds requested: 83931. Seconds Remaining: 0. | 2015-05-17 17:58:43 HD Request # 24 | Requesting 83931 Seconds of data at 30 secs with ending Date-Time at 2015-05-17 19:08:41 for AAPL | 2015-05-17 17:58:43 HD Request # 24 | Processing historical data message from TWS | 2015-05-17 17:58:43 HD Request # 24 | Received 2798 records and wrote 0 records from 2015-05-14 12:41:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:43 HD Request # 24 | Received 5678 records from 2015-05-15 19:50:00 to 2015-05-15 19:59:30 (9.5 minutes) and wrote 0 records for AAPL | 2015-05-17 17:58:44 HD Request # 24 | Intraday download COMPLETE for AAPL. Completion time: 3s. Unique request ID: 23 | 2015-05-17 17:58:44 Removed historical data download ID 23 | 2015-05-17 17:58:44 Real-time Intraday chart data file updates started for AAPL | 2015-05-17 17:58:44 |
| [2015-05-17 22:17:03] |
Ok I got it going, had to select SC historical data as the data service. One other question, how do you find the values of a specific time on the chart? When I pull up the chart values window it only shows the values of the last displayed column. |
| [2015-05-17 22:48:53] |
You can do that, but the data will be delayed. Use the Tool Values window: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-18 13:33:25] |
Now I'm not seeing real time data...what do I need to select to get real time data under trade data settings?
| [2015-05-18 14:11:11] |
I selected SC Exchange Data but I don't see any price updates for futures or stocks (i.e., AAPL)...I have IB as a registered trading service.
| [2015-05-18 16:33:57] |
For futures data you need to use Interactive Brokers to receive the CME data. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME For stocks, restart Sierra Chart and post a copy of the Message Log after opening a stock chart. Here are instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-19 21:39:01] |
I do have IB but if I select IB as my trading service I lose the tick level info that I signed up for via SC. How do I enable both?
| [2015-05-19 21:59:01] |
You need to activate the US Equities exchange or the BATS exchange to get tick by tick historical data when using Interactive Brokers. There is no other way.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-19 22:03:42
| [2015-05-19 22:16:58] |
Actually one thing we could do is to allow the historical tick data to be accessed when using Interactive Brokers if you will have activated the SC Exchange Data Feed, but keep in mind it is going to be delayed and the most recent 15 minutes will be 30 seconds data from Interactive Brokers. So if this is acceptable, this is a possibility. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-20 01:31:23] |
I'm not worried about the historical piece, I'm more interested in how to use SC for tick by tick and IB for futures. From what I can tell, I can only select one data service.
| [2015-05-20 02:21:13] |
We see you have the CME Group and BATS exchanges activated on your account. When using Interactive Brokers, market data for all of the symbols available from those exchanges will then come from the Sierra Chart Exchange Data Feed. Are you having any difficulty receiving the data? You know it is coming from the Sierra Chart Exchange Data Feed when you see [M] at the top of the chart. For BATS, be sure to use .BZ at the end of the symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-20 02:21:14] |
| [2015-05-20 03:06:11] |
Yes, I see an [M] for AAPL, if I put in AAPL.BZ I see no charts at all. Software version: 1224 | 2015-05-17 17:57:29 Uses New Spreadsheets | 2015-05-17 17:57:29 Usage end date: 2015-06-10 | 2015-05-17 17:57:29 Enabled for: Advanced Features. | 2015-05-17 17:57:29 Enabled for: Sierra Chart Historical Data Service. | 2015-05-17 17:57:29 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2015-05-17 17:57:29 Enabled for: CME, CBOT, NYMEX, COMEX exchanges for trading accounts. | 2015-05-17 17:57:29 Received 1 data feed usernames. | 2015-05-17 17:57:29 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-05-17 17:57:29 Active service: Interactive Brokers | 2015-05-17 17:57:29 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-05-17 17:57:29 2015-05-17 14:57:29 Local computer clock time | 2015-05-17 17:57:29 2015-05-17 21:57:29 GMT time | 2015-05-17 17:57:29 2015-05-17 17:57:29 Time zone adjusted time | 2015-05-17 17:57:29 Time difference to server time: 0 seconds. | 2015-05-17 17:57:29 Program path: C:\SierraChart\ | 2015-05-17 17:57:29 Data Files path: C:\SierraChart\Data\ | 2015-05-17 17:57:29 OS Version Number: 6.1 | 2015-05-17 17:57:29 Locale Information: C | 2015-05-17 17:57:29 Checking for new symbol settings for ib | 2015-05-17 17:57:29 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-05-17 17:57:29 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-05-17 17:57:29 Requesting symbol settings for ib. Overwrite = on. | 2015-05-17 17:57:29 Symbol settings received. | 2015-05-17 17:57:32 Processed received symbol settings | 2015-05-17 17:57:32 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 17:57:34 Socket (2) | Connected. | 2015-05-17 17:57:34 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2015-05-17 17:57:34 Interactive Brokers | TWS server version: 76 | 2015-05-17 17:57:34 Interactive Brokers | Connected. Waiting for account information. | 2015-05-17 17:57:34 Interactive Brokers | Received Open orders end message. | 2015-05-17 17:57:34 IB Account information received. | 2015-05-17 17:57:34 Interactive Brokers | Received 5 Trade Accounts from TWS. | 2015-05-17 17:57:34 Interactive Brokers | Connected to Live account. | 2015-05-17 17:57:34 Interactive Brokers | Year-Month last connected to Live account: 2015-05 | 2015-05-17 17:57:34 Interactive Brokers | Connected to Financial Advisor account. | 2015-05-17 17:57:34 Next valid order ID: 1 | 2015-05-17 17:57:34 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2015-05-17 17:57:34 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2015-05-17 17:57:34 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2015-05-17 17:57:34 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2015-05-17 17:57:34 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2015-05-17 17:57:34 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2015-05-17 17:57:34 Next valid order ID: 1 | 2015-05-17 17:57:34 IB Account information received. | 2015-05-17 17:57:34 Interactive Brokers | Received 5 Trade Accounts from TWS. | 2015-05-17 17:57:34 Interactive Brokers | Connected to Live account. | 2015-05-17 17:57:34 Interactive Brokers | Year-Month last connected to Live account: 2015-05 | 2015-05-17 17:57:34 Interactive Brokers | Connected to Financial Advisor account. | 2015-05-17 17:57:34 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-05-17 17:57:36 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-05-17 17:57:36 Interactive Brokers | Requesting historical order fills for account F13*. | 2015-05-17 17:57:39 Interactive Brokers | Requesting historical order fills for account U13*. | 2015-05-17 17:57:39 Interactive Brokers | Requesting historical order fills for account U13*. | 2015-05-17 17:57:39 Interactive Brokers | Requesting historical order fills for account U13*. | 2015-05-17 17:57:39 Interactive Brokers | Requesting historical order fills for account U14*. | 2015-05-17 17:57:39 Interactive Brokers | Received Open orders end message. | 2015-05-17 17:57:39 Interactive Brokers | Starting real-time market data updates for: IBB. ID: 1 | 2015-05-17 17:57:50 Interactive Brokers | Subscribing to Symbol: IBB, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-17 17:57:50 HD Request # 2 | Downloading Historical Daily chart data for IBB. Starting date: 2015-05-14. Service: ib | 2015-05-17 17:57:50 HD Request # 2 | Using user Barchart Historical data account. | 2015-05-17 17:57:50 HD Request # 2 | Requesting historical Daily data for IBB starting at 2015-05-13 | 2015-05-17 17:57:50 Intraday data recording state for symbol IBB is set to download pending. | 2015-05-17 17:57:50 HD Request # 3 | Downloading Intraday chart data for IBB to the file IBB.scid. Service: equities.us | 2015-05-17 17:57:50 HD Request # 3 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:57:50 HD Request # 3 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 17:57:50 Interactive Brokers | Starting real-time market data updates for: SMH. ID: 2 | 2015-05-17 17:57:50 Interactive Brokers | Subscribing to Symbol: SMH, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-17 17:57:50 Intraday data recording state for symbol SMH is set to download pending. | 2015-05-17 17:57:50 Interactive Brokers | Starting real-time market data updates for: ESPR. ID: 3 | 2015-05-17 17:57:50 Interactive Brokers | Subscribing to Symbol: ESPR, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-17 17:57:50 Intraday data recording state for symbol ESPR is set to download pending. | 2015-05-17 17:57:50 Interactive Brokers | Starting real-time market data updates for: UWTI. ID: 4 | 2015-05-17 17:57:50 Interactive Brokers | Subscribing to Symbol: UWTI, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-17 17:57:50 Intraday data recording state for symbol UWTI is set to download pending. | 2015-05-17 17:57:50 Interactive Brokers | Starting real-time market data updates for: PFE. ID: 5 | 2015-05-17 17:57:50 Interactive Brokers | Subscribing to Symbol: PFE, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-17 17:57:50 Intraday data recording state for symbol PFE is set to download pending. | 2015-05-17 17:57:50 Interactive Brokers | Starting real-time market data updates for: CMG. ID: 6 | 2015-05-17 17:57:50 Interactive Brokers | Subscribing to Symbol: CMG, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-17 17:57:50 Intraday data recording state for symbol CMG is set to download pending. | 2015-05-17 17:57:50 Interactive Brokers | Starting real-time market data updates for: USO. ID: 7 | 2015-05-17 17:57:50 Interactive Brokers | Subscribing to Symbol: USO, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-17 17:57:50 Intraday data recording state for symbol USO is set to download pending. | 2015-05-17 17:57:50 Interactive Brokers | Starting real-time market data updates for: FSL. ID: 8 | 2015-05-17 17:57:50 Interactive Brokers | Subscribing to Symbol: FSL, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-17 17:57:50 Intraday data recording state for symbol FSL is set to download pending. | 2015-05-17 17:57:50 Interactive Brokers | Starting real-time market data updates for: AAPL. ID: 9 | 2015-05-17 17:57:50 Interactive Brokers | Subscribing to Symbol: AAPL, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-17 17:57:50 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 17:57:50 Mapping ES-201506-GLOBEX to ESM15. Service code: cme | 2015-05-17 17:57:50 SC Exchange Data | Starting real-time market data updates for: ESM15. ID: 10 | 2015-05-17 17:57:50 Using username 0 | 2015-05-17 17:57:50 SC Exchange Data | Connecting to the server scdf1.sierracharts.com. Port 443 | 2015-05-17 17:57:50 Intraday data recording state for symbol ES-201506-GLOBEX is set to download pending. | 2015-05-17 17:57:50 Mapping NQ-201506-GLOBEX to NQM15. Service code: cme | 2015-05-17 17:57:50 SC Exchange Data | Starting real-time market data updates for: NQM15. ID: 11 | 2015-05-17 17:57:50 Intraday data recording state for symbol NQ-201506-GLOBEX is set to download pending. | 2015-05-17 17:57:50 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 17:57:50 Socket (3) | Connected. | 2015-05-17 17:57:50 HD Request # 3 | Sending historical data logon request message. | 2015-05-17 17:57:50 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 17:57:50 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 1. Symbol: IBB | 2015-05-17 17:57:50 Socket (4) | Connected. | 2015-05-17 17:57:50 SC Exchange Data | Connected to server. | 2015-05-17 17:57:50 SC Exchange Data | Sending logon request message. | 2015-05-17 17:57:50 HD Request # 3 | Decompressing data. | 2015-05-17 17:57:50 HD Request # 3 | Receiving Intraday data for IBB starting at 2015-05-14 19:59:33 | 2015-05-17 17:57:50 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-05-17 17:57:51 SC Exchange Data | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-05-17 17:57:51 SC Exchange Data | Successfully connected. | 2015-05-17 17:57:51 SC Exchange Data | Restarting real-time data updates for symbol: ES-201506-GLOBEX -> ESM15 | 2015-05-17 17:57:51 SC Exchange Data | Restarting real-time data updates for symbol: NQ-201506-GLOBEX -> NQM15 | 2015-05-17 17:57:51 HD Request # 2 | Receiving historical Daily data for IBB starting at 2015-05-13 | 2015-05-17 17:57:51 Writing historical Daily data for IBB to the file IBB.dly | 2015-05-17 17:57:51 HD Request # 2 | Received 3 records from 2015-05-13 00:00:00 to 2015-05-15 00:00:00 (3.0 days) and wrote 2 records for IBB | 2015-05-17 17:57:51 HD Request # 2 | Daily download COMPLETE for IBB. Completion time: 0s. Unique request ID: 1 | 2015-05-17 17:57:51 Removed historical data download ID 1 | 2015-05-17 17:57:51 Socket (3) | Shutdown and closed. | 2015-05-17 17:57:51 The network socket for historical data has been closed. | 2015-05-17 17:57:51 HD Request # 3 | Received 1506 records from 2015-05-14 19:59:33 to 2015-05-15 19:03:18 (23.1 hours) and wrote 0 records for IBB | 2015-05-17 17:57:51 HD Request # 3 | Intraday download COMPLETE for IBB. Completion time: 0s. Unique request ID: 2 | 2015-05-17 17:57:51 Removed historical data download ID 2 | 2015-05-17 17:57:51 Real-time Intraday chart data file updates started for IBB | 2015-05-17 17:57:51 Intraday data recording state for symbol IBB is set to download pending. | 2015-05-17 17:57:51 HD Request # 4 | Downloading Intraday chart data for IBB to the file IBB.scid. Service: ib | 2015-05-17 17:57:51 HD Request # 4 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:57:51 HD Request # 4 | Requesting a total of 1 days and 83901 seconds. | 2015-05-17 17:57:51 HD Request # 4 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 83901. | 2015-05-17 17:57:51 HD Request # 4 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-05-16 19:49:30 for IBB | 2015-05-17 17:57:51 HD Request # 5 | Downloading Intraday chart data for SMH to the file SMH.scid. Service: equities.us | 2015-05-17 17:57:51 HD Request # 5 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:57:51 HD Request # 5 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 17:57:51 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 17:57:51 Socket (5) | Connected. | 2015-05-17 17:57:51 HD Request # 5 | Sending historical data logon request message. | 2015-05-17 17:57:51 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 1. Symbol: SMH | 2015-05-17 17:57:51 HD Request # 5 | Decompressing data. | 2015-05-17 17:57:51 HD Request # 5 | Receiving Intraday data for SMH starting at 2015-05-14 16:02:36 | 2015-05-17 17:57:51 HD Request # 4 | Processing historical data message from TWS | 2015-05-17 17:57:51 HD Request # 4 | Receiving Intraday data for IBB starting at 2015-05-15 19:50:00 | 2015-05-17 17:57:51 HD Request # 4 | Received 2220 records and wrote 0 records from 2015-05-14 12:00:00 to 2015-05-15 19:59:30. | 2015-05-17 17:57:51 Socket (5) | Shutdown and closed. | 2015-05-17 17:57:51 The network socket for historical data has been closed. | 2015-05-17 17:57:51 HD Request # 5 | Received 1539 records from 2015-05-14 16:02:36 to 2015-05-15 16:00:21 (24.0 hours) and wrote 0 records for SMH | 2015-05-17 17:57:51 HD Request # 5 | Intraday download COMPLETE for SMH. Completion time: 0s. Unique request ID: 3 | 2015-05-17 17:57:51 Removed historical data download ID 3 | 2015-05-17 17:57:51 Real-time Intraday chart data file updates started for SMH | 2015-05-17 17:57:51 Intraday data recording state for symbol SMH is set to download pending. | 2015-05-17 17:57:51 HD Request # 6 | Downloading Intraday chart data for ESPR to the file ESPR.scid. Service: equities.us | 2015-05-17 17:57:51 HD Request # 6 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:57:51 HD Request # 6 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 17:57:51 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 17:57:51 Socket (6) | Connected. | 2015-05-17 17:57:51 HD Request # 6 | Sending historical data logon request message. | 2015-05-17 17:57:51 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 1. Symbol: ESPR | 2015-05-17 17:57:51 HD Request # 6 | Decompressing data. | 2015-05-17 17:57:51 HD Request # 6 | Receiving Intraday data for ESPR starting at 2015-05-14 15:59:59 | 2015-05-17 17:57:51 Socket (6) | Shutdown and closed. | 2015-05-17 17:57:51 The network socket for historical data has been closed. | 2015-05-17 17:57:51 HD Request # 6 | Received 510 records from 2015-05-14 15:59:59 to 2015-05-15 15:59:58 (24.0 hours) and wrote 0 records for ESPR | 2015-05-17 17:57:51 HD Request # 6 | Intraday download COMPLETE for ESPR. Completion time: 0s. Unique request ID: 4 | 2015-05-17 17:57:51 Removed historical data download ID 4 | 2015-05-17 17:57:51 Real-time Intraday chart data file updates started for ESPR | 2015-05-17 17:57:51 Intraday data recording state for symbol ESPR is set to download pending. | 2015-05-17 17:57:52 HD Request # 7 | Downloading Intraday chart data for UWTI to the file UWTI.scid. Service: equities.us | 2015-05-17 17:57:52 HD Request # 7 | Download start Date-Time: 2015-05-15 19:59:56.0 | 2015-05-17 17:57:52 HD Request # 7 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 17:57:52 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 17:57:52 Socket (7) | Connected. | 2015-05-17 17:57:52 HD Request # 7 | Sending historical data logon request message. | 2015-05-17 17:57:52 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:56. Record interval: 1. Symbol: UWTI | 2015-05-17 17:57:52 HD Request # 7 | Decompressing data. | 2015-05-17 17:57:52 HD Request # 7 | Receiving Intraday data for UWTI starting at 2015-05-15 06:10:56 | 2015-05-17 17:57:52 HD Request # 4 | IB Backfill - Seconds requested: 83901. Seconds Remaining: 0. | 2015-05-17 17:57:52 HD Request # 4 | Requesting 83901 Seconds of data at 30 secs with ending Date-Time at 2015-05-17 19:07:51 for IBB | 2015-05-17 17:57:52 Socket (7) | Shutdown and closed. | 2015-05-17 17:57:52 The network socket for historical data has been closed. | 2015-05-17 17:57:52 HD Request # 7 | Received 5938 records from 2015-05-15 06:10:56 to 2015-05-15 19:59:55 (13.8 hours) and wrote 0 records for UWTI | 2015-05-17 17:57:52 HD Request # 7 | Intraday download COMPLETE for UWTI. Completion time: 0s. Unique request ID: 5 | 2015-05-17 17:57:52 Removed historical data download ID 5 | 2015-05-17 17:57:52 Real-time Intraday chart data file updates started for UWTI | 2015-05-17 17:57:52 Intraday data recording state for symbol UWTI is set to download pending. | 2015-05-17 17:57:52 HD Request # 8 | Downloading Intraday chart data for PFE to the file PFE.scid. Service: equities.us | 2015-05-17 17:57:52 HD Request # 8 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:57:52 HD Request # 8 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 17:57:52 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 17:57:52 Socket (8) | Connected. | 2015-05-17 17:57:52 HD Request # 8 | Sending historical data logon request message. | 2015-05-17 17:57:52 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 1. Symbol: PFE | 2015-05-17 17:57:52 HD Request # 8 | Decompressing data. | 2015-05-17 17:57:53 HD Request # 8 | Receiving Intraday data for PFE starting at 2015-05-15 08:00:00 | 2015-05-17 17:57:53 HD Request # 4 | Processing historical data message from TWS | 2015-05-17 17:57:53 HD Request # 4 | Received 2137 records and wrote 0 records from 2015-05-14 12:41:30 to 2015-05-15 19:59:30. | 2015-05-17 17:57:53 Socket (8) | Shutdown and closed. | 2015-05-17 17:57:53 The network socket for historical data has been closed. | 2015-05-17 17:57:53 HD Request # 8 | Received 8512 records from 2015-05-15 08:00:00 to 2015-05-15 19:45:01 (11.8 hours) and wrote 0 records for PFE | 2015-05-17 17:57:53 HD Request # 8 | Intraday download COMPLETE for PFE. Completion time: 1s. Unique request ID: 6 | 2015-05-17 17:57:53 Removed historical data download ID 6 | 2015-05-17 17:57:53 Real-time Intraday chart data file updates started for PFE | 2015-05-17 17:57:53 Intraday data recording state for symbol PFE is set to download pending. | 2015-05-17 17:57:53 HD Request # 9 | Downloading Intraday chart data for CMG to the file CMG.scid. Service: equities.us | 2015-05-17 17:57:53 HD Request # 9 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:57:53 HD Request # 9 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 17:57:53 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 17:57:53 Socket (9) | Connected. | 2015-05-17 17:57:53 HD Request # 9 | Sending historical data logon request message. | 2015-05-17 17:57:53 HD Request # 9 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 1. Symbol: CMG | 2015-05-17 17:57:53 HD Request # 9 | Decompressing data. | 2015-05-17 17:57:53 HD Request # 9 | Receiving Intraday data for CMG starting at 2015-05-14 16:46:34 | 2015-05-17 17:57:53 Socket (9) | Shutdown and closed. | 2015-05-17 17:57:53 The network socket for historical data has been closed. | 2015-05-17 17:57:53 HD Request # 9 | Received 816 records from 2015-05-14 16:46:34 to 2015-05-15 16:31:28 (23.7 hours) and wrote 0 records for CMG | 2015-05-17 17:57:53 HD Request # 9 | Intraday download COMPLETE for CMG. Completion time: 0s. Unique request ID: 7 | 2015-05-17 17:57:53 Removed historical data download ID 7 | 2015-05-17 17:57:53 Real-time Intraday chart data file updates started for CMG | 2015-05-17 17:57:53 Intraday data recording state for symbol CMG is set to download pending. | 2015-05-17 17:57:53 HD Request # 10 | Downloading Intraday chart data for USO to the file USO.scid. Service: equities.us | 2015-05-17 17:57:53 HD Request # 10 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:57:53 HD Request # 10 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 17:57:53 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 17:57:53 Socket (10) | Connected. | 2015-05-17 17:57:53 HD Request # 10 | Sending historical data logon request message. | 2015-05-17 17:57:53 HD Request # 10 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 1. Symbol: USO | 2015-05-17 17:57:53 HD Request # 10 | Decompressing data. | 2015-05-17 17:57:54 HD Request # 10 | Receiving Intraday data for USO starting at 2015-05-14 18:49:09 | 2015-05-17 17:57:54 Socket (10) | Shutdown and closed. | 2015-05-17 17:57:54 The network socket for historical data has been closed. | 2015-05-17 17:57:54 HD Request # 10 | Received 5012 records from 2015-05-14 18:49:09 to 2015-05-15 18:20:06 (23.5 hours) and wrote 0 records for USO | 2015-05-17 17:57:54 HD Request # 10 | Intraday download COMPLETE for USO. Completion time: 0s. Unique request ID: 8 | 2015-05-17 17:57:54 Removed historical data download ID 8 | 2015-05-17 17:57:54 Real-time Intraday chart data file updates started for USO | 2015-05-17 17:57:54 Intraday data recording state for symbol USO is set to download pending. | 2015-05-17 17:57:54 HD Request # 11 | Downloading Intraday chart data for FSL to the file FSL.scid. Service: equities.us | 2015-05-17 17:57:54 HD Request # 11 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:57:54 HD Request # 11 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 17:57:54 HD Request # 4 | Received 4357 records from 2015-05-15 19:50:00 to 2015-05-15 19:59:30 (9.5 minutes) and wrote 0 records for IBB | 2015-05-17 17:57:54 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 17:57:54 HD Request # 4 | Intraday download COMPLETE for IBB. Completion time: 3s. Unique request ID: 13 | 2015-05-17 17:57:54 Removed historical data download ID 13 | 2015-05-17 17:57:54 Real-time Intraday chart data file updates started for IBB | 2015-05-17 17:57:54 HD Request # 12 | Downloading Intraday chart data for SMH to the file SMH.scid. Service: ib | 2015-05-17 17:57:54 HD Request # 12 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:57:54 HD Request # 12 | Requesting a total of 1 days and 83904 seconds. | 2015-05-17 17:57:54 HD Request # 12 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 83904. | 2015-05-17 17:57:54 HD Request # 12 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-05-16 19:49:30 for SMH | 2015-05-17 17:57:54 Socket (11) | Connected. | 2015-05-17 17:57:54 HD Request # 11 | Sending historical data logon request message. | 2015-05-17 17:57:54 Requesting market depth updates for: AAPL if supported. | 2015-05-17 17:57:54 Requesting market depth updates for: CMG if supported. | 2015-05-17 17:57:54 Requesting market depth updates for: IBB if supported. | 2015-05-17 17:57:54 Requesting market depth updates for: SMH if supported. | 2015-05-17 17:57:54 HD Request # 11 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 1. Symbol: FSL | 2015-05-17 17:57:54 Message from IB: Deep market data is not supported for this combination of security type/exchange. IB Error Code: 10092. Request ID: 100009. | 2015-05-17 17:57:54 Message from IB: Deep market data is not supported for this combination of security type/exchange. IB Error Code: 10092. Request ID: 100006. | 2015-05-17 17:57:54 HD Request # 11 | Decompressing data. | 2015-05-17 17:57:54 HD Request # 11 | Receiving Intraday data for FSL starting at 2015-05-14 16:02:52 | 2015-05-17 17:57:54 Message from IB: Deep market data is not supported for this combination of security type/exchange. IB Error Code: 10092. Request ID: 100001. | 2015-05-17 17:57:54 Message from IB: Deep market data is not supported for this combination of security type/exchange. IB Error Code: 10092. Request ID: 100002. | 2015-05-17 17:57:54 Socket (11) | Shutdown and closed. | 2015-05-17 17:57:54 The network socket for historical data has been closed. | 2015-05-17 17:57:54 HD Request # 11 | Received 1630 records from 2015-05-14 16:02:52 to 2015-05-15 16:02:33 (24.0 hours) and wrote 0 records for FSL | 2015-05-17 17:57:54 HD Request # 11 | Intraday download COMPLETE for FSL. Completion time: 0s. Unique request ID: 9 | 2015-05-17 17:57:54 Removed historical data download ID 9 | 2015-05-17 17:57:54 Real-time Intraday chart data file updates started for FSL | 2015-05-17 17:57:54 Intraday data recording state for symbol FSL is set to download pending. | 2015-05-17 17:57:54 HD Request # 13 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: equities.us | 2015-05-17 17:57:54 HD Request # 13 | Download start Date-Time: 2015-05-15 19:59:50.0 | 2015-05-17 17:57:54 HD Request # 13 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 17:57:54 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 17:57:54 HD Request # 12 | Processing historical data message from TWS | 2015-05-17 17:57:54 HD Request # 12 | Receiving Intraday data for SMH starting at 2015-05-15 19:50:00 | 2015-05-17 17:57:54 HD Request # 12 | Received 2521 records and wrote 0 records from 2015-05-14 12:00:00 to 2015-05-15 19:59:30. | 2015-05-17 17:57:54 Socket (12) | Connected. | 2015-05-17 17:57:54 HD Request # 13 | Sending historical data logon request message. | 2015-05-17 17:57:54 HD Request # 13 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:50. Record interval: 1. Symbol: AAPL | 2015-05-17 17:57:54 HD Request # 13 | Decompressing data. | 2015-05-17 17:57:54 HD Request # 13 | Receiving Intraday data for AAPL starting at 2015-05-15 19:59:50 | 2015-05-17 17:57:54 HD Request # 13 | Timestamp of first Intraday data file record written: 2015-05-15 19:59:50 | 2015-05-17 17:57:54 Socket (12) | Shutdown and closed. | 2015-05-17 17:57:54 The network socket for historical data has been closed. | 2015-05-17 17:57:54 HD Request # 13 | Received 1 record from 2015-05-15 19:59:50 to 2015-05-15 19:59:50 (0.0 seconds) and wrote 1 record for AAPL | 2015-05-17 17:57:54 HD Request # 13 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 10 | 2015-05-17 17:57:54 Removed historical data download ID 10 | 2015-05-17 17:57:54 Real-time Intraday chart data file updates started for AAPL | 2015-05-17 17:57:54 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 17:57:54 HD Request # 14 | Downloading Intraday chart data for ES-201506-GLOBEX to the file ES-201506-GLOBEX.scid. Service: cme | 2015-05-17 17:57:55 HD Request # 14 | Download start Date-Time: 2015-05-15 17:14:59.0 | 2015-05-17 17:57:55 HD Request # 14 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 17:57:55 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 17:57:55 Socket (13) | Connected. | 2015-05-17 17:57:55 HD Request # 14 | Sending historical data logon request message. | 2015-05-17 17:57:55 HD Request # 14 | Requesting Intraday data. Start Date-Time: 2015-05-15 17:14:59. Record interval: 0. Symbol: ESM15 | 2015-05-17 17:57:55 HD Request # 14 | Decompressing data. | 2015-05-17 17:57:55 HD Request # 14 | Receiving Intraday data for ES-201506-GLOBEX starting at 2015-05-15 17:14:59 | 2015-05-17 17:57:55 Socket (13) | Shutdown and closed. | 2015-05-17 17:57:55 The network socket for historical data has been closed. | 2015-05-17 17:57:55 HD Request # 14 | Received 13 records from 2015-05-15 17:14:59 to 2015-05-15 17:14:59 (0.0 seconds) and wrote 0 records for ES-201506-GLOBEX | 2015-05-17 17:57:55 HD Request # 14 | Intraday download COMPLETE for ES-201506-GLOBEX. Completion time: 0s. Unique request ID: 11 | 2015-05-17 17:57:55 Removed historical data download ID 11 | 2015-05-17 17:57:55 Real-time Intraday chart data file updates started for ES-201506-GLOBEX | 2015-05-17 17:57:55 HD Request # 15 | Downloading Intraday chart data for NQ-201506-GLOBEX to the file NQ-201506-GLOBEX.scid. Service: cme | 2015-05-17 17:57:55 HD Request # 15 | Download start Date-Time: 2015-05-15 17:14:59.0 | 2015-05-17 17:57:55 HD Request # 15 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 17:57:55 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 17:57:55 Socket (14) | Connected. | 2015-05-17 17:57:55 HD Request # 15 | Sending historical data logon request message. | 2015-05-17 17:57:55 HD Request # 15 | Requesting Intraday data. Start Date-Time: 2015-05-15 17:14:59. Record interval: 0. Symbol: NQM15 | 2015-05-17 17:57:55 HD Request # 15 | Decompressing data. | 2015-05-17 17:57:55 HD Request # 15 | Receiving Intraday data for NQ-201506-GLOBEX starting at 2015-05-15 17:14:59 | 2015-05-17 17:57:55 Socket (14) | Shutdown and closed. | 2015-05-17 17:57:55 The network socket for historical data has been closed. | 2015-05-17 17:57:55 HD Request # 15 | Received 2 records from 2015-05-15 17:14:59 to 2015-05-15 17:14:59 (0.0 seconds) and wrote 0 records for NQ-201506-GLOBEX | 2015-05-17 17:57:55 HD Request # 15 | Intraday download COMPLETE for NQ-201506-GLOBEX. Completion time: 0s. Unique request ID: 12 | 2015-05-17 17:57:55 Removed historical data download ID 12 | 2015-05-17 17:57:55 Real-time Intraday chart data file updates started for NQ-201506-GLOBEX | 2015-05-17 17:57:55 HD Request # 12 | IB Backfill - Seconds requested: 83904. Seconds Remaining: 0. | 2015-05-17 17:57:55 HD Request # 12 | Requesting 83904 Seconds of data at 30 secs with ending Date-Time at 2015-05-17 19:07:54 for SMH | 2015-05-17 17:57:55 HD Request # 12 | Processing historical data message from TWS | 2015-05-17 17:57:56 HD Request # 12 | Received 2438 records and wrote 0 records from 2015-05-14 12:41:30 to 2015-05-15 19:59:30. | 2015-05-17 17:57:56 HD Request # 12 | Received 4959 records from 2015-05-15 19:50:00 to 2015-05-15 19:59:30 (9.5 minutes) and wrote 0 records for SMH | 2015-05-17 17:57:57 HD Request # 12 | Intraday download COMPLETE for SMH. Completion time: 3s. Unique request ID: 14 | 2015-05-17 17:57:57 Removed historical data download ID 14 | 2015-05-17 17:57:57 Real-time Intraday chart data file updates started for SMH | 2015-05-17 17:57:57 HD Request # 16 | Downloading Intraday chart data for ESPR to the file ESPR.scid. Service: ib | 2015-05-17 17:57:57 HD Request # 16 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:57:57 HD Request # 16 | Requesting a total of 1 days and 83907 seconds. | 2015-05-17 17:57:57 HD Request # 16 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 83907. | 2015-05-17 17:57:57 HD Request # 16 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-05-16 19:49:30 for ESPR | 2015-05-17 17:57:57 HD Request # 16 | Processing historical data message from TWS | 2015-05-17 17:57:57 HD Request # 16 | Receiving Intraday data for ESPR starting at 2015-05-15 19:50:00 | 2015-05-17 17:57:57 HD Request # 16 | Received 2221 records and wrote 0 records from 2015-05-14 12:00:00 to 2015-05-15 19:59:30. | 2015-05-17 17:57:57 HD Request # 16 | IB Backfill - Seconds requested: 83907. Seconds Remaining: 0. | 2015-05-17 17:57:59 HD Request # 16 | Requesting 83907 Seconds of data at 30 secs with ending Date-Time at 2015-05-17 19:07:57 for ESPR | 2015-05-17 17:57:59 HD Request # 16 | Processing historical data message from TWS | 2015-05-17 17:57:59 HD Request # 16 | Received 2138 records and wrote 0 records from 2015-05-14 12:41:30 to 2015-05-15 19:59:30. | 2015-05-17 17:57:59 HD Request # 16 | Received 4359 records from 2015-05-15 19:50:00 to 2015-05-15 19:59:30 (9.5 minutes) and wrote 0 records for ESPR | 2015-05-17 17:58:00 HD Request # 16 | Intraday download COMPLETE for ESPR. Completion time: 3s. Unique request ID: 15 | 2015-05-17 17:58:00 Removed historical data download ID 15 | 2015-05-17 17:58:00 Real-time Intraday chart data file updates started for ESPR | 2015-05-17 17:58:00 HD Request # 17 | Downloading Intraday chart data for UWTI to the file UWTI.scid. Service: ib | 2015-05-17 17:58:00 HD Request # 17 | Download start Date-Time: 2015-05-15 19:59:56.0 | 2015-05-17 17:58:00 HD Request # 17 | Requesting a total of 1 days and 83884 seconds. | 2015-05-17 17:58:00 HD Request # 17 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 83884. | 2015-05-17 17:58:00 HD Request # 17 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-05-16 19:49:56 for UWTI | 2015-05-17 17:58:00 HD Request # 17 | Processing historical data message from TWS | 2015-05-17 17:58:01 HD Request # 17 | Receiving Intraday data for UWTI starting at 2015-05-15 19:50:00 | 2015-05-17 17:58:01 HD Request # 17 | Received 2871 records and wrote 0 records from 2015-05-14 12:00:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:01 HD Request # 17 | IB Backfill - Seconds requested: 83884. Seconds Remaining: 0. | 2015-05-17 17:58:02 HD Request # 17 | Requesting 83884 Seconds of data at 30 secs with ending Date-Time at 2015-05-17 19:08:00 for UWTI | 2015-05-17 17:58:02 HD Request # 17 | Processing historical data message from TWS | 2015-05-17 17:58:02 HD Request # 17 | Received 2788 records and wrote 0 records from 2015-05-14 12:41:30 to 2015-05-15 19:59:30. | 2015-05-17 17:58:02 HD Request # 17 | Received 5659 records from 2015-05-15 19:50:00 to 2015-05-15 19:59:30 (9.5 minutes) and wrote 0 records for UWTI | 2015-05-17 17:58:03 HD Request # 17 | Intraday download COMPLETE for UWTI. Completion time: 3s. Unique request ID: 16 | 2015-05-17 17:58:03 Removed historical data download ID 16 | 2015-05-17 17:58:03 Real-time Intraday chart data file updates started for UWTI | 2015-05-17 17:58:03 HD Request # 18 | Downloading Intraday chart data for PFE to the file PFE.scid. Service: ib | 2015-05-17 17:58:03 HD Request # 18 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:58:03 HD Request # 18 | Requesting a total of 1 days and 83913 seconds. | 2015-05-17 17:58:03 HD Request # 18 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 83913. | 2015-05-17 17:58:03 HD Request # 18 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-05-16 19:49:30 for PFE | 2015-05-17 17:58:03 HD Request # 18 | Processing historical data message from TWS | 2015-05-17 17:58:04 HD Request # 18 | Receiving Intraday data for PFE starting at 2015-05-15 19:50:00 | 2015-05-17 17:58:04 HD Request # 18 | Received 2700 records and wrote 0 records from 2015-05-14 12:00:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:04 HD Request # 18 | IB Backfill - Seconds requested: 83913. Seconds Remaining: 0. | 2015-05-17 17:58:05 HD Request # 18 | Requesting 83913 Seconds of data at 30 secs with ending Date-Time at 2015-05-17 19:08:03 for PFE | 2015-05-17 17:58:05 HD Request # 18 | Processing historical data message from TWS | 2015-05-17 17:58:05 HD Request # 18 | Received 2618 records and wrote 0 records from 2015-05-14 12:41:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:05 HD Request # 18 | Received 5318 records from 2015-05-15 19:50:00 to 2015-05-15 19:59:30 (9.5 minutes) and wrote 0 records for PFE | 2015-05-17 17:58:06 HD Request # 18 | Intraday download COMPLETE for PFE. Completion time: 3s. Unique request ID: 17 | 2015-05-17 17:58:06 Removed historical data download ID 17 | 2015-05-17 17:58:06 Real-time Intraday chart data file updates started for PFE | 2015-05-17 17:58:06 HD Request # 19 | Downloading Intraday chart data for CMG to the file CMG.scid. Service: ib | 2015-05-17 17:58:06 HD Request # 19 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:58:06 HD Request # 19 | Requesting a total of 1 days and 83916 seconds. | 2015-05-17 17:58:06 HD Request # 19 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 83916. | 2015-05-17 17:58:06 HD Request # 19 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-05-16 19:49:30 for CMG | 2015-05-17 17:58:06 HD Request # 19 | Processing historical data message from TWS | 2015-05-17 17:58:07 HD Request # 19 | Receiving Intraday data for CMG starting at 2015-05-15 19:50:00 | 2015-05-17 17:58:07 HD Request # 19 | Received 2220 records and wrote 0 records from 2015-05-14 12:00:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:07 HD Request # 19 | IB Backfill - Seconds requested: 83916. Seconds Remaining: 0. | 2015-05-17 17:58:08 HD Request # 19 | Requesting 83916 Seconds of data at 30 secs with ending Date-Time at 2015-05-17 19:08:06 for CMG | 2015-05-17 17:58:08 HD Request # 19 | Processing historical data message from TWS | 2015-05-17 17:58:09 HD Request # 19 | Received 2138 records and wrote 0 records from 2015-05-14 12:41:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:09 HD Request # 19 | Received 4358 records from 2015-05-15 19:50:00 to 2015-05-15 19:59:30 (9.5 minutes) and wrote 0 records for CMG | 2015-05-17 17:58:10 HD Request # 19 | Intraday download COMPLETE for CMG. Completion time: 4s. Unique request ID: 18 | 2015-05-17 17:58:10 Removed historical data download ID 18 | 2015-05-17 17:58:10 Real-time Intraday chart data file updates started for CMG | 2015-05-17 17:58:10 HD Request # 20 | Downloading Intraday chart data for USO to the file USO.scid. Service: ib | 2015-05-17 17:58:10 HD Request # 20 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:58:10 HD Request # 20 | Requesting a total of 1 days and 83920 seconds. | 2015-05-17 17:58:10 HD Request # 20 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 83920. | 2015-05-17 17:58:10 HD Request # 20 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-05-16 19:49:30 for USO | 2015-05-17 17:58:10 HD Request # 20 | Processing historical data message from TWS | 2015-05-17 17:58:10 HD Request # 20 | Receiving Intraday data for USO starting at 2015-05-15 19:50:00 | 2015-05-17 17:58:10 HD Request # 20 | Received 2705 records and wrote 0 records from 2015-05-14 12:00:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:10 HD Request # 20 | IB Backfill - Seconds requested: 83920. Seconds Remaining: 0. | 2015-05-17 17:58:11 HD Request # 20 | Requesting 83920 Seconds of data at 30 secs with ending Date-Time at 2015-05-17 19:08:10 for USO | 2015-05-17 17:58:11 HD Request # 20 | Processing historical data message from TWS | 2015-05-17 17:58:12 HD Request # 20 | Received 2623 records and wrote 0 records from 2015-05-14 12:41:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:12 HD Request # 20 | Received 5328 records from 2015-05-15 19:50:00 to 2015-05-15 19:59:30 (9.5 minutes) and wrote 0 records for USO | 2015-05-17 17:58:13 HD Request # 20 | Intraday download COMPLETE for USO. Completion time: 3s. Unique request ID: 19 | 2015-05-17 17:58:13 Removed historical data download ID 19 | 2015-05-17 17:58:13 Real-time Intraday chart data file updates started for USO | 2015-05-17 17:58:13 HD Request # 21 | Downloading Intraday chart data for FSL to the file FSL.scid. Service: ib | 2015-05-17 17:58:13 HD Request # 21 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 17:58:13 HD Request # 21 | Requesting a total of 1 days and 83923 seconds. | 2015-05-17 17:58:13 HD Request # 21 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 83923. | 2015-05-17 17:58:13 HD Request # 21 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-05-16 19:49:30 for FSL | 2015-05-17 17:58:13 HD Request # 21 | Processing historical data message from TWS | 2015-05-17 17:58:13 HD Request # 21 | Receiving Intraday data for FSL starting at 2015-05-15 19:50:00 | 2015-05-17 17:58:13 HD Request # 21 | Received 2237 records and wrote 0 records from 2015-05-14 12:00:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:13 HD Request # 21 | IB Backfill - Seconds requested: 83923. Seconds Remaining: 0. | 2015-05-17 17:58:15 HD Request # 21 | Requesting 83923 Seconds of data at 30 secs with ending Date-Time at 2015-05-17 19:08:13 for FSL | 2015-05-17 17:58:15 HD Request # 21 | Processing historical data message from TWS | 2015-05-17 17:58:15 HD Request # 21 | Received 2155 records and wrote 0 records from 2015-05-14 12:41:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:15 HD Request # 21 | Received 4392 records from 2015-05-15 19:50:00 to 2015-05-15 19:59:30 (9.5 minutes) and wrote 0 records for FSL | 2015-05-17 17:58:16 HD Request # 21 | Intraday download COMPLETE for FSL. Completion time: 3s. Unique request ID: 20 | 2015-05-17 17:58:16 Removed historical data download ID 20 | 2015-05-17 17:58:16 Real-time Intraday chart data file updates started for FSL | 2015-05-17 17:58:16 HD Request # 22 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ib | 2015-05-17 17:58:16 HD Request # 22 | Download start Date-Time: 2015-05-15 19:59:50.0 | 2015-05-17 17:58:16 HD Request # 22 | Requesting a total of 1 days and 83906 seconds. | 2015-05-17 17:58:16 HD Request # 22 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 83906. | 2015-05-17 17:58:16 HD Request # 22 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-05-16 19:49:50 for AAPL | 2015-05-17 17:58:16 HD Request # 22 | Processing historical data message from TWS | 2015-05-17 17:58:17 HD Request # 22 | Receiving Intraday data for AAPL starting at 2015-05-15 19:50:00 | 2015-05-17 17:58:17 HD Request # 22 | Received 2880 records and wrote 0 records from 2015-05-14 12:00:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:17 HD Request # 22 | IB Backfill - Seconds requested: 83906. Seconds Remaining: 0. | 2015-05-17 17:58:18 HD Request # 22 | Requesting 83906 Seconds of data at 30 secs with ending Date-Time at 2015-05-17 19:08:16 for AAPL | 2015-05-17 17:58:18 HD Request # 22 | Processing historical data message from TWS | 2015-05-17 17:58:18 HD Request # 22 | Received 2797 records and wrote 0 records from 2015-05-14 12:41:30 to 2015-05-15 19:59:30. | 2015-05-17 17:58:18 HD Request # 22 | Received 5677 records from 2015-05-15 19:50:00 to 2015-05-15 19:59:30 (9.5 minutes) and wrote 0 records for AAPL | 2015-05-17 17:58:19 HD Request # 22 | Intraday download COMPLETE for AAPL. Completion time: 3s. Unique request ID: 21 | 2015-05-17 17:58:19 Removed historical data download ID 21 | 2015-05-17 17:58:19 Real-time Intraday chart data file updates started for AAPL | 2015-05-17 17:58:19 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 17:58:29 Reloading all charts with filename: AAPL.scid | 2015-05-17 17:58:29 HD Request # 23 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: equities.us | 2015-05-17 17:58:29 HD Request # 23 | Download start Date-Time: 2015-01-17 16:58:29.0 | 2015-05-17 17:58:29 HD Request # 23 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 17:58:29 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 17:58:29 Socket (15) | Connected. | 2015-05-17 17:58:29 HD Request # 23 | Sending historical data logon request message. | 2015-05-17 17:58:29 HD Request # 23 | Requesting Intraday data. Start Date-Time: 2015-01-17 16:58:29. Record interval: 1. Symbol: AAPL | 2015-05-17 17:58:29 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\AAPL.scid | 2015-05-17 17:58:29 HD Request # 23 | Decompressing data. | 2015-05-17 17:58:29 HD Request # 23 | Receiving Intraday data for AAPL starting at 2015-01-20 07:29:48 | 2015-05-17 17:58:29 HD Request # 23 | Timestamp of first Intraday data file record written: 2015-01-20 07:29:48 | 2015-05-17 17:58:29 Socket (15) | Shutdown and closed. | 2015-05-17 17:58:41 The network socket for historical data has been closed. | 2015-05-17 17:58:41 HD Request # 23 | Received 1487805 records from 2015-01-20 07:29:48 to 2015-05-15 19:59:50 (115.5 days) and wrote 1487805 records for AAPL | 2015-05-17 17:58:41 HD Request # 23 | Intraday download COMPLETE for AAPL. Completion time: 12s. Unique request ID: 22 | 2015-05-17 17:58:41 Removed historical data download ID 22 | 2015-05-17 17:58:41 Real-time Intraday chart data file updates started for AAPL | 2015-05-17 17:58:41 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 17:58:41 HD Request # 24 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ib | 2015-05-17 17:58:41 HD Request # 24 | Download start Date-Time: 2015-05-15 19:59:50.0 | 2015-05-17 17:58:41 HD Request # 24 | Requesting a total of 1 days and 83931 seconds. | 2015-05-17 17:58:41 HD Request # 24 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 83931. | 2015-05-17 17:58:41 HD Request # 24 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-05-16 19:49:50 for AAPL | 2015-05-17 17:58:41 HD Request # 24 | Processing historical data message from TWS | 2015-05-17 17:58:42 HD Request # 24 | Receiving Intraday data for AAPL starting at 2015-05-15 19:50:00 | 2015-05-17 17:58:42 HD Request # 24 | Received 2880 records and wrote 0 records from 2015-05-14 12:00:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:42 HD Request # 24 | IB Backfill - Seconds requested: 83931. Seconds Remaining: 0. | 2015-05-17 17:58:43 HD Request # 24 | Requesting 83931 Seconds of data at 30 secs with ending Date-Time at 2015-05-17 19:08:41 for AAPL | 2015-05-17 17:58:43 HD Request # 24 | Processing historical data message from TWS | 2015-05-17 17:58:43 HD Request # 24 | Received 2798 records and wrote 0 records from 2015-05-14 12:41:00 to 2015-05-15 19:59:30. | 2015-05-17 17:58:43 HD Request # 24 | Received 5678 records from 2015-05-15 19:50:00 to 2015-05-15 19:59:30 (9.5 minutes) and wrote 0 records for AAPL | 2015-05-17 17:58:44 HD Request # 24 | Intraday download COMPLETE for AAPL. Completion time: 3s. Unique request ID: 23 | 2015-05-17 17:58:44 Removed historical data download ID 23 | 2015-05-17 17:58:44 Real-time Intraday chart data file updates started for AAPL | 2015-05-17 17:58:44 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM15-$INX.scid | 2015-05-17 18:05:23 Interactive Brokers | Starting real-time market data updates for: ESM15-$INX. ID: 32 | 2015-05-17 18:05:23 Interactive Brokers | Subscribing to Symbol: ESM15, SecType: $INX, Expiry: , Exchange: SMART, Currency: , Multiplier: | 2015-05-17 18:05:23 Intraday data recording state for symbol ESM15-$INX is set to download pending. | 2015-05-17 18:05:23 Message from IB: Error validating request:-'zd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 32. Symbol: ESM15-$INX. | 2015-05-17 18:05:23 Message from IB: Error validating request:-'wd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 32. Symbol: ESM15-$INX. | 2015-05-17 18:05:23 HD Request # 25 | Downloading Intraday chart data for ESM15-$INX to the file ESM15-$INX.scid. Service: ib | 2015-05-17 18:05:23 Compressing file: C:\SierraChart\Data\ESM15-$INX.scid. This may take a while. | 2015-05-17 18:05:23 HD Request # 25 | Download start Date-Time: 2015-01-17 17:05:23.0 | 2015-05-17 18:05:23 HD Request # 25 | Requesting a total of 120 days and 4800 seconds. | 2015-05-17 18:05:23 HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 10286400. | 2015-05-17 18:05:23 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-18 16:55:23 for ESM15-$INX | 2015-05-17 18:05:23 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 33. | 2015-05-17 18:05:23 Unsubscribed from market depth data for AAPL | 2015-05-17 18:05:25 Requesting market depth updates for: ESM15-$INX if supported. | 2015-05-17 18:05:25 Message from IB: Error validating request:-'ae' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 100032. | 2015-05-17 18:05:25 HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 10200000. | 2015-05-17 18:05:30 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-19 16:55:23 for ESM15-$INX | 2015-05-17 18:05:30 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 34. | 2015-05-17 18:05:30 HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 10113600. | 2015-05-17 18:05:37 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-20 16:55:23 for ESM15-$INX | 2015-05-17 18:05:37 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 35. | 2015-05-17 18:05:37 HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 10027200. | 2015-05-17 18:05:44 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-21 16:55:23 for ESM15-$INX | 2015-05-17 18:05:44 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 36. | 2015-05-17 18:05:44 Unsubscribed from market depth data for ESM15-$INX | 2015-05-17 18:05:45 Requesting market depth updates for: AAPL if supported. | 2015-05-17 18:05:45 Message from IB: Can't find the subscribed market depth with tickerId:100032. IB Error Code: 310. Request ID: 100032. | 2015-05-17 18:05:45 Message from IB: Deep market data is not supported for this combination of security type/exchange. IB Error Code: 10092. Request ID: 100009. | 2015-05-17 18:05:45 HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 9940800. | 2015-05-17 18:05:51 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-22 16:55:23 for ESM15-$INX | 2015-05-17 18:05:51 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 37. | 2015-05-17 18:05:51 HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 9854400. | 2015-05-17 18:05:58 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-23 16:55:23 for ESM15-$INX | 2015-05-17 18:05:58 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 38. | 2015-05-17 18:05:58 HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 9768000. | 2015-05-17 18:06:05 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-24 16:55:23 for ESM15-$INX | 2015-05-17 18:06:05 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 39. | 2015-05-17 18:06:05 HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 9681600. | 2015-05-17 18:06:12 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-25 16:55:23 for ESM15-$INX | 2015-05-17 18:06:12 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 40. | 2015-05-17 18:06:12 ! You need to first disconnect from the data feed with File >> Disconnect before you can perform a loaded bar back test. | 2015-05-17 18:06:17 * HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 9595200. | 2015-05-17 18:06:19 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-26 16:55:23 for ESM15-$INX | 2015-05-17 18:06:19 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 41. | 2015-05-17 18:06:19 HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 9508800. | 2015-05-17 18:06:26 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-27 16:55:23 for ESM15-$INX | 2015-05-17 18:06:26 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 42. | 2015-05-17 18:06:26 HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 9422400. | 2015-05-17 18:06:33 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-28 16:55:23 for ESM15-$INX | 2015-05-17 18:06:33 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 43. | 2015-05-17 18:06:33 HD Request # 25 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 9336000. | 2015-05-17 18:06:40 HD Request # 25 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-29 16:55:23 for ESM15-$INX | 2015-05-17 18:06:40 HD Request # 25 | Message from IB: Error validating request:-'yd' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 44. | 2015-05-17 18:06:40 Socket (2) | Closed. No error. | 2015-05-17 18:06:43 Socket (2) | Shutdown and closed. | 2015-05-17 18:06:43 Connection to the external service has been lost. | 2015-05-17 18:06:43 HD Request # 25 | Download canceled. | 2015-05-17 18:06:43 HD Request # 25 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM15-$INX | 2015-05-17 18:06:43 HD Request # 25 | Intraday download COMPLETE for ESM15-$INX. Completion time: 1m 20s. Unique request ID: 24 | 2015-05-17 18:06:43 Removed historical data download ID 24 | 2015-05-17 18:06:43 Disconnected from IB. | 2015-05-17 18:06:43 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:06:43 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:06:48 Starting TWS auto-login thread. | 2015-05-17 18:06:48 TWS auto-login thread ending. | 2015-05-17 18:06:48 Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:06:49 Socket (16) | Shutdown and closed. | 2015-05-17 18:06:49 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:06:49 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:06:49 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:06:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:06:49 Disconnected from IB. | 2015-05-17 18:06:49 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:06:49 Starting TWS auto-login thread. | 2015-05-17 18:06:52 TWS auto-login thread ending. | 2015-05-17 18:06:52 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 18:06:52 Reloading all charts with filename: AAPL.scid | 2015-05-17 18:06:52 HD Request # 26 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: equities.us | 2015-05-17 18:06:52 HD Request # 26 | Download start Date-Time: 2015-01-17 17:06:52.0 | 2015-05-17 18:06:52 HD Request # 26 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 18:06:52 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 18:06:52 Socket (17) | Connected. | 2015-05-17 18:06:52 HD Request # 26 | Sending historical data logon request message. | 2015-05-17 18:06:52 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\AAPL.scid | 2015-05-17 18:06:52 HD Request # 26 | Requesting Intraday data. Start Date-Time: 2015-01-17 17:06:52. Record interval: 1. Symbol: AAPL | 2015-05-17 18:06:52 HD Request # 26 | Decompressing data. | 2015-05-17 18:06:52 HD Request # 26 | Receiving Intraday data for AAPL starting at 2015-01-20 07:29:48 | 2015-05-17 18:06:52 HD Request # 26 | Timestamp of first Intraday data file record written: 2015-01-20 07:29:48 | 2015-05-17 18:06:52 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:06:54 Socket (18) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:06:55 Socket (18) | Shutdown and closed. | 2015-05-17 18:06:55 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:06:55 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:06:55 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:06:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:06:55 Disconnected from IB. | 2015-05-17 18:06:55 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:06:55 Starting TWS auto-login thread. | 2015-05-17 18:06:56 TWS auto-login thread ending. | 2015-05-17 18:06:56 Starting TWS auto-login thread. | 2015-05-17 18:07:00 TWS auto-login thread ending. | 2015-05-17 18:07:00 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:07:00 Socket (19) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:07:01 Socket (19) | Shutdown and closed. | 2015-05-17 18:07:01 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:07:01 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:07:01 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:07:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:07:01 Disconnected from IB. | 2015-05-17 18:07:01 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:07:01 HD Request # 26 | Historical data for AAPL is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-05-17 18:07:01 Socket (17) | Shutdown and closed. | 2015-05-17 18:07:01 The network socket for historical data has been closed. | 2015-05-17 18:07:01 HD Request # 26 | Received 1487762 records from 2015-01-20 07:29:48 to 2015-05-15 19:59:50 (115.5 days) and wrote 1487749 records for AAPL | 2015-05-17 18:07:01 HD Request # 26 | Intraday download COMPLETE for AAPL. Completion time: 9s. Unique request ID: 25 | 2015-05-17 18:07:01 Removed historical data download ID 25 | 2015-05-17 18:07:01 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 18:07:01 Starting TWS auto-login thread. | 2015-05-17 18:07:04 TWS auto-login thread ending. | 2015-05-17 18:07:04 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:07:06 Socket (20) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:07:07 Socket (20) | Shutdown and closed. | 2015-05-17 18:07:07 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:07:07 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:07:07 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:07:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:07:07 Removed historical data download ID 26 | 2015-05-17 18:07:07 Disconnected from IB. | 2015-05-17 18:07:07 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:07:07 Starting TWS auto-login thread. | 2015-05-17 18:07:08 TWS auto-login thread ending. | 2015-05-17 18:07:08 Starting TWS auto-login thread. | 2015-05-17 18:07:12 TWS auto-login thread ending. | 2015-05-17 18:07:12 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:07:12 Socket (21) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:07:13 Socket (21) | Shutdown and closed. | 2015-05-17 18:07:13 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:07:13 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:07:13 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:07:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:07:13 Disconnected from IB. | 2015-05-17 18:07:13 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:07:13 Starting TWS auto-login thread. | 2015-05-17 18:07:17 TWS auto-login thread ending. | 2015-05-17 18:07:17 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:07:18 Socket (22) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:07:19 Socket (22) | Shutdown and closed. | 2015-05-17 18:07:19 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:07:19 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:07:19 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:07:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:07:19 Disconnected from IB. | 2015-05-17 18:07:19 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:07:19 Starting TWS auto-login thread. | 2015-05-17 18:07:20 TWS auto-login thread ending. | 2015-05-17 18:07:20 Starting TWS auto-login thread. | 2015-05-17 18:07:24 TWS auto-login thread ending. | 2015-05-17 18:07:24 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:07:24 Socket (23) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:07:25 Socket (23) | Shutdown and closed. | 2015-05-17 18:07:25 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:07:25 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:07:25 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:07:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:07:25 Disconnected from IB. | 2015-05-17 18:07:25 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:07:25 Starting TWS auto-login thread. | 2015-05-17 18:07:28 TWS auto-login thread ending. | 2015-05-17 18:07:28 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:07:30 Socket (24) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:07:32 Socket (24) | Shutdown and closed. | 2015-05-17 18:07:32 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:07:32 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:07:32 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:07:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:07:32 Disconnected from IB. | 2015-05-17 18:07:32 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:07:32 Starting TWS auto-login thread. | 2015-05-17 18:07:32 TWS auto-login thread ending. | 2015-05-17 18:07:32 Starting TWS auto-login thread. | 2015-05-17 18:07:36 TWS auto-login thread ending. | 2015-05-17 18:07:36 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:07:37 Socket (25) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:07:38 Socket (25) | Shutdown and closed. | 2015-05-17 18:07:38 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:07:38 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:07:38 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:07:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:07:38 Disconnected from IB. | 2015-05-17 18:07:38 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:07:38 Starting TWS auto-login thread. | 2015-05-17 18:07:40 TWS auto-login thread ending. | 2015-05-17 18:07:40 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:07:43 Socket (26) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:07:44 Socket (26) | Shutdown and closed. | 2015-05-17 18:07:44 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:07:44 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:07:44 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:07:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:07:44 Disconnected from IB. | 2015-05-17 18:07:44 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:07:44 Starting TWS auto-login thread. | 2015-05-17 18:07:44 TWS auto-login thread ending. | 2015-05-17 18:07:44 Starting TWS auto-login thread. | 2015-05-17 18:07:48 TWS auto-login thread ending. | 2015-05-17 18:07:48 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:07:48 Socket (27) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:07:49 Socket (27) | Shutdown and closed. | 2015-05-17 18:07:49 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:07:49 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:07:49 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:07:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:07:49 Disconnected from IB. | 2015-05-17 18:07:49 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:07:49 Starting TWS auto-login thread. | 2015-05-17 18:07:52 TWS auto-login thread ending. | 2015-05-17 18:07:52 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:07:54 Socket (28) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:07:55 Socket (28) | Shutdown and closed. | 2015-05-17 18:07:55 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:07:55 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:07:55 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:07:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:07:55 Disconnected from IB. | 2015-05-17 18:07:55 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:07:55 Starting TWS auto-login thread. | 2015-05-17 18:07:56 TWS auto-login thread ending. | 2015-05-17 18:07:56 Starting TWS auto-login thread. | 2015-05-17 18:08:00 TWS auto-login thread ending. | 2015-05-17 18:08:00 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-17 18:08:00 Socket (29) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-05-17 18:08:01 Socket (29) | Shutdown and closed. | 2015-05-17 18:08:01 Interactive Brokers | Failed to connect to the data and trade server. | 2015-05-17 18:08:01 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-05-17 18:08:01 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-17 18:08:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-17 18:08:01 Disconnected from IB. | 2015-05-17 18:08:01 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-17 18:08:01 Starting TWS auto-login thread. | 2015-05-17 18:08:04 TWS auto-login thread ending. | 2015-05-17 18:08:04 Current selected Data/Trading service: SC Market Stats | 2015-05-17 18:08:06 Checking for new symbol settings for scms | 2015-05-17 18:08:06 Socket (4) | Shutdown and closed. | 2015-05-17 18:08:06 SC Exchange Data | Disconnected from the server. | 2015-05-17 18:08:06 Disconnected from IB. | 2015-05-17 18:08:06 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-05-17 18:08:06 HTTP connection to www.sierrachart.com:80 (30) | Connected. | 2015-05-17 18:08:06 Requesting symbol settings for scms. Overwrite = on. | 2015-05-17 18:08:07 Symbol settings received. | 2015-05-17 18:08:08 Processed received symbol settings | 2015-05-17 18:08:08 SC Market Stats | Connecting to the server ds5.sierracharts.com. Port 443 | 2015-05-17 18:08:09 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-05-17 18:08:09 Socket (31) | Connected. | 2015-05-17 18:08:09 SC Market Stats | Connected to server. | 2015-05-17 18:08:09 SC Market Stats | Sending logon request message. | 2015-05-17 18:08:09 SC Market Stats | Server Name: SC Real-Time Server. | 2015-05-17 18:08:10 SC Market Stats | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-05-17 18:08:10 SC Market Stats | Successfully connected. | 2015-05-17 18:08:10 NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2015-05-17 18:08:10 SC Market Stats | Starting real-time market data updates for: AAPL. ID: 1 | 2015-05-17 18:08:10 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 18:08:10 HD Request # 27 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: scms | 2015-05-17 18:08:10 HD Request # 27 | Download start Date-Time: 2015-05-15 19:59:50.0 | 2015-05-17 18:08:10 HD Request # 27 | Using server: ds4.sierracharts.com port 10149 | 2015-05-17 18:08:10 SC Market Stats | Starting real-time market data updates for: IBB. ID: 2 | 2015-05-17 18:08:10 Intraday data recording state for symbol IBB is set to download pending. | 2015-05-17 18:08:10 SC Market Stats | Starting real-time market data updates for: CMG. ID: 3 | 2015-05-17 18:08:10 Intraday data recording state for symbol CMG is set to download pending. | 2015-05-17 18:08:10 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-05-17 18:08:10 SC Market Stats | Starting real-time market data updates for: SMH. ID: 4 | 2015-05-17 18:08:10 Intraday data recording state for symbol SMH is set to download pending. | 2015-05-17 18:08:10 Symbol Error - AAPL is unknown, unavailable, or improperly formatted. Data source not specified. | 2015-05-17 18:08:10 Symbol Error - IBB is unknown, unavailable, or improperly formatted. Data source not specified. | 2015-05-17 18:08:10 Symbol Error - CMG is unknown, unavailable, or improperly formatted. Data source not specified. | 2015-05-17 18:08:10 Socket (32) | Connected. | 2015-05-17 18:08:10 HD Request # 27 | Sending historical data logon request message. | 2015-05-17 18:08:10 SC Market Stats | Starting real-time market data updates for: ESPR. ID: 5 | 2015-05-17 18:08:10 Intraday data recording state for symbol ESPR is set to download pending. | 2015-05-17 18:08:10 Symbol Error - SMH is unknown, unavailable, or improperly formatted. Data source not specified. | 2015-05-17 18:08:10 SC Market Stats | Starting real-time market data updates for: UWTI. ID: 6 | 2015-05-17 18:08:10 Intraday data recording state for symbol UWTI is set to download pending. | 2015-05-17 18:08:10 SC Market Stats | Starting real-time market data updates for: PFE. ID: 7 | 2015-05-17 18:08:10 Intraday data recording state for symbol PFE is set to download pending. | 2015-05-17 18:08:10 SC Market Stats | Starting real-time market data updates for: USO. ID: 8 | 2015-05-17 18:08:10 Intraday data recording state for symbol USO is set to download pending. | 2015-05-17 18:08:10 SC Market Stats | Starting real-time market data updates for: FSL. ID: 9 | 2015-05-17 18:08:10 Intraday data recording state for symbol FSL is set to download pending. | 2015-05-17 18:08:10 SC Market Stats | Starting real-time market data updates for: ES-201506-GLOBEX. ID: 10 | 2015-05-17 18:08:10 Intraday data recording state for symbol ES-201506-GLOBEX is set to download pending. | 2015-05-17 18:08:10 Socket (32) | Shutdown and closed. | 2015-05-17 18:08:10 The network socket for historical data has been closed. | 2015-05-17 18:08:10 Symbol Error - ESPR is unknown, unavailable, or improperly formatted. Data source not specified. | 2015-05-17 18:08:10 HD Request # 27 | Error downloading historical Intraday data for AAPL. Historical data logon error: Invalid/missing data for service code: scms | 2015-05-17 18:08:10 * HD Request # 27 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AAPL | 2015-05-17 18:08:10 HD Request # 27 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 27 | 2015-05-17 18:08:10 Removed historical data download ID 27 | 2015-05-17 18:08:10 Real-time Intraday chart data file updates started for AAPL | 2015-05-17 18:08:10 HD Request # 28 | Downloading Intraday chart data for IBB to the file IBB.scid. Service: scms | 2015-05-17 18:08:10 HD Request # 28 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:08:10 Symbol Error - UWTI is unknown, unavailable, or improperly formatted. Data source not specified. | 2015-05-17 18:08:10 HD Request # 28 | Using server: ds3.sierracharts.com port 10149 | 2015-05-17 18:08:10 SC Market Stats | Starting real-time market data updates for: NQ-201506-GLOBEX. ID: 11 | 2015-05-17 18:08:10 Intraday data recording state for symbol NQ-201506-GLOBEX is set to download pending. | 2015-05-17 18:08:10 Symbol Error - PFE is unknown, unavailable, or improperly formatted. Data source not specified. | 2015-05-17 18:08:10 Symbol Error - USO is unknown, unavailable, or improperly formatted. Data source not specified. | 2015-05-17 18:08:10 Symbol Error - FSL is unknown, unavailable, or improperly formatted. Data source not specified. | 2015-05-17 18:08:10 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-05-17 18:08:10 Symbol Error - ES-201506-GLOBEX is unknown, unavailable, or improperly formatted. Data source not specified. | 2015-05-17 18:08:10 Symbol Error - NQ-201506-GLOBEX is unknown, unavailable, or improperly formatted. Data source not specified. | 2015-05-17 18:08:10 Socket (33) | Connected. | 2015-05-17 18:08:10 HD Request # 28 | Sending historical data logon request message. | 2015-05-17 18:08:10 HD Request # 28 | Error downloading historical Intraday data for IBB. Historical data logon error: Invalid/missing data for service code: scms | 2015-05-17 18:08:10 * Socket (33) | Shutdown and closed. | 2015-05-17 18:08:10 The network socket for historical data has been closed. | 2015-05-17 18:08:10 HD Request # 28 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for IBB | 2015-05-17 18:08:10 HD Request # 28 | Intraday download COMPLETE for IBB. Completion time: 0s. Unique request ID: 28 | 2015-05-17 18:08:10 Removed historical data download ID 28 | 2015-05-17 18:08:10 Real-time Intraday chart data file updates started for IBB | 2015-05-17 18:08:10 HD Request # 29 | Downloading Intraday chart data for CMG to the file CMG.scid. Service: scms | 2015-05-17 18:08:10 HD Request # 29 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:08:10 HD Request # 29 | Using server: ds5.sierracharts.com port 10149 | 2015-05-17 18:08:10 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-05-17 18:08:10 Socket (34) | Connected. | 2015-05-17 18:08:11 HD Request # 29 | Sending historical data logon request message. | 2015-05-17 18:08:11 HD Request # 29 | Error downloading historical Intraday data for CMG. Historical data logon error: Invalid/missing data for service code: scms | 2015-05-17 18:08:11 * Socket (34) | Shutdown and closed. | 2015-05-17 18:08:11 The network socket for historical data has been closed. | 2015-05-17 18:08:11 HD Request # 29 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CMG | 2015-05-17 18:08:11 HD Request # 29 | Intraday download COMPLETE for CMG. Completion time: 1s. Unique request ID: 29 | 2015-05-17 18:08:11 Removed historical data download ID 29 | 2015-05-17 18:08:11 Real-time Intraday chart data file updates started for CMG | 2015-05-17 18:08:11 HD Request # 30 | Downloading Intraday chart data for SMH to the file SMH.scid. Service: scms | 2015-05-17 18:08:11 HD Request # 30 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:08:11 HD Request # 30 | Using server: ds4.sierracharts.com port 10149 | 2015-05-17 18:08:11 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-05-17 18:08:11 Socket (35) | Connected. | 2015-05-17 18:08:11 HD Request # 30 | Sending historical data logon request message. | 2015-05-17 18:08:11 HD Request # 30 | Error downloading historical Intraday data for SMH. Historical data logon error: Invalid/missing data for service code: scms | 2015-05-17 18:08:11 * Socket (35) | Shutdown and closed. | 2015-05-17 18:08:11 The network socket for historical data has been closed. | 2015-05-17 18:08:11 HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SMH | 2015-05-17 18:08:11 HD Request # 30 | Intraday download COMPLETE for SMH. Completion time: 0s. Unique request ID: 30 | 2015-05-17 18:08:11 Removed historical data download ID 30 | 2015-05-17 18:08:11 Real-time Intraday chart data file updates started for SMH | 2015-05-17 18:08:11 HD Request # 31 | Downloading Intraday chart data for ESPR to the file ESPR.scid. Service: scms | 2015-05-17 18:08:11 HD Request # 31 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:08:11 HD Request # 31 | Using server: ds3.sierracharts.com port 10149 | 2015-05-17 18:08:11 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-05-17 18:08:11 Socket (36) | Connected. | 2015-05-17 18:08:11 HD Request # 31 | Sending historical data logon request message. | 2015-05-17 18:08:11 Socket (36) | Shutdown and closed. | 2015-05-17 18:08:11 The network socket for historical data has been closed. | 2015-05-17 18:08:11 HD Request # 31 | Error downloading historical Intraday data for ESPR. Historical data logon error: Invalid/missing data for service code: scms | 2015-05-17 18:08:11 * HD Request # 31 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESPR | 2015-05-17 18:08:11 HD Request # 31 | Intraday download COMPLETE for ESPR. Completion time: 0s. Unique request ID: 31 | 2015-05-17 18:08:11 Removed historical data download ID 31 | 2015-05-17 18:08:11 Real-time Intraday chart data file updates started for ESPR | 2015-05-17 18:08:11 HD Request # 32 | Downloading Intraday chart data for UWTI to the file UWTI.scid. Service: scms | 2015-05-17 18:08:11 HD Request # 32 | Download start Date-Time: 2015-05-15 19:59:56.0 | 2015-05-17 18:08:11 HD Request # 32 | Using server: ds5.sierracharts.com port 10149 | 2015-05-17 18:08:11 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-05-17 18:08:11 Socket (37) | Connected. | 2015-05-17 18:08:11 HD Request # 32 | Sending historical data logon request message. | 2015-05-17 18:08:11 HD Request # 32 | Error downloading historical Intraday data for UWTI. Historical data logon error: Invalid/missing data for service code: scms | 2015-05-17 18:08:11 * Socket (37) | Shutdown and closed. | 2015-05-17 18:08:11 The network socket for historical data has been closed. | 2015-05-17 18:08:11 HD Request # 32 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for UWTI | 2015-05-17 18:08:11 HD Request # 32 | Intraday download COMPLETE for UWTI. Completion time: 0s. Unique request ID: 32 | 2015-05-17 18:08:11 Removed historical data download ID 32 | 2015-05-17 18:08:11 Real-time Intraday chart data file updates started for UWTI | 2015-05-17 18:08:11 HD Request # 33 | Downloading Intraday chart data for PFE to the file PFE.scid. Service: scms | 2015-05-17 18:08:11 HD Request # 33 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:08:11 HD Request # 33 | Using server: ds4.sierracharts.com port 10149 | 2015-05-17 18:08:11 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-05-17 18:08:11 Socket (38) | Connected. | 2015-05-17 18:08:11 HD Request # 33 | Sending historical data logon request message. | 2015-05-17 18:08:11 HD Request # 33 | Error downloading historical Intraday data for PFE. Historical data logon error: Invalid/missing data for service code: scms | 2015-05-17 18:08:11 * Socket (38) | Shutdown and closed. | 2015-05-17 18:08:11 The network socket for historical data has been closed. | 2015-05-17 18:08:11 HD Request # 33 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for PFE | 2015-05-17 18:08:11 HD Request # 33 | Intraday download COMPLETE for PFE. Completion time: 0s. Unique request ID: 33 | 2015-05-17 18:08:11 Removed historical data download ID 33 | 2015-05-17 18:08:11 Real-time Intraday chart data file updates started for PFE | 2015-05-17 18:08:11 HD Request # 34 | Downloading Intraday chart data for USO to the file USO.scid. Service: scms | 2015-05-17 18:08:11 HD Request # 34 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:08:11 HD Request # 34 | Using server: ds3.sierracharts.com port 10149 | 2015-05-17 18:08:11 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-05-17 18:08:11 Socket (39) | Connected. | 2015-05-17 18:08:11 HD Request # 34 | Sending historical data logon request message. | 2015-05-17 18:08:11 Socket (39) | Shutdown and closed. | 2015-05-17 18:08:12 The network socket for historical data has been closed. | 2015-05-17 18:08:12 HD Request # 34 | Error downloading historical Intraday data for USO. Historical data logon error: Invalid/missing data for service code: scms | 2015-05-17 18:08:12 * HD Request # 34 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USO | 2015-05-17 18:08:12 HD Request # 34 | Intraday download COMPLETE for USO. Completion time: 0s. Unique request ID: 34 | 2015-05-17 18:08:12 Removed historical data download ID 34 | 2015-05-17 18:08:12 Real-time Intraday chart data file updates started for USO | 2015-05-17 18:08:12 HD Request # 35 | Downloading Intraday chart data for FSL to the file FSL.scid. Service: scms | 2015-05-17 18:08:12 HD Request # 35 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:08:12 HD Request # 35 | Using server: ds5.sierracharts.com port 10149 | 2015-05-17 18:08:12 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-05-17 18:08:12 Socket (40) | Connected. | 2015-05-17 18:08:12 HD Request # 35 | Sending historical data logon request message. | 2015-05-17 18:08:12 Socket (40) | Shutdown and closed. | 2015-05-17 18:08:12 The network socket for historical data has been closed. | 2015-05-17 18:08:12 HD Request # 35 | Error downloading historical Intraday data for FSL. Historical data logon error: Invalid/missing data for service code: scms | 2015-05-17 18:08:12 * HD Request # 35 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FSL | 2015-05-17 18:08:12 HD Request # 35 | Intraday download COMPLETE for FSL. Completion time: 0s. Unique request ID: 35 | 2015-05-17 18:08:12 Removed historical data download ID 35 | 2015-05-17 18:08:12 Real-time Intraday chart data file updates started for FSL | 2015-05-17 18:08:12 HD Request # 36 | Downloading Intraday chart data for ES-201506-GLOBEX to the file ES-201506-GLOBEX.scid. Service: scms | 2015-05-17 18:08:12 HD Request # 36 | Download start Date-Time: 2015-05-17 18:08:03.0 | 2015-05-17 18:08:12 HD Request # 36 | Using server: ds4.sierracharts.com port 10149 | 2015-05-17 18:08:12 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-05-17 18:08:12 Socket (41) | Connected. | 2015-05-17 18:08:12 HD Request # 36 | Sending historical data logon request message. | 2015-05-17 18:08:12 HD Request # 36 | Error downloading historical Intraday data for ES-201506-GLOBEX. Historical data logon error: Invalid/missing data for service code: scms | 2015-05-17 18:08:12 * Socket (41) | Shutdown and closed. | 2015-05-17 18:08:12 The network socket for historical data has been closed. | 2015-05-17 18:08:12 HD Request # 36 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201506-GLOBEX | 2015-05-17 18:08:12 HD Request # 36 | Intraday download COMPLETE for ES-201506-GLOBEX. Completion time: 0s. Unique request ID: 36 | 2015-05-17 18:08:12 Removed historical data download ID 36 | 2015-05-17 18:08:12 Real-time Intraday chart data file updates started for ES-201506-GLOBEX | 2015-05-17 18:08:12 HD Request # 37 | Downloading Intraday chart data for NQ-201506-GLOBEX to the file NQ-201506-GLOBEX.scid. Service: scms | 2015-05-17 18:08:12 HD Request # 37 | Download start Date-Time: 2015-05-17 18:07:58.0 | 2015-05-17 18:08:12 HD Request # 37 | Using server: ds3.sierracharts.com port 10149 | 2015-05-17 18:08:12 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-05-17 18:08:12 Socket (42) | Connected. | 2015-05-17 18:08:12 HD Request # 37 | Sending historical data logon request message. | 2015-05-17 18:08:12 HD Request # 37 | Error downloading historical Intraday data for NQ-201506-GLOBEX. Historical data logon error: Invalid/missing data for service code: scms | 2015-05-17 18:08:12 * Socket (42) | Shutdown and closed. | 2015-05-17 18:08:12 The network socket for historical data has been closed. | 2015-05-17 18:08:12 HD Request # 37 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201506-GLOBEX | 2015-05-17 18:08:12 HD Request # 37 | Intraday download COMPLETE for NQ-201506-GLOBEX. Completion time: 0s. Unique request ID: 37 | 2015-05-17 18:08:12 Removed historical data download ID 37 | 2015-05-17 18:08:12 Real-time Intraday chart data file updates started for NQ-201506-GLOBEX | 2015-05-17 18:08:12 HTTP connection to www.sierrachart.com:80 (30) | Closed. No error. | 2015-05-17 18:08:13 HTTP connection to www.sierrachart.com:80 (30) | Shutdown and closed. | 2015-05-17 18:08:13 Requesting market depth updates for: AAPL if supported. | 2015-05-17 18:08:15 Requesting market depth updates for: CMG if supported. | 2015-05-17 18:08:15 Requesting market depth updates for: IBB if supported. | 2015-05-17 18:08:15 Requesting market depth updates for: SMH if supported. | 2015-05-17 18:08:15 Market Depth data has been rejected for symbol: AAPL. Request contained no data source. | 2015-05-17 18:08:15 Market Depth data has been rejected for symbol: CMG. Request contained no data source. | 2015-05-17 18:08:15 Market Depth data has been rejected for symbol: IBB. Request contained no data source. | 2015-05-17 18:08:15 Market Depth data has been rejected for symbol: SMH. Request contained no data source. | 2015-05-17 18:08:15 Current selected Data/Trading service: SC Exchange Data | 2015-05-17 18:09:07 Checking for new symbol settings for scbcd | 2015-05-17 18:09:07 Socket (31) | Shutdown and closed. | 2015-05-17 18:09:07 SC Market Stats | Disconnected from the server. | 2015-05-17 18:09:07 NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2015-05-17 18:09:07 SC Exchange Data | Connected. | 2015-05-17 18:09:07 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-05-17 18:09:07 HTTP connection to www.sierrachart.com:80 (43) | Connected. | 2015-05-17 18:09:07 Mapping AAPL to AAPL. Service code: equities.us | 2015-05-17 18:09:07 SC Exchange Data | Starting real-time market data updates for: AAPL. ID: 1 | 2015-05-17 18:09:07 Using username 0 | 2015-05-17 18:09:07 SC Exchange Data | Connecting to the server scdf1.sierracharts.com. Port 10047 | 2015-05-17 18:09:07 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 18:09:07 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 18:09:07 HD Request # 38 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: equities.us | 2015-05-17 18:09:07 HD Request # 38 | Download start Date-Time: 2015-05-15 19:59:50.0 | 2015-05-17 18:09:07 HD Request # 38 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 18:09:07 Mapping IBB to IBB. Service code: equities.us | 2015-05-17 18:09:07 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 18:09:07 SC Exchange Data | Starting real-time market data updates for: IBB. ID: 2 | 2015-05-17 18:09:07 Intraday data recording state for symbol IBB is set to download pending. | 2015-05-17 18:09:07 Mapping CMG to CMG. Service code: equities.us | 2015-05-17 18:09:07 SC Exchange Data | Starting real-time market data updates for: CMG. ID: 3 | 2015-05-17 18:09:07 Intraday data recording state for symbol CMG is set to download pending. | 2015-05-17 18:09:07 Mapping SMH to SMH. Service code: equities.us | 2015-05-17 18:09:07 SC Exchange Data | Starting real-time market data updates for: SMH. ID: 4 | 2015-05-17 18:09:07 Intraday data recording state for symbol SMH is set to download pending. | 2015-05-17 18:09:07 Mapping ESPR to ESPR. Service code: equities.us | 2015-05-17 18:09:07 SC Exchange Data | Starting real-time market data updates for: ESPR. ID: 5 | 2015-05-17 18:09:07 Intraday data recording state for symbol ESPR is set to download pending. | 2015-05-17 18:09:07 Mapping UWTI to UWTI. Service code: equities.us | 2015-05-17 18:09:07 SC Exchange Data | Starting real-time market data updates for: UWTI. ID: 6 | 2015-05-17 18:09:07 Intraday data recording state for symbol UWTI is set to download pending. | 2015-05-17 18:09:07 Mapping PFE to PFE. Service code: equities.us | 2015-05-17 18:09:07 SC Exchange Data | Starting real-time market data updates for: PFE. ID: 7 | 2015-05-17 18:09:07 Intraday data recording state for symbol PFE is set to download pending. | 2015-05-17 18:09:07 Socket (44) | Connected. | 2015-05-17 18:09:07 SC Exchange Data | Connected to server. | 2015-05-17 18:09:07 SC Exchange Data | Sending logon request message. | 2015-05-17 18:09:07 Socket (45) | Connected. | 2015-05-17 18:09:07 HD Request # 38 | Sending historical data logon request message. | 2015-05-17 18:09:07 Mapping USO to USO. Service code: equities.us | 2015-05-17 18:09:07 SC Exchange Data | Starting real-time market data updates for: USO. ID: 8 | 2015-05-17 18:09:07 Intraday data recording state for symbol USO is set to download pending. | 2015-05-17 18:09:07 Mapping FSL to FSL. Service code: equities.us | 2015-05-17 18:09:07 SC Exchange Data | Starting real-time market data updates for: FSL. ID: 9 | 2015-05-17 18:09:07 Intraday data recording state for symbol FSL is set to download pending. | 2015-05-17 18:09:07 SC Exchange Data | Starting real-time market data updates for: ES-201506-GLOBEX. ID: 10 | 2015-05-17 18:09:07 SC Exchange Data | Subscribing to market data in the service client is not supported. Symbol: ES-201506-GLOBEX | 2015-05-17 18:09:07 Intraday data recording state for symbol ES-201506-GLOBEX is set to download pending. | 2015-05-17 18:09:07 SC Exchange Data | Starting real-time market data updates for: NQ-201506-GLOBEX. ID: 11 | 2015-05-17 18:09:07 SC Exchange Data | Subscribing to market data in the service client is not supported. Symbol: NQ-201506-GLOBEX | 2015-05-17 18:09:07 Intraday data recording state for symbol NQ-201506-GLOBEX is set to download pending. | 2015-05-17 18:09:07 HD Request # 38 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:50. Record interval: 0. Symbol: AAPL | 2015-05-17 18:09:07 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-05-17 18:09:07 SC Exchange Data | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-05-17 18:09:07 SC Exchange Data | Successfully connected. | 2015-05-17 18:09:07 SC Exchange Data | Restarting real-time data updates for symbol: AAPL -> AAPL | 2015-05-17 18:09:07 SC Exchange Data | Restarting real-time data updates for symbol: CMG -> CMG | 2015-05-17 18:09:07 SC Exchange Data | Restarting real-time data updates for symbol: ESPR -> ESPR | 2015-05-17 18:09:07 SC Exchange Data | Restarting real-time data updates for symbol: FSL -> FSL | 2015-05-17 18:09:07 SC Exchange Data | Restarting real-time data updates for symbol: IBB -> IBB | 2015-05-17 18:09:07 SC Exchange Data | Restarting real-time data updates for symbol: PFE -> PFE | 2015-05-17 18:09:07 SC Exchange Data | Restarting real-time data updates for symbol: SMH -> SMH | 2015-05-17 18:09:07 SC Exchange Data | Restarting real-time data updates for symbol: USO -> USO | 2015-05-17 18:09:07 SC Exchange Data | Restarting real-time data updates for symbol: UWTI -> UWTI | 2015-05-17 18:09:07 HD Request # 38 | Decompressing data. | 2015-05-17 18:09:07 HD Request # 38 | Receiving Intraday data for AAPL starting at 2015-05-15 19:59:50 | 2015-05-17 18:09:07 Socket (45) | Shutdown and closed. | 2015-05-17 18:09:07 The network socket for historical data has been closed. | 2015-05-17 18:09:07 HD Request # 38 | Received 1 record from 2015-05-15 19:59:50 to 2015-05-15 19:59:50 (0.0 seconds) and wrote 0 records for AAPL | 2015-05-17 18:09:07 HD Request # 38 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 38 | 2015-05-17 18:09:07 Removed historical data download ID 38 | 2015-05-17 18:09:07 Real-time Intraday chart data file updates started for AAPL | 2015-05-17 18:09:07 Symbol Error - AAPL is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-17 18:09:07 Symbol Error - CMG is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-17 18:09:07 HD Request # 39 | Downloading Intraday chart data for IBB to the file IBB.scid. Service: equities.us | 2015-05-17 18:09:07 HD Request # 39 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:09:07 HD Request # 39 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 18:09:07 Symbol Error - ESPR is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-17 18:09:07 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 18:09:07 Symbol Error - FSL is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-17 18:09:07 Symbol Error - IBB is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-17 18:09:07 Symbol Error - PFE is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-17 18:09:07 Symbol Error - SMH is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-17 18:09:07 Symbol Error - USO is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-17 18:09:07 Symbol Error - UWTI is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-17 18:09:07 Requesting symbol settings for scbcd. Overwrite = on. | 2015-05-17 18:09:07 Socket (46) | Connected. | 2015-05-17 18:09:07 HD Request # 39 | Sending historical data logon request message. | 2015-05-17 18:09:07 HD Request # 39 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: IBB | 2015-05-17 18:09:08 HD Request # 39 | Decompressing data. | 2015-05-17 18:09:08 HD Request # 39 | Receiving Intraday data for IBB starting at 2015-05-14 19:59:33 | 2015-05-17 18:09:08 Socket (46) | Shutdown and closed. | 2015-05-17 18:09:08 The network socket for historical data has been closed. | 2015-05-17 18:09:08 HD Request # 39 | Received 4332 records from 2015-05-14 19:59:33 to 2015-05-15 19:03:18 (23.1 hours) and wrote 0 records for IBB | 2015-05-17 18:09:08 HD Request # 39 | Intraday download COMPLETE for IBB. Completion time: 1s. Unique request ID: 39 | 2015-05-17 18:09:08 Removed historical data download ID 39 | 2015-05-17 18:09:08 Real-time Intraday chart data file updates started for IBB | 2015-05-17 18:09:08 HD Request # 40 | Downloading Intraday chart data for CMG to the file CMG.scid. Service: equities.us | 2015-05-17 18:09:08 HD Request # 40 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:09:08 HD Request # 40 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 18:09:08 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 18:09:08 Socket (47) | Connected. | 2015-05-17 18:09:08 HD Request # 40 | Sending historical data logon request message. | 2015-05-17 18:09:08 HD Request # 40 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: CMG | 2015-05-17 18:09:08 HD Request # 40 | Decompressing data. | 2015-05-17 18:09:08 HD Request # 40 | Receiving Intraday data for CMG starting at 2015-05-14 16:46:34 | 2015-05-17 18:09:08 Socket (47) | Shutdown and closed. | 2015-05-17 18:09:08 The network socket for historical data has been closed. | 2015-05-17 18:09:08 HD Request # 40 | Received 1574 records from 2015-05-14 16:46:34 to 2015-05-15 16:31:28 (23.7 hours) and wrote 0 records for CMG | 2015-05-17 18:09:08 HD Request # 40 | Intraday download COMPLETE for CMG. Completion time: 0s. Unique request ID: 40 | 2015-05-17 18:09:08 Removed historical data download ID 40 | 2015-05-17 18:09:08 Real-time Intraday chart data file updates started for CMG | 2015-05-17 18:09:08 HD Request # 41 | Downloading Intraday chart data for SMH to the file SMH.scid. Service: equities.us | 2015-05-17 18:09:08 HD Request # 41 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:09:08 HD Request # 41 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 18:09:08 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 18:09:08 Socket (48) | Connected. | 2015-05-17 18:09:08 HD Request # 41 | Sending historical data logon request message. | 2015-05-17 18:09:08 HD Request # 41 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: SMH | 2015-05-17 18:09:08 HD Request # 41 | Decompressing data. | 2015-05-17 18:09:08 HD Request # 41 | Receiving Intraday data for SMH starting at 2015-05-14 16:02:36 | 2015-05-17 18:09:08 Socket (48) | Shutdown and closed. | 2015-05-17 18:09:09 The network socket for historical data has been closed. | 2015-05-17 18:09:09 HD Request # 41 | Received 4899 records from 2015-05-14 16:02:36 to 2015-05-15 16:00:21 (24.0 hours) and wrote 0 records for SMH | 2015-05-17 18:09:09 HD Request # 41 | Intraday download COMPLETE for SMH. Completion time: 0s. Unique request ID: 41 | 2015-05-17 18:09:09 Removed historical data download ID 41 | 2015-05-17 18:09:09 Real-time Intraday chart data file updates started for SMH | 2015-05-17 18:09:09 HD Request # 42 | Downloading Intraday chart data for ESPR to the file ESPR.scid. Service: equities.us | 2015-05-17 18:09:09 HD Request # 42 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:09:09 HD Request # 42 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 18:09:09 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 18:09:09 Socket (49) | Connected. | 2015-05-17 18:09:09 HD Request # 42 | Sending historical data logon request message. | 2015-05-17 18:09:09 HD Request # 42 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: ESPR | 2015-05-17 18:09:09 HD Request # 42 | Decompressing data. | 2015-05-17 18:09:09 HD Request # 42 | Receiving Intraday data for ESPR starting at 2015-05-14 15:59:59 | 2015-05-17 18:09:09 Socket (49) | Shutdown and closed. | 2015-05-17 18:09:09 The network socket for historical data has been closed. | 2015-05-17 18:09:09 HD Request # 42 | Received 788 records from 2015-05-14 15:59:59 to 2015-05-15 15:59:58 (24.0 hours) and wrote 0 records for ESPR | 2015-05-17 18:09:09 HD Request # 42 | Intraday download COMPLETE for ESPR. Completion time: 0s. Unique request ID: 42 | 2015-05-17 18:09:09 Removed historical data download ID 42 | 2015-05-17 18:09:09 Real-time Intraday chart data file updates started for ESPR | 2015-05-17 18:09:09 HD Request # 43 | Downloading Intraday chart data for UWTI to the file UWTI.scid. Service: equities.us | 2015-05-17 18:09:09 HD Request # 43 | Download start Date-Time: 2015-05-15 19:59:56.0 | 2015-05-17 18:09:09 HD Request # 43 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 18:09:09 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 18:09:09 Socket (50) | Connected. | 2015-05-17 18:09:09 HD Request # 43 | Sending historical data logon request message. | 2015-05-17 18:09:09 HD Request # 43 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:56. Record interval: 0. Symbol: UWTI | 2015-05-17 18:09:09 HD Request # 43 | Decompressing data. | 2015-05-17 18:09:09 HD Request # 43 | Receiving Intraday data for UWTI starting at 2015-05-15 06:10:56 | 2015-05-17 18:09:09 Socket (50) | Shutdown and closed. | 2015-05-17 18:09:10 The network socket for historical data has been closed. | 2015-05-17 18:09:10 HD Request # 43 | Received 19558 records from 2015-05-15 06:10:56 to 2015-05-15 19:59:55 (13.8 hours) and wrote 0 records for UWTI | 2015-05-17 18:09:10 HD Request # 43 | Intraday download COMPLETE for UWTI. Completion time: 1s. Unique request ID: 43 | 2015-05-17 18:09:10 Removed historical data download ID 43 | 2015-05-17 18:09:10 Real-time Intraday chart data file updates started for UWTI | 2015-05-17 18:09:10 HD Request # 44 | Downloading Intraday chart data for PFE to the file PFE.scid. Service: equities.us | 2015-05-17 18:09:10 HD Request # 44 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:09:10 HD Request # 44 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 18:09:10 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 18:09:10 Socket (51) | Connected. | 2015-05-17 18:09:10 HD Request # 44 | Sending historical data logon request message. | 2015-05-17 18:09:10 HD Request # 44 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: PFE | 2015-05-17 18:09:10 HD Request # 44 | Decompressing data. | 2015-05-17 18:09:10 HD Request # 44 | Receiving Intraday data for PFE starting at 2015-05-15 08:00:00 | 2015-05-17 18:09:10 Symbol settings received. | 2015-05-17 18:09:10 Processed received symbol settings | 2015-05-17 18:09:10 Socket (51) | Shutdown and closed. | 2015-05-17 18:09:10 The network socket for historical data has been closed. | 2015-05-17 18:09:10 HD Request # 44 | Received 32731 records from 2015-05-15 08:00:00 to 2015-05-15 19:45:01 (11.8 hours) and wrote 0 records for PFE | 2015-05-17 18:09:10 HD Request # 44 | Intraday download COMPLETE for PFE. Completion time: 0s. Unique request ID: 44 | 2015-05-17 18:09:10 Removed historical data download ID 44 | 2015-05-17 18:09:10 Real-time Intraday chart data file updates started for PFE | 2015-05-17 18:09:10 HD Request # 45 | Downloading Intraday chart data for USO to the file USO.scid. Service: equities.us | 2015-05-17 18:09:10 HD Request # 45 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:09:10 HD Request # 45 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 18:09:10 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 18:09:10 Socket (52) | Connected. | 2015-05-17 18:09:10 HD Request # 45 | Sending historical data logon request message. | 2015-05-17 18:09:10 HD Request # 45 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: USO | 2015-05-17 18:09:11 HD Request # 45 | Decompressing data. | 2015-05-17 18:09:11 HD Request # 45 | Receiving Intraday data for USO starting at 2015-05-14 18:49:09 | 2015-05-17 18:09:11 Socket (52) | Shutdown and closed. | 2015-05-17 18:09:11 The network socket for historical data has been closed. | 2015-05-17 18:09:11 HD Request # 45 | Received 17558 records from 2015-05-14 18:49:09 to 2015-05-15 18:20:06 (23.5 hours) and wrote 0 records for USO | 2015-05-17 18:09:11 HD Request # 45 | Intraday download COMPLETE for USO. Completion time: 0s. Unique request ID: 45 | 2015-05-17 18:09:11 Removed historical data download ID 45 | 2015-05-17 18:09:11 Real-time Intraday chart data file updates started for USO | 2015-05-17 18:09:11 HD Request # 46 | Downloading Intraday chart data for FSL to the file FSL.scid. Service: equities.us | 2015-05-17 18:09:11 HD Request # 46 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:09:11 HD Request # 46 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 18:09:11 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 18:09:11 Socket (53) | Connected. | 2015-05-17 18:09:11 HD Request # 46 | Sending historical data logon request message. | 2015-05-17 18:09:11 HD Request # 46 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: FSL | 2015-05-17 18:09:11 HD Request # 46 | Decompressing data. | 2015-05-17 18:09:11 HD Request # 46 | Receiving Intraday data for FSL starting at 2015-05-14 16:02:52 | 2015-05-17 18:09:11 Socket (53) | Shutdown and closed. | 2015-05-17 18:09:12 The network socket for historical data has been closed. | 2015-05-17 18:09:12 HD Request # 46 | Received 6535 records from 2015-05-14 16:02:52 to 2015-05-15 16:02:33 (24.0 hours) and wrote 0 records for FSL | 2015-05-17 18:09:12 HD Request # 46 | Intraday download COMPLETE for FSL. Completion time: 1s. Unique request ID: 46 | 2015-05-17 18:09:12 Removed historical data download ID 46 | 2015-05-17 18:09:12 Real-time Intraday chart data file updates started for FSL | 2015-05-17 18:09:12 HD Request # 47 | Downloading Intraday chart data for ES-201506-GLOBEX to the file ES-201506-GLOBEX.scid. Service: scbcd | 2015-05-17 18:09:12 HD Request # 47 | Download start Date-Time: 2015-05-17 18:08:03.0 | 2015-05-17 18:09:12 HD Request # 47 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 18:09:12 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 18:09:12 Socket (54) | Connected. | 2015-05-17 18:09:12 HD Request # 47 | Sending historical data logon request message. | 2015-05-17 18:09:12 HD Request # 47 | Error downloading historical Intraday data for ES-201506-GLOBEX. Historical data logon error: Invalid/missing data for service code: scbcd | 2015-05-17 18:09:12 * Socket (54) | Shutdown and closed. | 2015-05-17 18:09:12 The network socket for historical data has been closed. | 2015-05-17 18:09:12 HD Request # 47 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201506-GLOBEX | 2015-05-17 18:09:12 HD Request # 47 | Intraday download COMPLETE for ES-201506-GLOBEX. Completion time: 0s. Unique request ID: 47 | 2015-05-17 18:09:12 Removed historical data download ID 47 | 2015-05-17 18:09:12 Real-time Intraday chart data file updates started for ES-201506-GLOBEX | 2015-05-17 18:09:12 HD Request # 48 | Downloading Intraday chart data for NQ-201506-GLOBEX to the file NQ-201506-GLOBEX.scid. Service: scbcd | 2015-05-17 18:09:12 HD Request # 48 | Download start Date-Time: 2015-05-17 18:07:58.0 | 2015-05-17 18:09:12 HD Request # 48 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-17 18:09:12 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-17 18:09:12 Socket (55) | Connected. | 2015-05-17 18:09:12 HD Request # 48 | Sending historical data logon request message. | 2015-05-17 18:09:12 Socket (55) | Shutdown and closed. | 2015-05-17 18:09:12 The network socket for historical data has been closed. | 2015-05-17 18:09:12 HD Request # 48 | Error downloading historical Intraday data for NQ-201506-GLOBEX. Historical data logon error: Invalid/missing data for service code: scbcd | 2015-05-17 18:09:12 * HD Request # 48 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201506-GLOBEX | 2015-05-17 18:09:12 HD Request # 48 | Intraday download COMPLETE for NQ-201506-GLOBEX. Completion time: 0s. Unique request ID: 48 | 2015-05-17 18:09:12 Removed historical data download ID 48 | 2015-05-17 18:09:12 Real-time Intraday chart data file updates started for NQ-201506-GLOBEX | 2015-05-17 18:09:12 Requesting market depth updates for: AAPL if supported. | 2015-05-17 18:09:12 Requesting market depth updates for: CMG if supported. | 2015-05-17 18:09:12 Requesting market depth updates for: IBB if supported. | 2015-05-17 18:09:12 Requesting market depth updates for: SMH if supported. | 2015-05-17 18:09:12 Market Depth data has been rejected for symbol: AAPL. Exchange not authorized. | 2015-05-17 18:09:12 Market Depth data has been rejected for symbol: CMG. Exchange not authorized. | 2015-05-17 18:09:12 Market Depth data has been rejected for symbol: IBB. Exchange not authorized. | 2015-05-17 18:09:12 Market Depth data has been rejected for symbol: SMH. Exchange not authorized. | 2015-05-17 18:09:12 HTTP connection to www.sierrachart.com:80 (43) | Closed. No error. | 2015-05-17 18:09:15 HTTP connection to www.sierrachart.com:80 (43) | Shutdown and closed. | 2015-05-17 18:09:15 Current selected Data/Trading service: SC Historical Data | 2015-05-17 18:10:05 Checking for new symbol settings for ddf | 2015-05-17 18:10:05 Socket (44) | Shutdown and closed. | 2015-05-17 18:10:05 SC Exchange Data | Disconnected from the server. | 2015-05-17 18:10:05 SC Exchange Data | Disconnected. | 2015-05-17 18:10:05 NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2015-05-17 18:10:05 SC Historical Data | Connected. Historical Intraday data will be requested. | 2015-05-17 18:10:05 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-05-17 18:10:05 SC Historical Data | Starting real-time market data updates for: AAPL. ID: 1 | 2015-05-17 18:10:05 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: AAPL | 2015-05-17 18:10:05 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 18:10:05 HD Request # 49 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ddf | 2015-05-17 18:10:05 HD Request # 49 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:05 HD Request # 49 | Download start Date-Time: 2015-05-15 19:59:50.0 | 2015-05-17 18:10:05 HD Request # 49 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:05 HD Request # 49 | Using user Barchart Historical data account. | 2015-05-17 18:10:05 HD Request # 49 | Requesting historical Intraday Minute data for AAPL starting at 2015-05-15 19:59:50 (Exchange time). | 2015-05-17 18:10:05 SC Historical Data | Starting real-time market data updates for: IBB. ID: 2 | 2015-05-17 18:10:05 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: IBB | 2015-05-17 18:10:05 Intraday data recording state for symbol IBB is set to download pending. | 2015-05-17 18:10:05 SC Historical Data | Starting real-time market data updates for: CMG. ID: 3 | 2015-05-17 18:10:05 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: CMG | 2015-05-17 18:10:05 Intraday data recording state for symbol CMG is set to download pending. | 2015-05-17 18:10:05 SC Historical Data | Starting real-time market data updates for: SMH. ID: 4 | 2015-05-17 18:10:05 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: SMH | 2015-05-17 18:10:05 Intraday data recording state for symbol SMH is set to download pending. | 2015-05-17 18:10:05 SC Historical Data | Starting real-time market data updates for: ESPR. ID: 5 | 2015-05-17 18:10:05 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: ESPR | 2015-05-17 18:10:05 Intraday data recording state for symbol ESPR is set to download pending. | 2015-05-17 18:10:05 SC Historical Data | Starting real-time market data updates for: UWTI. ID: 6 | 2015-05-17 18:10:05 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: UWTI | 2015-05-17 18:10:05 Intraday data recording state for symbol UWTI is set to download pending. | 2015-05-17 18:10:05 SC Historical Data | Starting real-time market data updates for: PFE. ID: 7 | 2015-05-17 18:10:05 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: PFE | 2015-05-17 18:10:05 Intraday data recording state for symbol PFE is set to download pending. | 2015-05-17 18:10:05 SC Historical Data | Starting real-time market data updates for: USO. ID: 8 | 2015-05-17 18:10:05 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: USO | 2015-05-17 18:10:05 Intraday data recording state for symbol USO is set to download pending. | 2015-05-17 18:10:05 SC Historical Data | Starting real-time market data updates for: FSL. ID: 9 | 2015-05-17 18:10:05 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: FSL | 2015-05-17 18:10:05 Intraday data recording state for symbol FSL is set to download pending. | 2015-05-17 18:10:05 SC Historical Data | Starting real-time market data updates for: ES-201506-GLOBEX. ID: 10 | 2015-05-17 18:10:05 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: ES-201506-GLOBEX | 2015-05-17 18:10:05 Intraday data recording state for symbol ES-201506-GLOBEX is set to download pending. | 2015-05-17 18:10:05 SC Historical Data | Starting real-time market data updates for: NQ-201506-GLOBEX. ID: 11 | 2015-05-17 18:10:05 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: NQ-201506-GLOBEX | 2015-05-17 18:10:05 Intraday data recording state for symbol NQ-201506-GLOBEX is set to download pending. | 2015-05-17 18:10:05 HTTP connection to www.sierrachart.com:80 (56) | Connected. | 2015-05-17 18:10:05 HD Request # 49 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AAPL | 2015-05-17 18:10:05 HD Request # 49 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 49 | 2015-05-17 18:10:05 HD Request # 50 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ddf | 2015-05-17 18:10:05 HD Request # 50 | Rounding start Date-Time down to the minute: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:05 HD Request # 50 | Download start Date-Time: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:05 HD Request # 50 | Using user Barchart Historical data account. | 2015-05-17 18:10:05 HD Request # 50 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-15 19:59:00 (Exchange time). | 2015-05-17 18:10:05 HD Request # 50 | Receiving Intraday data for AAPL starting at 2015-05-15 19:59:01 | 2015-05-17 18:10:05 HD Request # 50 | Truncating Intraday data file at 2015-05-15 19:59:01 while receiving initial tick data during multistage download. | 2015-05-17 18:10:05 HD Request # 50 | Date-time after truncate 2015-05-15 19:58:46 | 2015-05-17 18:10:05 HD Request # 50 | Timestamp of first Intraday data file record written: 2015-05-15 19:59:01 | 2015-05-17 18:10:05 HD Request # 50 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 18:10:05 HD Request # 50 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 18:10:05 HD Request # 50 | Received 2 records from 2015-05-15 19:59:01 to 2015-05-15 19:59:50 (49.0 seconds) and wrote 2 records for AAPL | 2015-05-17 18:10:05 HD Request # 50 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 49 | 2015-05-17 18:10:05 Removed historical data download ID 49 | 2015-05-17 18:10:05 Real-time Intraday chart data file updates started for AAPL | 2015-05-17 18:10:05 HD Request # 50 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:10:05 HD Request # 50 | Reloading Intraday charts for symbol. | 2015-05-17 18:10:05 Reloading all charts with filename: AAPL.scid | 2015-05-17 18:10:05 HD Request # 51 | Downloading Intraday chart data for IBB to the file IBB.scid. Service: ddf | 2015-05-17 18:10:05 HD Request # 51 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:05 HD Request # 51 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:10:05 HD Request # 51 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:05 HD Request # 51 | Using user Barchart Historical data account. | 2015-05-17 18:10:05 HD Request # 51 | Requesting historical Intraday Minute data for IBB starting at 2015-05-15 19:59:30 (Exchange time). | 2015-05-17 18:10:05 HD Request # 51 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for IBB | 2015-05-17 18:10:05 HD Request # 51 | Intraday download COMPLETE for IBB. Completion time: 1s. Unique request ID: 50 | 2015-05-17 18:10:06 HD Request # 52 | Downloading Intraday chart data for IBB to the file IBB.scid. Service: ddf | 2015-05-17 18:10:06 HD Request # 52 | Rounding start Date-Time down to the minute: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:06 HD Request # 52 | Download start Date-Time: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:06 HD Request # 52 | Using user Barchart Historical data account. | 2015-05-17 18:10:06 HD Request # 52 | Requesting historical Intraday Tick data for IBB starting at 2015-05-15 19:59:00 (Exchange time). | 2015-05-17 18:10:06 Requesting symbol settings for ddf. Overwrite = on. | 2015-05-17 18:10:06 HD Request # 52 | Requesting historical Intraday Tick data for IBB starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 18:10:06 HD Request # 52 | Requesting historical Intraday Tick data for IBB starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 18:10:06 HD Request # 52 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for IBB | 2015-05-17 18:10:06 HD Request # 52 | Intraday download COMPLETE for IBB. Completion time: 0s. Unique request ID: 50 | 2015-05-17 18:10:06 Removed historical data download ID 50 | 2015-05-17 18:10:06 Real-time Intraday chart data file updates started for IBB | 2015-05-17 18:10:06 HD Request # 52 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:10:06 HD Request # 53 | Downloading Intraday chart data for CMG to the file CMG.scid. Service: ddf | 2015-05-17 18:10:06 HD Request # 53 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:06 HD Request # 53 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:10:06 HD Request # 53 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:06 HD Request # 53 | Using user Barchart Historical data account. | 2015-05-17 18:10:06 HD Request # 53 | Requesting historical Intraday Minute data for CMG starting at 2015-05-15 19:59:30 (Exchange time). | 2015-05-17 18:10:06 HD Request # 53 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CMG | 2015-05-17 18:10:06 HD Request # 53 | Intraday download COMPLETE for CMG. Completion time: 0s. Unique request ID: 51 | 2015-05-17 18:10:06 HD Request # 54 | Downloading Intraday chart data for CMG to the file CMG.scid. Service: ddf | 2015-05-17 18:10:06 HD Request # 54 | Rounding start Date-Time down to the minute: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:06 HD Request # 54 | Download start Date-Time: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:06 HD Request # 54 | Using user Barchart Historical data account. | 2015-05-17 18:10:06 HD Request # 54 | Requesting historical Intraday Tick data for CMG starting at 2015-05-15 19:59:00 (Exchange time). | 2015-05-17 18:10:06 HD Request # 54 | Requesting historical Intraday Tick data for CMG starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 18:10:06 HD Request # 54 | Requesting historical Intraday Tick data for CMG starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 18:10:06 HD Request # 54 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CMG | 2015-05-17 18:10:06 HD Request # 54 | Intraday download COMPLETE for CMG. Completion time: 0s. Unique request ID: 51 | 2015-05-17 18:10:06 Removed historical data download ID 51 | 2015-05-17 18:10:06 Real-time Intraday chart data file updates started for CMG | 2015-05-17 18:10:06 HD Request # 54 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:10:06 HD Request # 55 | Downloading Intraday chart data for SMH to the file SMH.scid. Service: ddf | 2015-05-17 18:10:06 HD Request # 55 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:06 HD Request # 55 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:10:06 HD Request # 55 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:06 HD Request # 55 | Using user Barchart Historical data account. | 2015-05-17 18:10:06 HD Request # 55 | Requesting historical Intraday Minute data for SMH starting at 2015-05-15 19:59:30 (Exchange time). | 2015-05-17 18:10:06 HD Request # 55 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SMH | 2015-05-17 18:10:06 HD Request # 55 | Intraday download COMPLETE for SMH. Completion time: 0s. Unique request ID: 52 | 2015-05-17 18:10:06 HD Request # 56 | Downloading Intraday chart data for SMH to the file SMH.scid. Service: ddf | 2015-05-17 18:10:06 HD Request # 56 | Rounding start Date-Time down to the minute: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:06 HD Request # 56 | Download start Date-Time: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:06 HD Request # 56 | Using user Barchart Historical data account. | 2015-05-17 18:10:06 HD Request # 56 | Requesting historical Intraday Tick data for SMH starting at 2015-05-15 19:59:00 (Exchange time). | 2015-05-17 18:10:06 HD Request # 56 | Requesting historical Intraday Tick data for SMH starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 18:10:06 HD Request # 56 | Requesting historical Intraday Tick data for SMH starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 18:10:06 HD Request # 56 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SMH | 2015-05-17 18:10:06 HD Request # 56 | Intraday download COMPLETE for SMH. Completion time: 0s. Unique request ID: 52 | 2015-05-17 18:10:06 Removed historical data download ID 52 | 2015-05-17 18:10:06 Real-time Intraday chart data file updates started for SMH | 2015-05-17 18:10:06 HD Request # 56 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:10:06 HD Request # 57 | Downloading Intraday chart data for ESPR to the file ESPR.scid. Service: ddf | 2015-05-17 18:10:06 HD Request # 57 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:06 HD Request # 57 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:10:06 HD Request # 57 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:06 HD Request # 57 | Using user Barchart Historical data account. | 2015-05-17 18:10:06 HD Request # 57 | Requesting historical Intraday Minute data for ESPR starting at 2015-05-15 19:59:30 (Exchange time). | 2015-05-17 18:10:06 HD Request # 57 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESPR | 2015-05-17 18:10:07 HD Request # 57 | Intraday download COMPLETE for ESPR. Completion time: 1s. Unique request ID: 53 | 2015-05-17 18:10:07 HD Request # 58 | Downloading Intraday chart data for ESPR to the file ESPR.scid. Service: ddf | 2015-05-17 18:10:07 HD Request # 58 | Rounding start Date-Time down to the minute: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:07 HD Request # 58 | Download start Date-Time: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:07 HD Request # 58 | Using user Barchart Historical data account. | 2015-05-17 18:10:07 HD Request # 58 | Requesting historical Intraday Tick data for ESPR starting at 2015-05-15 19:59:00 (Exchange time). | 2015-05-17 18:10:07 HD Request # 58 | Requesting historical Intraday Tick data for ESPR starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 18:10:07 HD Request # 58 | Requesting historical Intraday Tick data for ESPR starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 18:10:07 HD Request # 58 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESPR | 2015-05-17 18:10:07 HD Request # 58 | Intraday download COMPLETE for ESPR. Completion time: 0s. Unique request ID: 53 | 2015-05-17 18:10:07 Removed historical data download ID 53 | 2015-05-17 18:10:07 Real-time Intraday chart data file updates started for ESPR | 2015-05-17 18:10:07 HD Request # 58 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:10:07 HD Request # 59 | Downloading Intraday chart data for UWTI to the file UWTI.scid. Service: ddf | 2015-05-17 18:10:07 HD Request # 59 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:07 HD Request # 59 | Download start Date-Time: 2015-05-15 19:59:56.0 | 2015-05-17 18:10:07 HD Request # 59 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:07 HD Request # 59 | Using user Barchart Historical data account. | 2015-05-17 18:10:07 HD Request # 59 | Requesting historical Intraday Minute data for UWTI starting at 2015-05-15 19:59:56 (Exchange time). | 2015-05-17 18:10:07 HD Request # 59 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for UWTI | 2015-05-17 18:10:07 HD Request # 59 | Intraday download COMPLETE for UWTI. Completion time: 0s. Unique request ID: 54 | 2015-05-17 18:10:07 HD Request # 60 | Downloading Intraday chart data for UWTI to the file UWTI.scid. Service: ddf | 2015-05-17 18:10:07 HD Request # 60 | Rounding start Date-Time down to the minute: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:07 HD Request # 60 | Download start Date-Time: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:07 HD Request # 60 | Using user Barchart Historical data account. | 2015-05-17 18:10:07 HD Request # 60 | Requesting historical Intraday Tick data for UWTI starting at 2015-05-15 19:59:00 (Exchange time). | 2015-05-17 18:10:07 HD Request # 60 | Receiving Intraday data for UWTI starting at 2015-05-15 19:59:55 | 2015-05-17 18:10:07 HD Request # 60 | Truncating Intraday data file at 2015-05-15 19:59:55 while receiving initial tick data during multistage download. | 2015-05-17 18:10:07 HD Request # 60 | Date-time after truncate 2015-05-15 19:58:42 | 2015-05-17 18:10:07 HD Request # 60 | Timestamp of first Intraday data file record written: 2015-05-15 19:59:55 | 2015-05-17 18:10:07 HD Request # 60 | Requesting historical Intraday Tick data for UWTI starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 18:10:07 HD Request # 60 | Requesting historical Intraday Tick data for UWTI starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 18:10:07 HD Request # 60 | Received 1 record from 2015-05-15 19:59:55 to 2015-05-15 19:59:55 (0.0 seconds) and wrote 1 record for UWTI | 2015-05-17 18:10:07 HD Request # 60 | Intraday download COMPLETE for UWTI. Completion time: 0s. Unique request ID: 54 | 2015-05-17 18:10:07 Removed historical data download ID 54 | 2015-05-17 18:10:07 Real-time Intraday chart data file updates started for UWTI | 2015-05-17 18:10:07 HD Request # 60 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:10:07 HD Request # 60 | Reloading Intraday charts for symbol. | 2015-05-17 18:10:07 Reloading all charts with filename: UWTI.scid | 2015-05-17 18:10:07 HD Request # 61 | Downloading Intraday chart data for PFE to the file PFE.scid. Service: ddf | 2015-05-17 18:10:07 HD Request # 61 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:07 HD Request # 61 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:10:07 HD Request # 61 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:07 HD Request # 61 | Using user Barchart Historical data account. | 2015-05-17 18:10:07 HD Request # 61 | Requesting historical Intraday Minute data for PFE starting at 2015-05-15 19:59:30 (Exchange time). | 2015-05-17 18:10:07 HD Request # 61 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for PFE | 2015-05-17 18:10:07 HD Request # 61 | Intraday download COMPLETE for PFE. Completion time: 0s. Unique request ID: 55 | 2015-05-17 18:10:07 HD Request # 62 | Downloading Intraday chart data for PFE to the file PFE.scid. Service: ddf | 2015-05-17 18:10:07 HD Request # 62 | Rounding start Date-Time down to the minute: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:07 HD Request # 62 | Download start Date-Time: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:07 HD Request # 62 | Using user Barchart Historical data account. | 2015-05-17 18:10:07 HD Request # 62 | Requesting historical Intraday Tick data for PFE starting at 2015-05-15 19:59:00 (Exchange time). | 2015-05-17 18:10:07 HD Request # 62 | Requesting historical Intraday Tick data for PFE starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 18:10:07 HD Request # 62 | Requesting historical Intraday Tick data for PFE starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 18:10:07 HD Request # 62 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for PFE | 2015-05-17 18:10:07 HD Request # 62 | Intraday download COMPLETE for PFE. Completion time: 0s. Unique request ID: 55 | 2015-05-17 18:10:07 Removed historical data download ID 55 | 2015-05-17 18:10:07 Real-time Intraday chart data file updates started for PFE | 2015-05-17 18:10:07 HD Request # 62 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:10:07 HD Request # 63 | Downloading Intraday chart data for USO to the file USO.scid. Service: ddf | 2015-05-17 18:10:07 HD Request # 63 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:07 HD Request # 63 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:10:07 HD Request # 63 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:07 HD Request # 63 | Using user Barchart Historical data account. | 2015-05-17 18:10:07 HD Request # 63 | Requesting historical Intraday Minute data for USO starting at 2015-05-15 19:59:30 (Exchange time). | 2015-05-17 18:10:07 HD Request # 63 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USO | 2015-05-17 18:10:07 HD Request # 63 | Intraday download COMPLETE for USO. Completion time: 0s. Unique request ID: 56 | 2015-05-17 18:10:07 HD Request # 64 | Downloading Intraday chart data for USO to the file USO.scid. Service: ddf | 2015-05-17 18:10:07 HD Request # 64 | Rounding start Date-Time down to the minute: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:07 HD Request # 64 | Download start Date-Time: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:07 HD Request # 64 | Using user Barchart Historical data account. | 2015-05-17 18:10:07 HD Request # 64 | Requesting historical Intraday Tick data for USO starting at 2015-05-15 19:59:00 (Exchange time). | 2015-05-17 18:10:07 HD Request # 64 | Requesting historical Intraday Tick data for USO starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 18:10:08 HD Request # 64 | Requesting historical Intraday Tick data for USO starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 18:10:08 HD Request # 64 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USO | 2015-05-17 18:10:08 HD Request # 64 | Intraday download COMPLETE for USO. Completion time: 0s. Unique request ID: 56 | 2015-05-17 18:10:08 Removed historical data download ID 56 | 2015-05-17 18:10:08 Real-time Intraday chart data file updates started for USO | 2015-05-17 18:10:08 HD Request # 64 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:10:08 HD Request # 65 | Downloading Intraday chart data for FSL to the file FSL.scid. Service: ddf | 2015-05-17 18:10:08 HD Request # 65 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:08 HD Request # 65 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-17 18:10:08 HD Request # 65 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:08 HD Request # 65 | Using user Barchart Historical data account. | 2015-05-17 18:10:08 HD Request # 65 | Requesting historical Intraday Minute data for FSL starting at 2015-05-15 19:59:30 (Exchange time). | 2015-05-17 18:10:08 HD Request # 65 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FSL | 2015-05-17 18:10:08 HD Request # 65 | Intraday download COMPLETE for FSL. Completion time: 0s. Unique request ID: 57 | 2015-05-17 18:10:08 HD Request # 66 | Downloading Intraday chart data for FSL to the file FSL.scid. Service: ddf | 2015-05-17 18:10:08 HD Request # 66 | Rounding start Date-Time down to the minute: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:08 HD Request # 66 | Download start Date-Time: 2015-05-15 19:59:00.0 | 2015-05-17 18:10:08 HD Request # 66 | Using user Barchart Historical data account. | 2015-05-17 18:10:08 HD Request # 66 | Requesting historical Intraday Tick data for FSL starting at 2015-05-15 19:59:00 (Exchange time). | 2015-05-17 18:10:08 HD Request # 66 | Requesting historical Intraday Tick data for FSL starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 18:10:08 HD Request # 66 | Requesting historical Intraday Tick data for FSL starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 18:10:08 HD Request # 66 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FSL | 2015-05-17 18:10:08 HD Request # 66 | Intraday download COMPLETE for FSL. Completion time: 0s. Unique request ID: 57 | 2015-05-17 18:10:08 Removed historical data download ID 57 | 2015-05-17 18:10:08 Real-time Intraday chart data file updates started for FSL | 2015-05-17 18:10:08 HD Request # 66 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:10:08 HD Request # 67 | Downloading Intraday chart data for ES-201506-GLOBEX to the file ES-201506-GLOBEX.scid. Service: ddf | 2015-05-17 18:10:08 HD Request # 67 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:08 HD Request # 67 | Download start Date-Time: 2015-05-17 18:08:03.0 | 2015-05-17 18:10:08 HD Request # 67 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:08 HD Request # 67 | Using user Barchart Historical data account. | 2015-05-17 18:10:08 HD Request # 67 | Requesting historical Intraday Minute data for ES-201506-GLOBEX starting at 2015-05-17 18:08:03 (Exchange time). | 2015-05-17 18:10:08 HD Request # 67 | Error downloading historical Intraday data for ES-201506-GLOBEX. Error executing query: Invalid symbol | 2015-05-17 18:10:08 * HD Request # 67 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201506-GLOBEX | 2015-05-17 18:10:08 HD Request # 67 | Intraday download COMPLETE for ES-201506-GLOBEX. Completion time: 0s. Unique request ID: 58 | 2015-05-17 18:10:08 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-05-17 18:10:08 HD Request # 68 | Downloading Intraday chart data for ES-201506-GLOBEX to the file ES-201506-GLOBEX.scid. Service: ddf | 2015-05-17 18:10:08 HD Request # 68 | Rounding start Date-Time down to the minute: 2015-05-17 18:08:00.0 | 2015-05-17 18:10:08 HD Request # 68 | Download start Date-Time: 2015-05-17 18:08:00.0 | 2015-05-17 18:10:08 HD Request # 68 | Using user Barchart Historical data account. | 2015-05-17 18:10:08 HD Request # 68 | Requesting historical Intraday Tick data for ES-201506-GLOBEX starting at 2015-05-17 18:08:00 (Exchange time). | 2015-05-17 18:10:08 HD Request # 68 | Error downloading historical Intraday data for ES-201506-GLOBEX. Error executing query: Invalid symbol | 2015-05-17 18:10:08 * HD Request # 68 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201506-GLOBEX | 2015-05-17 18:10:08 HD Request # 68 | Intraday download COMPLETE for ES-201506-GLOBEX. Completion time: 0s. Unique request ID: 58 | 2015-05-17 18:10:08 Removed historical data download ID 58 | 2015-05-17 18:10:08 Real-time Intraday chart data file updates started for ES-201506-GLOBEX | 2015-05-17 18:10:08 HD Request # 68 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:10:08 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-05-17 18:10:08 HD Request # 69 | Downloading Intraday chart data for NQ-201506-GLOBEX to the file NQ-201506-GLOBEX.scid. Service: ddf | 2015-05-17 18:10:08 HD Request # 69 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:08 HD Request # 69 | Download start Date-Time: 2015-05-17 18:07:58.0 | 2015-05-17 18:10:08 HD Request # 69 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:08 HD Request # 69 | Using user Barchart Historical data account. | 2015-05-17 18:10:08 HD Request # 69 | Requesting historical Intraday Minute data for NQ-201506-GLOBEX starting at 2015-05-17 18:07:58 (Exchange time). | 2015-05-17 18:10:08 HD Request # 69 | Error downloading historical Intraday data for NQ-201506-GLOBEX. Error executing query: Invalid symbol | 2015-05-17 18:10:08 * HD Request # 69 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201506-GLOBEX | 2015-05-17 18:10:08 HD Request # 69 | Intraday download COMPLETE for NQ-201506-GLOBEX. Completion time: 0s. Unique request ID: 59 | 2015-05-17 18:10:08 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-05-17 18:10:08 HD Request # 70 | Downloading Intraday chart data for NQ-201506-GLOBEX to the file NQ-201506-GLOBEX.scid. Service: ddf | 2015-05-17 18:10:08 HD Request # 70 | Rounding start Date-Time down to the minute: 2015-05-17 18:07:00.0 | 2015-05-17 18:10:08 HD Request # 70 | Download start Date-Time: 2015-05-17 18:07:00.0 | 2015-05-17 18:10:08 HD Request # 70 | Using user Barchart Historical data account. | 2015-05-17 18:10:08 HD Request # 70 | Requesting historical Intraday Tick data for NQ-201506-GLOBEX starting at 2015-05-17 18:07:00 (Exchange time). | 2015-05-17 18:10:08 HD Request # 70 | Error downloading historical Intraday data for NQ-201506-GLOBEX. Error executing query: Invalid symbol | 2015-05-17 18:10:08 * HD Request # 70 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201506-GLOBEX | 2015-05-17 18:10:08 HD Request # 70 | Intraday download COMPLETE for NQ-201506-GLOBEX. Completion time: 0s. Unique request ID: 59 | 2015-05-17 18:10:08 Removed historical data download ID 59 | 2015-05-17 18:10:08 Real-time Intraday chart data file updates started for NQ-201506-GLOBEX | 2015-05-17 18:10:08 HD Request # 70 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:10:08 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-05-17 18:10:08 Requesting market depth updates for: AAPL if supported. | 2015-05-17 18:10:10 Requesting market depth updates for: CMG if supported. | 2015-05-17 18:10:10 Requesting market depth updates for: IBB if supported. | 2015-05-17 18:10:10 Requesting market depth updates for: SMH if supported. | 2015-05-17 18:10:10 Symbol settings received. | 2015-05-17 18:10:11 Processed received symbol settings | 2015-05-17 18:10:11 HTTP connection to www.sierrachart.com:80 (56) | Closed. No error. | 2015-05-17 18:10:15 HTTP connection to www.sierrachart.com:80 (56) | Shutdown and closed. | 2015-05-17 18:10:15 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 18:10:45 Reloading all charts with filename: AAPL.scid | 2015-05-17 18:10:45 HD Request # 71 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ddf | 2015-05-17 18:10:45 HD Request # 71 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:10:45 HD Request # 71 | Download start Date-Time: 2015-01-17 17:10:45.0 | 2015-05-17 18:10:45 HD Request # 71 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:10:45 HD Request # 71 | Using user Barchart Historical data account. | 2015-05-17 18:10:45 HD Request # 71 | Requesting historical Intraday Minute data for AAPL starting at 2015-01-17 17:10:45 (Exchange time). | 2015-05-17 18:10:45 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\AAPL.scid | 2015-05-17 18:10:46 HD Request # 71 | Receiving Intraday data for AAPL starting at 2015-01-20 07:29:00 | 2015-05-17 18:10:46 HD Request # 71 | Timestamp of first Intraday data file record written: 2015-01-20 07:29:00 | 2015-05-17 18:10:46 HD Request # 71 | Received 56657 records from 2015-01-20 07:29:00 to 2015-05-15 19:59:00 (115.5 days) and wrote 56657 records for AAPL | 2015-05-17 18:10:48 HD Request # 71 | Intraday download COMPLETE for AAPL. Completion time: 3s. Unique request ID: 60 | 2015-05-17 18:10:48 HD Request # 72 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ddf | 2015-05-17 18:10:48 HD Request # 72 | Rounding start Date-Time down to the minute: 2015-01-17 17:10:00.0 | 2015-05-17 18:10:48 HD Request # 72 | Download start Date-Time: 2015-01-17 17:10:00.0 | 2015-05-17 18:10:48 HD Request # 72 | Using user Barchart Historical data account. | 2015-05-17 18:10:48 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-16 18:10:45 (Exchange time). | 2015-05-17 18:10:48 HD Request # 72 | Receiving Intraday data for AAPL starting at 2015-04-16 18:11:42 | 2015-05-17 18:10:48 HD Request # 72 | Truncating Intraday data file at 2015-04-16 18:11:42 while receiving initial tick data during multistage download. | 2015-05-17 18:10:48 HD Request # 72 | Date-time after truncate 2015-04-16 18:11:00 | 2015-05-17 18:10:48 HD Request # 72 | Timestamp of first Intraday data file record written: 2015-04-16 18:11:42 | 2015-05-17 18:10:48 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-17 00:00:00 (Exchange time). | 2015-05-17 18:10:48 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-18 00:00:00 (Exchange time). | 2015-05-17 18:10:50 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-19 00:00:00 (Exchange time). | 2015-05-17 18:10:50 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-20 00:00:00 (Exchange time). | 2015-05-17 18:10:50 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-21 00:00:00 (Exchange time). | 2015-05-17 18:10:52 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-22 00:00:00 (Exchange time). | 2015-05-17 18:10:54 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-23 00:00:00 (Exchange time). | 2015-05-17 18:10:56 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-24 00:00:00 (Exchange time). | 2015-05-17 18:10:59 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-25 00:00:00 (Exchange time). | 2015-05-17 18:11:02 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-26 00:00:00 (Exchange time). | 2015-05-17 18:11:02 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-27 00:00:00 (Exchange time). | 2015-05-17 18:11:02 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-28 00:00:00 (Exchange time). | 2015-05-17 18:11:09 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-29 00:00:00 (Exchange time). | 2015-05-17 18:11:16 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-30 00:00:00 (Exchange time). | 2015-05-17 18:11:19 Intraday data recording state for symbol NQ-201506-GLOBEX is set to download pending. | 2015-05-17 18:11:20 Reloading all charts with filename: NQ-201506-GLOBEX.scid | 2015-05-17 18:11:20 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQ-201506-GLOBEX.scid | 2015-05-17 18:11:20 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-01 00:00:00 (Exchange time). | 2015-05-17 18:11:22 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-02 00:00:00 (Exchange time). | 2015-05-17 18:11:26 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-03 00:00:00 (Exchange time). | 2015-05-17 18:11:26 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-04 00:00:00 (Exchange time). | 2015-05-17 18:11:26 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-05 00:00:00 (Exchange time). | 2015-05-17 18:11:28 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-06 00:00:00 (Exchange time). | 2015-05-17 18:11:31 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-07 00:00:00 (Exchange time). | 2015-05-17 18:11:37 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-08 00:00:00 (Exchange time). | 2015-05-17 18:11:42 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-09 00:00:00 (Exchange time). | 2015-05-17 18:11:45 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-10 00:00:00 (Exchange time). | 2015-05-17 18:11:46 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-11 00:00:00 (Exchange time). | 2015-05-17 18:11:46 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-12 00:00:00 (Exchange time). | 2015-05-17 18:11:48 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-13 00:00:00 (Exchange time). | 2015-05-17 18:11:50 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-14 00:00:00 (Exchange time). | 2015-05-17 18:11:51 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-15 00:00:00 (Exchange time). | 2015-05-17 18:11:54 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 18:11:57 HD Request # 72 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 18:11:57 HD Request # 72 | Received 4332321 records from 2015-04-16 18:11:42 to 2015-05-15 19:59:50 (29.1 days) and wrote 4332293 records for AAPL | 2015-05-17 18:11:57 HD Request # 72 | Intraday download COMPLETE for AAPL. Completion time: 1m 9s. Unique request ID: 60 | 2015-05-17 18:11:57 Removed historical data download ID 60 | 2015-05-17 18:11:57 Real-time Intraday chart data file updates started for AAPL | 2015-05-17 18:11:57 HD Request # 72 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:11:57 HD Request # 72 | Reloading Intraday charts for symbol. | 2015-05-17 18:11:57 Reloading all charts with filename: AAPL.scid | 2015-05-17 18:11:57 HD Request # 73 | Downloading Intraday chart data for NQ-201506-GLOBEX to the file NQ-201506-GLOBEX.scid. Service: ddf | 2015-05-17 18:11:57 HD Request # 73 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:11:57 HD Request # 73 | Download start Date-Time: 2015-01-17 17:11:57.0 | 2015-05-17 18:11:57 HD Request # 73 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:11:57 HD Request # 73 | Using user Barchart Historical data account. | 2015-05-17 18:11:57 HD Request # 73 | Requesting historical Intraday Minute data for NQ-201506-GLOBEX starting at 2015-01-17 17:11:57 (Exchange time). | 2015-05-17 18:11:57 HD Request # 73 | Error downloading historical Intraday data for NQ-201506-GLOBEX. Error executing query: Invalid symbol | 2015-05-17 18:11:57 * HD Request # 73 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201506-GLOBEX | 2015-05-17 18:11:57 HD Request # 73 | Intraday download COMPLETE for NQ-201506-GLOBEX. Completion time: 0s. Unique request ID: 61 | 2015-05-17 18:11:57 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-05-17 18:11:57 HD Request # 74 | Downloading Intraday chart data for NQ-201506-GLOBEX to the file NQ-201506-GLOBEX.scid. Service: ddf | 2015-05-17 18:11:57 HD Request # 74 | Rounding start Date-Time down to the minute: 2015-01-17 17:11:00.0 | 2015-05-17 18:11:57 HD Request # 74 | Download start Date-Time: 2015-01-17 17:11:00.0 | 2015-05-17 18:11:57 HD Request # 74 | Using user Barchart Historical data account. | 2015-05-17 18:11:57 HD Request # 74 | Requesting historical Intraday Tick data for NQ-201506-GLOBEX starting at 2015-04-16 18:11:57 (Exchange time). | 2015-05-17 18:11:57 HD Request # 74 | Error downloading historical Intraday data for NQ-201506-GLOBEX. Error executing query: Invalid symbol | 2015-05-17 18:11:57 * HD Request # 74 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201506-GLOBEX | 2015-05-17 18:11:57 HD Request # 74 | Intraday download COMPLETE for NQ-201506-GLOBEX. Completion time: 0s. Unique request ID: 61 | 2015-05-17 18:11:57 Removed historical data download ID 61 | 2015-05-17 18:11:57 Real-time Intraday chart data file updates started for NQ-201506-GLOBEX | 2015-05-17 18:11:57 HD Request # 74 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:11:57 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-05-17 18:11:57 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQM15.scid | 2015-05-17 18:12:20 SC Historical Data | Starting real-time market data updates for: NQM15. ID: 12 | 2015-05-17 18:12:21 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: NQM15 | 2015-05-17 18:12:21 Intraday data recording state for symbol NQM15 is set to download pending. | 2015-05-17 18:12:21 HD Request # 75 | Downloading Intraday chart data for NQM15 to the file NQM15.scid. Service: cme | 2015-05-17 18:12:21 Compressing file: C:\SierraChart\Data\NQM15.scid. This may take a while. | 2015-05-17 18:12:21 HD Request # 75 | Download start Date-Time: 2015-01-17 17:12:21.0 | 2015-05-17 18:12:21 HD Request # 75 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-17 18:12:21 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-17 18:12:21 Socket (57) | Connected. | 2015-05-17 18:12:21 HD Request # 75 | Sending historical data logon request message. | 2015-05-17 18:12:21 HD Request # 75 | Requesting Intraday data. Start Date-Time: 2015-01-17 17:12:21. Record interval: 0. Symbol: NQM15 | 2015-05-17 18:12:21 HD Request # 75 | Decompressing data. | 2015-05-17 18:12:21 HD Request # 75 | Receiving Intraday data for NQM15 starting at 2015-01-20 00:31:46 | 2015-05-17 18:12:21 HD Request # 75 | Timestamp of first Intraday data file record written: 2015-01-20 00:31:46 | 2015-05-17 18:12:21 Socket (57) | Shutdown and closed. | 2015-05-17 18:12:40 The network socket for historical data has been closed. | 2015-05-17 18:12:40 HD Request # 75 | Received 6477924 records from 2015-01-20 00:31:46 to 2015-05-17 18:02:15 (117.7 days) and wrote 6477924 records for NQM15 | 2015-05-17 18:12:40 HD Request # 75 | Intraday download COMPLETE for NQM15. Completion time: 19s. Unique request ID: 62 | 2015-05-17 18:12:40 Removed historical data download ID 62 | 2015-05-17 18:12:40 Real-time Intraday chart data file updates started for NQM15 | 2015-05-17 18:12:40 HD Request # 76 | Downloading Historical Daily chart data for AAPL. Starting date: 2015-05-14. Service: ddf | 2015-05-17 18:17:25 HD Request # 76 | Using user Barchart Historical data account. | 2015-05-17 18:17:25 HD Request # 76 | Requesting historical Daily data for AAPL starting at 2015-05-13 | 2015-05-17 18:17:25 HD Request # 76 | Receiving historical Daily data for AAPL starting at 2015-05-13 | 2015-05-17 18:17:25 Writing historical Daily data for AAPL to the file AAPL.dly | 2015-05-17 18:17:25 HD Request # 76 | Received 3 records from 2015-05-13 00:00:00 to 2015-05-15 00:00:00 (3.0 days) and wrote 2 records for AAPL | 2015-05-17 18:17:25 HD Request # 76 | Daily download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 63 | 2015-05-17 18:17:25 Removed historical data download ID 63 | 2015-05-17 18:17:25 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 18:17:59 Reloading all charts with filename: AAPL.scid | 2015-05-17 18:17:59 HD Request # 77 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ddf | 2015-05-17 18:17:59 HD Request # 77 | Performing multistage download. Downloading Minute data first. | 2015-05-17 18:17:59 HD Request # 77 | Download start Date-Time: 2015-01-17 17:17:59.0 | 2015-05-17 18:17:59 HD Request # 77 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 18:17:59 HD Request # 77 | Using user Barchart Historical data account. | 2015-05-17 18:17:59 HD Request # 77 | Requesting historical Intraday Minute data for AAPL starting at 2015-01-17 17:17:59 (Exchange time). | 2015-05-17 18:17:59 HD Request # 77 | Receiving Intraday data for AAPL starting at 2015-01-20 07:29:00 | 2015-05-17 18:18:00 HD Request # 77 | Timestamp of first Intraday data file record written: 2015-01-20 07:29:00 | 2015-05-17 18:18:00 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\AAPL.scid | 2015-05-17 18:18:00 HD Request # 77 | Received 56657 records from 2015-01-20 07:29:00 to 2015-05-15 19:59:00 (115.5 days) and wrote 56657 records for AAPL | 2015-05-17 18:18:02 HD Request # 77 | Intraday download COMPLETE for AAPL. Completion time: 3s. Unique request ID: 64 | 2015-05-17 18:18:02 HD Request # 78 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ddf | 2015-05-17 18:18:02 HD Request # 78 | Rounding start Date-Time down to the minute: 2015-01-17 17:17:00.0 | 2015-05-17 18:18:02 HD Request # 78 | Download start Date-Time: 2015-01-17 17:17:00.0 | 2015-05-17 18:18:02 HD Request # 78 | Using user Barchart Historical data account. | 2015-05-17 18:18:02 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-16 18:17:59 (Exchange time). | 2015-05-17 18:18:02 HD Request # 78 | Receiving Intraday data for AAPL starting at 2015-04-16 18:18:02 | 2015-05-17 18:18:02 HD Request # 78 | Truncating Intraday data file at 2015-04-16 18:18:02 while receiving initial tick data during multistage download. | 2015-05-17 18:18:02 HD Request # 78 | Date-time after truncate 2015-04-16 18:18:00 | 2015-05-17 18:18:02 HD Request # 78 | Timestamp of first Intraday data file record written: 2015-04-16 18:18:02 | 2015-05-17 18:18:02 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-17 00:00:00 (Exchange time). | 2015-05-17 18:18:02 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-18 00:00:00 (Exchange time). | 2015-05-17 18:18:05 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-19 00:00:00 (Exchange time). | 2015-05-17 18:18:05 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-20 00:00:00 (Exchange time). | 2015-05-17 18:18:05 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-21 00:00:00 (Exchange time). | 2015-05-17 18:18:07 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-22 00:00:00 (Exchange time). | 2015-05-17 18:18:09 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-23 00:00:00 (Exchange time). | 2015-05-17 18:18:11 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-24 00:00:00 (Exchange time). | 2015-05-17 18:18:13 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-25 00:00:00 (Exchange time). | 2015-05-17 18:18:15 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-26 00:00:00 (Exchange time). | 2015-05-17 18:18:15 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-27 00:00:00 (Exchange time). | 2015-05-17 18:18:15 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-28 00:00:00 (Exchange time). | 2015-05-17 18:18:21 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-29 00:00:00 (Exchange time). | 2015-05-17 18:18:27 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-30 00:00:00 (Exchange time). | 2015-05-17 18:18:30 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-01 00:00:00 (Exchange time). | 2015-05-17 18:18:33 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-02 00:00:00 (Exchange time). | 2015-05-17 18:18:36 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-03 00:00:00 (Exchange time). | 2015-05-17 18:18:36 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-04 00:00:00 (Exchange time). | 2015-05-17 18:18:36 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-05 00:00:00 (Exchange time). | 2015-05-17 18:18:38 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-06 00:00:00 (Exchange time). | 2015-05-17 18:18:41 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-07 00:00:00 (Exchange time). | 2015-05-17 18:18:44 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-08 00:00:00 (Exchange time). | 2015-05-17 18:18:46 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-09 00:00:00 (Exchange time). | 2015-05-17 18:18:48 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-10 00:00:00 (Exchange time). | 2015-05-17 18:18:48 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-11 00:00:00 (Exchange time). | 2015-05-17 18:18:48 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-12 00:00:00 (Exchange time). | 2015-05-17 18:18:50 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-13 00:00:00 (Exchange time). | 2015-05-17 18:18:52 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-14 00:00:00 (Exchange time). | 2015-05-17 18:18:53 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-15 00:00:00 (Exchange time). | 2015-05-17 18:18:55 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 18:18:57 HD Request # 78 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 18:18:57 HD Request # 78 | Received 4332319 records from 2015-04-16 18:18:02 to 2015-05-15 19:59:50 (29.1 days) and wrote 4332291 records for AAPL | 2015-05-17 18:18:57 HD Request # 78 | Intraday download COMPLETE for AAPL. Completion time: 55s. Unique request ID: 64 | 2015-05-17 18:18:57 Removed historical data download ID 64 | 2015-05-17 18:18:57 Real-time Intraday chart data file updates started for AAPL | 2015-05-17 18:18:57 HD Request # 78 | Enabling Intraday chart updating for symbol. | 2015-05-17 18:18:57 HD Request # 78 | Reloading Intraday charts for symbol. | 2015-05-17 18:18:57 Reloading all charts with filename: AAPL.scid | 2015-05-17 18:18:57 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-17 22:31:49 HD Request # 79 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ddf | 2015-05-17 22:31:49 HD Request # 79 | Truncating file to starting Date-Time of 2013-05-27 20:00:00 | 2015-05-17 22:31:49 HD Request # 79 | Performing multistage download. Downloading Minute data first. | 2015-05-17 22:31:49 HD Request # 79 | Download start Date-Time: 2013-05-27 19:59:59.0 | 2015-05-17 22:31:49 HD Request # 79 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 22:31:49 HD Request # 79 | Using user Barchart Historical data account. | 2015-05-17 22:31:49 HD Request # 79 | Requesting historical Intraday Minute data for AAPL starting at 2013-05-27 19:59:59 (Exchange time). | 2015-05-17 22:31:49 HD Request # 79 | Receiving Intraday data for AAPL starting at 2013-05-28 04:36:00 | 2015-05-17 22:31:50 HD Request # 79 | Timestamp of first Intraday data file record written: 2013-05-28 04:36:00 | 2015-05-17 22:31:50 HD Request # 79 | Received 313501 records from 2013-05-28 04:36:00 to 2015-05-15 19:59:00 (717.6 days) and wrote 313501 records for AAPL | 2015-05-17 22:31:57 HD Request # 79 | Intraday download COMPLETE for AAPL. Completion time: 8s. Unique request ID: 65 | 2015-05-17 22:31:57 HD Request # 79 | Reloading Intraday charts for symbol. | 2015-05-17 22:31:57 Reloading all charts with filename: AAPL.scid | 2015-05-17 22:31:57 HD Request # 80 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ddf | 2015-05-17 22:31:57 HD Request # 80 | Rounding start Date-Time down to the minute: 2015-01-17 21:31:00.0 | 2015-05-17 22:31:57 HD Request # 80 | Download start Date-Time: 2015-01-17 21:31:00.0 | 2015-05-17 22:31:57 HD Request # 80 | Using user Barchart Historical data account. | 2015-05-17 22:31:57 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-16 22:31:49 (Exchange time). | 2015-05-17 22:31:57 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-17 00:00:00 (Exchange time). | 2015-05-17 22:31:57 HD Request # 80 | Receiving Intraday data for AAPL starting at 2015-04-17 07:50:45 | 2015-05-17 22:31:58 HD Request # 80 | Truncating Intraday data file at 2015-04-17 07:50:45 while receiving initial tick data during multistage download. | 2015-05-17 22:31:58 HD Request # 80 | Date-time after truncate 2015-04-17 07:50:00 | 2015-05-17 22:31:58 HD Request # 80 | Timestamp of first Intraday data file record written: 2015-04-17 07:50:45 | 2015-05-17 22:31:58 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-18 00:00:00 (Exchange time). | 2015-05-17 22:32:01 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-19 00:00:00 (Exchange time). | 2015-05-17 22:32:01 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-20 00:00:00 (Exchange time). | 2015-05-17 22:32:01 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-21 00:00:00 (Exchange time). | 2015-05-17 22:32:03 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-22 00:00:00 (Exchange time). | 2015-05-17 22:32:05 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-23 00:00:00 (Exchange time). | 2015-05-17 22:32:07 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-24 00:00:00 (Exchange time). | 2015-05-17 22:32:09 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-25 00:00:00 (Exchange time). | 2015-05-17 22:32:11 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-26 00:00:00 (Exchange time). | 2015-05-17 22:32:11 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-27 00:00:00 (Exchange time). | 2015-05-17 22:32:11 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-28 00:00:00 (Exchange time). | 2015-05-17 22:32:15 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-29 00:00:00 (Exchange time). | 2015-05-17 22:32:22 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-04-30 00:00:00 (Exchange time). | 2015-05-17 22:32:26 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-01 00:00:00 (Exchange time). | 2015-05-17 22:32:30 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-02 00:00:00 (Exchange time). | 2015-05-17 22:32:32 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-03 00:00:00 (Exchange time). | 2015-05-17 22:32:32 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-04 00:00:00 (Exchange time). | 2015-05-17 22:32:32 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-05 00:00:00 (Exchange time). | 2015-05-17 22:32:34 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-06 00:00:00 (Exchange time). | 2015-05-17 22:32:37 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-07 00:00:00 (Exchange time). | 2015-05-17 22:32:42 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-08 00:00:00 (Exchange time). | 2015-05-17 22:32:45 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-09 00:00:00 (Exchange time). | 2015-05-17 22:32:48 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-10 00:00:00 (Exchange time). | 2015-05-17 22:32:48 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-11 00:00:00 (Exchange time). | 2015-05-17 22:32:48 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-12 00:00:00 (Exchange time). | 2015-05-17 22:32:51 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-13 00:00:00 (Exchange time). | 2015-05-17 22:32:53 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-14 00:00:00 (Exchange time). | 2015-05-17 22:32:54 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-15 00:00:00 (Exchange time). | 2015-05-17 22:32:58 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 22:33:00 HD Request # 80 | Requesting historical Intraday Tick data for AAPL starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 22:33:00 HD Request # 80 | Received 4332161 records from 2015-04-17 07:50:45 to 2015-05-15 19:59:50 (28.5 days) and wrote 4332133 records for AAPL | 2015-05-17 22:33:00 HD Request # 80 | Intraday download COMPLETE for AAPL. Completion time: 1m 3s. Unique request ID: 65 | 2015-05-17 22:33:00 Removed historical data download ID 65 | 2015-05-17 22:33:00 Real-time Intraday chart data file updates started for AAPL | 2015-05-17 22:33:00 HD Request # 80 | Enabling Intraday chart updating for symbol. | 2015-05-17 22:33:00 HD Request # 80 | Reloading Intraday charts for symbol. | 2015-05-17 22:33:00 Reloading all charts with filename: AAPL.scid | 2015-05-17 22:33:00 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\$PFE.scid | 2015-05-17 23:36:31 SC Historical Data | Starting real-time market data updates for: $PFE. ID: 13 | 2015-05-17 23:36:31 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: $PFE | 2015-05-17 23:36:31 Intraday data recording state for symbol $PFE is set to download pending. | 2015-05-17 23:36:31 HD Request # 81 | Downloading Intraday chart data for $PFE to the file $PFE.scid. Service: ddf | 2015-05-17 23:36:31 HD Request # 81 | Performing multistage download. Downloading Minute data first. | 2015-05-17 23:36:31 HD Request # 81 | Download start Date-Time: 2015-01-17 22:36:31.0 | 2015-05-17 23:36:31 HD Request # 81 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 23:36:31 HD Request # 81 | Using user Barchart Historical data account. | 2015-05-17 23:36:31 HD Request # 81 | Requesting historical Intraday Minute data for $PFE starting at 2015-01-17 22:36:31 (Exchange time). | 2015-05-17 23:36:31 HD Request # 81 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $PFE | 2015-05-17 23:36:31 HD Request # 81 | Intraday download COMPLETE for $PFE. Completion time: 0s. Unique request ID: 66 | 2015-05-17 23:36:31 HD Request # 82 | Downloading Intraday chart data for $PFE to the file $PFE.scid. Service: ddf | 2015-05-17 23:36:31 HD Request # 82 | Rounding start Date-Time down to the minute: 2015-01-17 22:36:00.0 | 2015-05-17 23:36:31 HD Request # 82 | Download start Date-Time: 2015-01-17 22:36:00.0 | 2015-05-17 23:36:31 HD Request # 82 | Using user Barchart Historical data account. | 2015-05-17 23:36:31 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-16 23:36:31 (Exchange time). | 2015-05-17 23:36:31 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-17 00:00:00 (Exchange time). | 2015-05-17 23:36:31 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-18 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-19 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-20 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-21 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-22 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-23 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-24 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-25 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-26 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-27 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-28 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-29 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-04-30 00:00:00 (Exchange time). | 2015-05-17 23:36:32 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-01 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-02 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-03 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-04 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-05 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-06 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-07 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-08 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-09 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-10 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-11 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-12 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-13 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-14 00:00:00 (Exchange time). | 2015-05-17 23:36:33 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-15 00:00:00 (Exchange time). | 2015-05-17 23:36:34 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 23:36:34 HD Request # 82 | Requesting historical Intraday Tick data for $PFE starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 23:36:34 HD Request # 82 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $PFE | 2015-05-17 23:36:34 HD Request # 82 | Intraday download COMPLETE for $PFE. Completion time: 3s. Unique request ID: 66 | 2015-05-17 23:36:34 Removed historical data download ID 66 | 2015-05-17 23:36:34 Real-time Intraday chart data file updates started for $PFE | 2015-05-17 23:36:34 HD Request # 82 | Enabling Intraday chart updating for symbol. | 2015-05-17 23:36:34 Requesting market depth updates for: $PFE if supported. | 2015-05-17 23:36:34 SC Historical Data | Starting real-time market data updates for: DAL. ID: 14 | 2015-05-17 23:36:48 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: DAL | 2015-05-17 23:36:48 Intraday data recording state for symbol DAL is set to download pending. | 2015-05-17 23:36:48 HD Request # 83 | Downloading Intraday chart data for DAL to the file DAL.scid. Service: ddf | 2015-05-17 23:36:48 HD Request # 83 | Performing multistage download. Downloading Minute data first. | 2015-05-17 23:36:48 HD Request # 83 | Download start Date-Time: 2015-04-02 09:38:43.0 | 2015-05-17 23:36:48 HD Request # 83 | Disabling Intraday chart updating for symbol during historical data download. | 2015-05-17 23:36:48 HD Request # 83 | Using user Barchart Historical data account. | 2015-05-17 23:36:48 HD Request # 83 | Requesting historical Intraday Minute data for DAL starting at 2015-04-02 09:38:43 (Exchange time). | 2015-05-17 23:36:48 HD Request # 83 | Receiving Intraday data for DAL starting at 2015-04-02 09:39:00 | 2015-05-17 23:36:48 HD Request # 83 | Timestamp of first Intraday data file record written: 2015-04-02 09:39:00 | 2015-05-17 23:36:48 Unsubscribed from market depth data for AAPL | 2015-05-17 23:36:49 Requesting market depth updates for: DAL if supported. | 2015-05-17 23:36:49 HD Request # 83 | Received 13279 records from 2015-04-02 09:39:00 to 2015-05-15 19:19:00 (43.4 days) and wrote 13279 records for DAL | 2015-05-17 23:36:50 HD Request # 83 | Intraday download COMPLETE for DAL. Completion time: 2s. Unique request ID: 67 | 2015-05-17 23:36:50 HD Request # 84 | Downloading Intraday chart data for DAL to the file DAL.scid. Service: ddf | 2015-05-17 23:36:50 HD Request # 84 | Rounding start Date-Time down to the minute: 2015-04-02 09:38:00.0 | 2015-05-17 23:36:50 HD Request # 84 | Download start Date-Time: 2015-04-02 09:38:00.0 | 2015-05-17 23:36:50 HD Request # 84 | Using user Barchart Historical data account. | 2015-05-17 23:36:50 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-16 23:36:48 (Exchange time). | 2015-05-17 23:36:50 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-17 00:00:00 (Exchange time). | 2015-05-17 23:36:50 HD Request # 84 | Receiving Intraday data for DAL starting at 2015-04-17 09:30:13 | 2015-05-17 23:36:50 HD Request # 84 | Truncating Intraday data file at 2015-04-17 09:30:13 while receiving initial tick data during multistage download. | 2015-05-17 23:36:50 HD Request # 84 | Date-time after truncate 2015-04-17 09:30:00 | 2015-05-17 23:36:50 HD Request # 84 | Timestamp of first Intraday data file record written: 2015-04-17 09:30:13 | 2015-05-17 23:36:50 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-18 00:00:00 (Exchange time). | 2015-05-17 23:36:51 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-19 00:00:00 (Exchange time). | 2015-05-17 23:36:51 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-20 00:00:00 (Exchange time). | 2015-05-17 23:36:51 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-21 00:00:00 (Exchange time). | 2015-05-17 23:36:52 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-22 00:00:00 (Exchange time). | 2015-05-17 23:36:53 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-23 00:00:00 (Exchange time). | 2015-05-17 23:36:53 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-24 00:00:00 (Exchange time). | 2015-05-17 23:36:54 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-25 00:00:00 (Exchange time). | 2015-05-17 23:36:55 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-26 00:00:00 (Exchange time). | 2015-05-17 23:36:55 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-27 00:00:00 (Exchange time). | 2015-05-17 23:36:55 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-28 00:00:00 (Exchange time). | 2015-05-17 23:36:55 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-29 00:00:00 (Exchange time). | 2015-05-17 23:36:56 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-04-30 00:00:00 (Exchange time). | 2015-05-17 23:36:57 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-01 00:00:00 (Exchange time). | 2015-05-17 23:36:57 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-02 00:00:00 (Exchange time). | 2015-05-17 23:36:58 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-03 00:00:00 (Exchange time). | 2015-05-17 23:36:58 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-04 00:00:00 (Exchange time). | 2015-05-17 23:36:58 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-05 00:00:00 (Exchange time). | 2015-05-17 23:36:59 Unsubscribed from market depth data for DAL | 2015-05-17 23:36:59 Requesting market depth updates for: AAPL if supported. | 2015-05-17 23:36:59 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-06 00:00:00 (Exchange time). | 2015-05-17 23:36:59 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-07 00:00:00 (Exchange time). | 2015-05-17 23:37:00 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-08 00:00:00 (Exchange time). | 2015-05-17 23:37:01 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-09 00:00:00 (Exchange time). | 2015-05-17 23:37:02 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-10 00:00:00 (Exchange time). | 2015-05-17 23:37:02 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-11 00:00:00 (Exchange time). | 2015-05-17 23:37:02 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-12 00:00:00 (Exchange time). | 2015-05-17 23:37:03 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-13 00:00:00 (Exchange time). | 2015-05-17 23:37:03 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-14 00:00:00 (Exchange time). | 2015-05-17 23:37:04 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-15 00:00:00 (Exchange time). | 2015-05-17 23:37:05 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-16 00:00:00 (Exchange time). | 2015-05-17 23:37:05 HD Request # 84 | Requesting historical Intraday Tick data for DAL starting at 2015-05-17 00:00:00 (Exchange time). | 2015-05-17 23:37:05 HD Request # 84 | Received 993809 records from 2015-04-17 09:30:13 to 2015-05-15 19:19:10 (28.4 days) and wrote 993808 records for DAL | 2015-05-17 23:37:05 HD Request # 84 | Intraday download COMPLETE for DAL. Completion time: 15s. Unique request ID: 67 | 2015-05-17 23:37:05 Removed historical data download ID 67 | 2015-05-17 23:37:05 Real-time Intraday chart data file updates started for DAL | 2015-05-17 23:37:05 HD Request # 84 | Enabling Intraday chart updating for symbol. | 2015-05-17 23:37:05 HD Request # 84 | Reloading Intraday charts for symbol. | 2015-05-17 23:37:05 Reloading all charts with filename: DAL.scid | 2015-05-17 23:37:05 HD Request # 85 | Downloading Historical Daily chart data for IBB. Starting date: 1965-05-17. Service: ddf | 2015-05-17 23:50:01 HD Request # 85 | Using user Barchart Historical data account. | 2015-05-17 23:50:01 HD Request # 85 | Requesting historical Daily data for IBB starting at 1965-05-16 | 2015-05-17 23:50:01 HD Request # 85 | Receiving historical Daily data for IBB starting at 2001-02-09 | 2015-05-17 23:50:01 Writing historical Daily data for IBB to the file IBB.dly | 2015-05-17 23:50:01 HD Request # 85 | Received 3587 records from 2001-02-09 00:00:00 to 2015-05-15 00:00:00 (14.3 years) and wrote 3587 records for IBB | 2015-05-17 23:50:02 HD Request # 85 | Daily download COMPLETE for IBB. Completion time: 1s. Unique request ID: 68 | 2015-05-17 23:50:02 Removed historical data download ID 68 | 2015-05-17 23:50:02 HD Request # 86 | Downloading Historical Daily chart data for CMG. Starting date: 2015-04-30. Service: ddf | 2015-05-18 00:00:58 HD Request # 86 | Using user Barchart Historical data account. | 2015-05-18 00:00:58 HD Request # 86 | Requesting historical Daily data for CMG starting at 2015-04-29 | 2015-05-18 00:00:58 HD Request # 86 | Receiving historical Daily data for CMG starting at 2015-04-29 | 2015-05-18 00:00:58 Writing historical Daily data for CMG to the file CMG.dly | 2015-05-18 00:00:58 HD Request # 86 | Received 13 records from 2015-04-29 00:00:00 to 2015-05-15 00:00:00 (17.0 days) and wrote 12 records for CMG | 2015-05-18 00:00:58 HD Request # 86 | Daily download COMPLETE for CMG. Completion time: 0s. Unique request ID: 69 | 2015-05-18 00:00:58 Removed historical data download ID 69 | 2015-05-18 00:00:58 SC Historical Data | Starting real-time market data updates for: @ES#. ID: 15 | 2015-05-18 00:13:04 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: @ES# | 2015-05-18 00:13:04 HD Request # 87 | Downloading Historical Daily chart data for @ES#. Starting date: 2015-01-29. Service: ddf | 2015-05-18 00:13:04 HD Request # 87 | Using user Barchart Historical data account. | 2015-05-18 00:13:04 HD Request # 87 | Requesting historical Daily Continuous data for @ESZ10 starting at 2015-01-28 | 2015-05-18 00:13:04 HD Request # 87 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for @ES# | 2015-05-18 00:13:04 HD Request # 87 | Daily download COMPLETE for @ES#. Completion time: 0s. Unique request ID: 70 | 2015-05-18 00:13:04 Removed historical data download ID 70 | 2015-05-18 00:13:04 Requesting market depth updates for: @ES# if supported. | 2015-05-18 00:13:07 Unsubscribed from market depth data for @ES# | 2015-05-18 00:13:12 Current selected Data/Trading service: SC Exchange Data | 2015-05-18 09:30:58 Checking for new symbol settings for scbcd | 2015-05-18 09:30:58 SC Historical Data | Disconnected | 2015-05-18 09:30:58 NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2015-05-18 09:30:58 SC Exchange Data | Connected. | 2015-05-18 09:30:58 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-05-18 09:30:58 HTTP connection to www.sierrachart.com:80 (58) | Connected. | 2015-05-18 09:30:58 Mapping AAPL to AAPL. Service code: equities.us | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: AAPL. ID: 1 | 2015-05-18 09:30:58 Using username 0 | 2015-05-18 09:30:58 SC Exchange Data | Connecting to the server scdf2.sierracharts.com. Port 10047 | 2015-05-18 09:30:58 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-18 09:30:58 HD Request # 88 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: equities.us | 2015-05-18 09:30:58 HD Request # 88 | Download start Date-Time: 2015-05-15 19:59:50.0 | 2015-05-18 09:30:58 HD Request # 88 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:30:58 Mapping CMG to CMG. Service code: equities.us | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: CMG. ID: 2 | 2015-05-18 09:30:58 Mapping IBB to IBB. Service code: equities.us | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: IBB. ID: 3 | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: $PFE. ID: 4 | 2015-05-18 09:30:58 SC Exchange Data | Subscribing to market data in the service client is not supported. Symbol: $PFE | 2015-05-18 09:30:58 Intraday data recording state for symbol $PFE is set to download pending. | 2015-05-18 09:30:58 Mapping UWTI to UWTI. Service code: equities.us | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: UWTI. ID: 5 | 2015-05-18 09:30:58 Intraday data recording state for symbol UWTI is set to download pending. | 2015-05-18 09:30:58 Intraday data recording state for symbol IBB is set to download pending. | 2015-05-18 09:30:58 Mapping SMH to SMH. Service code: equities.us | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: SMH. ID: 6 | 2015-05-18 09:30:58 Intraday data recording state for symbol SMH is set to download pending. | 2015-05-18 09:30:58 Mapping ESPR to ESPR. Service code: equities.us | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: ESPR. ID: 7 | 2015-05-18 09:30:58 Intraday data recording state for symbol ESPR is set to download pending. | 2015-05-18 09:30:58 Mapping PFE to PFE. Service code: equities.us | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: PFE. ID: 8 | 2015-05-18 09:30:58 Intraday data recording state for symbol PFE is set to download pending. | 2015-05-18 09:30:58 Intraday data recording state for symbol CMG is set to download pending. | 2015-05-18 09:30:58 Mapping USO to USO. Service code: equities.us | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: USO. ID: 9 | 2015-05-18 09:30:58 Intraday data recording state for symbol USO is set to download pending. | 2015-05-18 09:30:58 Mapping FSL to FSL. Service code: equities.us | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: FSL. ID: 10 | 2015-05-18 09:30:58 Intraday data recording state for symbol FSL is set to download pending. | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: ES-201506-GLOBEX. ID: 11 | 2015-05-18 09:30:58 SC Exchange Data | Subscribing to market data in the service client is not supported. Symbol: ES-201506-GLOBEX | 2015-05-18 09:30:58 Intraday data recording state for symbol ES-201506-GLOBEX is set to download pending. | 2015-05-18 09:30:58 Mapping NQM15 to NQM15. Service code: cme | 2015-05-18 09:30:58 SC Exchange Data | Starting real-time market data updates for: NQM15. ID: 12 | 2015-05-18 09:30:58 Using username 0 | 2015-05-18 09:30:58 SC Exchange Data | Connecting to the server scdf2.sierracharts.com. Port 443 | 2015-05-18 09:30:58 Intraday data recording state for symbol NQM15 is set to download pending. | 2015-05-18 09:30:58 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:30:58 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:30:58 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:30:58 Socket (59) | Connected. | 2015-05-18 09:30:59 HD Request # 88 | Sending historical data logon request message. | 2015-05-18 09:30:59 Socket (60) | Connected. | 2015-05-18 09:30:59 SC Exchange Data | Connected to server. | 2015-05-18 09:30:59 SC Exchange Data | Sending logon request message. | 2015-05-18 09:30:59 Socket (61) | Connected. | 2015-05-18 09:30:59 SC Exchange Data | Connected to server. | 2015-05-18 09:30:59 SC Exchange Data | Sending logon request message. | 2015-05-18 09:30:59 Requesting symbol settings for scbcd. Overwrite = on. | 2015-05-18 09:30:59 HD Request # 88 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:50. Record interval: 0. Symbol: AAPL | 2015-05-18 09:30:59 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-05-18 09:30:59 SC Exchange Data | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-05-18 09:30:59 SC Exchange Data | Successfully connected. | 2015-05-18 09:30:59 SC Exchange Data | Restarting real-time data updates for symbol: NQM15 -> NQM15 | 2015-05-18 09:30:59 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-05-18 09:30:59 SC Exchange Data | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-05-18 09:30:59 SC Exchange Data | Successfully connected. | 2015-05-18 09:30:59 SC Exchange Data | Restarting real-time data updates for symbol: AAPL -> AAPL | 2015-05-18 09:30:59 SC Exchange Data | Restarting real-time data updates for symbol: CMG -> CMG | 2015-05-18 09:30:59 SC Exchange Data | Restarting real-time data updates for symbol: ESPR -> ESPR | 2015-05-18 09:30:59 SC Exchange Data | Restarting real-time data updates for symbol: FSL -> FSL | 2015-05-18 09:30:59 SC Exchange Data | Restarting real-time data updates for symbol: IBB -> IBB | 2015-05-18 09:30:59 SC Exchange Data | Restarting real-time data updates for symbol: PFE -> PFE | 2015-05-18 09:30:59 SC Exchange Data | Restarting real-time data updates for symbol: SMH -> SMH | 2015-05-18 09:30:59 SC Exchange Data | Restarting real-time data updates for symbol: USO -> USO | 2015-05-18 09:30:59 SC Exchange Data | Restarting real-time data updates for symbol: UWTI -> UWTI | 2015-05-18 09:30:59 HD Request # 88 | Decompressing data. | 2015-05-18 09:30:59 HD Request # 88 | Receiving Intraday data for AAPL starting at 2015-05-15 19:59:50 | 2015-05-18 09:30:59 HD Request # 88 | Timestamp of first Intraday data file record written: 2015-05-18 06:47:40 | 2015-05-18 09:30:59 Symbol Error - NQM15 is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:30:59 Symbol Error - AAPL is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:30:59 Symbol Error - CMG is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:30:59 Symbol Error - ESPR is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:30:59 Symbol Error - FSL is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:30:59 Symbol Error - IBB is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:30:59 Symbol Error - PFE is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:30:59 Symbol Error - SMH is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:30:59 Symbol Error - USO is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:30:59 Symbol Error - UWTI is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:30:59 Socket (59) | Shutdown and closed. | 2015-05-18 09:30:59 The network socket for historical data has been closed. | 2015-05-18 09:30:59 HD Request # 88 | Received 575 records from 2015-05-15 19:59:50 to 2015-05-18 09:15:57 (2.6 days) and wrote 574 records for AAPL | 2015-05-18 09:30:59 HD Request # 88 | Intraday download COMPLETE for AAPL. Completion time: 1s. Unique request ID: 71 | 2015-05-18 09:30:59 Removed historical data download ID 71 | 2015-05-18 09:30:59 Real-time Intraday chart data file updates started for AAPL | 2015-05-18 09:30:59 HD Request # 89 | Downloading Intraday chart data for $PFE to the file $PFE.scid. Service: scbcd | 2015-05-18 09:30:59 HD Request # 89 | Download start Date-Time: 2015-01-18 08:30:59.0 | 2015-05-18 09:30:59 HD Request # 89 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:30:59 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:30:59 Socket (62) | Connected. | 2015-05-18 09:30:59 HD Request # 89 | Sending historical data logon request message. | 2015-05-18 09:30:59 HD Request # 89 | Error downloading historical Intraday data for $PFE. Historical data logon error: Invalid/missing data for service code: scbcd | 2015-05-18 09:30:59 * Socket (62) | Shutdown and closed. | 2015-05-18 09:30:59 The network socket for historical data has been closed. | 2015-05-18 09:30:59 HD Request # 89 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $PFE | 2015-05-18 09:30:59 HD Request # 89 | Intraday download COMPLETE for $PFE. Completion time: 0s. Unique request ID: 72 | 2015-05-18 09:30:59 Removed historical data download ID 72 | 2015-05-18 09:30:59 Real-time Intraday chart data file updates started for $PFE | 2015-05-18 09:30:59 HD Request # 90 | Downloading Intraday chart data for UWTI to the file UWTI.scid. Service: equities.us | 2015-05-18 09:30:59 HD Request # 90 | Download start Date-Time: 2015-05-15 19:59:55.0 | 2015-05-18 09:30:59 HD Request # 90 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:30:59 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:30:59 Socket (63) | Connected. | 2015-05-18 09:30:59 HD Request # 90 | Sending historical data logon request message. | 2015-05-18 09:30:59 HD Request # 90 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:55. Record interval: 0. Symbol: UWTI | 2015-05-18 09:30:59 HD Request # 90 | Decompressing data. | 2015-05-18 09:30:59 HD Request # 90 | Receiving Intraday data for UWTI starting at 2015-05-15 19:59:55 | 2015-05-18 09:30:59 HD Request # 90 | Timestamp of first Intraday data file record written: 2015-05-18 07:36:23 | 2015-05-18 09:30:59 Socket (63) | Shutdown and closed. | 2015-05-18 09:30:59 The network socket for historical data has been closed. | 2015-05-18 09:30:59 HD Request # 90 | Received 690 records from 2015-05-15 19:59:55 to 2015-05-18 09:15:54 (2.6 days) and wrote 689 records for UWTI | 2015-05-18 09:30:59 HD Request # 90 | Intraday download COMPLETE for UWTI. Completion time: 0s. Unique request ID: 73 | 2015-05-18 09:30:59 Removed historical data download ID 73 | 2015-05-18 09:30:59 Real-time Intraday chart data file updates started for UWTI | 2015-05-18 09:30:59 HD Request # 91 | Downloading Intraday chart data for IBB to the file IBB.scid. Service: equities.us | 2015-05-18 09:30:59 HD Request # 91 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-18 09:30:59 HD Request # 91 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:30:59 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:30:59 Socket (64) | Connected. | 2015-05-18 09:30:59 HD Request # 91 | Sending historical data logon request message. | 2015-05-18 09:30:59 HD Request # 91 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: IBB | 2015-05-18 09:30:59 HD Request # 91 | Decompressing data. | 2015-05-18 09:30:59 HD Request # 91 | Receiving Intraday data for IBB starting at 2015-05-18 05:21:52 | 2015-05-18 09:30:59 HD Request # 91 | Timestamp of first Intraday data file record written: 2015-05-18 05:21:52 | 2015-05-18 09:30:59 Socket (64) | Shutdown and closed. | 2015-05-18 09:30:59 The network socket for historical data has been closed. | 2015-05-18 09:30:59 HD Request # 91 | Received 6 records from 2015-05-18 05:21:52 to 2015-05-18 09:10:04 (3.8 hours) and wrote 6 records for IBB | 2015-05-18 09:30:59 HD Request # 91 | Intraday download COMPLETE for IBB. Completion time: 0s. Unique request ID: 74 | 2015-05-18 09:30:59 Removed historical data download ID 74 | 2015-05-18 09:30:59 Real-time Intraday chart data file updates started for IBB | 2015-05-18 09:30:59 HD Request # 92 | Downloading Intraday chart data for SMH to the file SMH.scid. Service: equities.us | 2015-05-18 09:30:59 HD Request # 92 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-18 09:30:59 HD Request # 92 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:30:59 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:30:59 Socket (65) | Connected. | 2015-05-18 09:30:59 HD Request # 92 | Sending historical data logon request message. | 2015-05-18 09:30:59 HD Request # 92 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: SMH | 2015-05-18 09:31:00 HD Request # 92 | Decompressing data. | 2015-05-18 09:31:00 HD Request # 92 | Receiving Intraday data for SMH starting at 2015-05-14 09:30:02 | 2015-05-18 09:31:00 Socket (65) | Shutdown and closed. | 2015-05-18 09:31:00 The network socket for historical data has been closed. | 2015-05-18 09:31:00 HD Request # 92 | Received 10736 records from 2015-05-14 09:30:02 to 2015-05-15 16:00:21 (30.5 hours) and wrote 0 records for SMH | 2015-05-18 09:31:00 HD Request # 92 | Intraday download COMPLETE for SMH. Completion time: 1s. Unique request ID: 75 | 2015-05-18 09:31:00 Removed historical data download ID 75 | 2015-05-18 09:31:00 Real-time Intraday chart data file updates started for SMH | 2015-05-18 09:31:00 HD Request # 93 | Downloading Intraday chart data for ESPR to the file ESPR.scid. Service: equities.us | 2015-05-18 09:31:00 HD Request # 93 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-18 09:31:00 HD Request # 93 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:31:00 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:31:00 Socket (66) | Connected. | 2015-05-18 09:31:01 HD Request # 93 | Sending historical data logon request message. | 2015-05-18 09:31:01 HD Request # 93 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: ESPR | 2015-05-18 09:31:01 HD Request # 93 | Decompressing data. | 2015-05-18 09:31:01 HD Request # 93 | Receiving Intraday data for ESPR starting at 2015-05-13 15:59:59 | 2015-05-18 09:31:01 Socket (66) | Shutdown and closed. | 2015-05-18 09:31:01 The network socket for historical data has been closed. | 2015-05-18 09:31:01 HD Request # 93 | Received 2288 records from 2015-05-13 15:59:59 to 2015-05-15 15:59:58 (48.0 hours) and wrote 0 records for ESPR | 2015-05-18 09:31:01 HD Request # 93 | Intraday download COMPLETE for ESPR. Completion time: 0s. Unique request ID: 76 | 2015-05-18 09:31:01 Removed historical data download ID 76 | 2015-05-18 09:31:01 Real-time Intraday chart data file updates started for ESPR | 2015-05-18 09:31:01 HD Request # 94 | Downloading Intraday chart data for PFE to the file PFE.scid. Service: equities.us | 2015-05-18 09:31:01 HD Request # 94 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-18 09:31:01 HD Request # 94 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:31:01 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:31:01 Socket (67) | Connected. | 2015-05-18 09:31:01 HD Request # 94 | Sending historical data logon request message. | 2015-05-18 09:31:01 HD Request # 94 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: PFE | 2015-05-18 09:31:01 HD Request # 94 | Decompressing data. | 2015-05-18 09:31:01 HD Request # 94 | Receiving Intraday data for PFE starting at 2015-05-18 08:41:30 | 2015-05-18 09:31:01 HD Request # 94 | Timestamp of first Intraday data file record written: 2015-05-18 08:41:30 | 2015-05-18 09:31:01 Socket (67) | Shutdown and closed. | 2015-05-18 09:31:01 The network socket for historical data has been closed. | 2015-05-18 09:31:01 HD Request # 94 | Received 3 records from 2015-05-18 08:41:30 to 2015-05-18 08:59:20 (17.8 minutes) and wrote 3 records for PFE | 2015-05-18 09:31:01 HD Request # 94 | Intraday download COMPLETE for PFE. Completion time: 0s. Unique request ID: 77 | 2015-05-18 09:31:01 Removed historical data download ID 77 | 2015-05-18 09:31:01 Real-time Intraday chart data file updates started for PFE | 2015-05-18 09:31:01 HD Request # 95 | Downloading Intraday chart data for CMG to the file CMG.scid. Service: equities.us | 2015-05-18 09:31:01 HD Request # 95 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-18 09:31:01 HD Request # 95 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:31:01 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:31:01 Socket (68) | Connected. | 2015-05-18 09:31:01 HD Request # 95 | Sending historical data logon request message. | 2015-05-18 09:31:01 HD Request # 95 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: CMG | 2015-05-18 09:31:01 HD Request # 95 | Decompressing data. | 2015-05-18 09:31:02 Socket (68) | Shutdown and closed. | 2015-05-18 09:31:02 The network socket for historical data has been closed. | 2015-05-18 09:31:02 HD Request # 95 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CMG | 2015-05-18 09:31:02 HD Request # 95 | Intraday download COMPLETE for CMG. Completion time: 1s. Unique request ID: 78 | 2015-05-18 09:31:02 Removed historical data download ID 78 | 2015-05-18 09:31:02 Real-time Intraday chart data file updates started for CMG | 2015-05-18 09:31:02 HD Request # 96 | Downloading Intraday chart data for USO to the file USO.scid. Service: equities.us | 2015-05-18 09:31:02 HD Request # 96 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-18 09:31:02 HD Request # 96 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:31:02 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:31:02 Socket (69) | Connected. | 2015-05-18 09:31:02 HD Request # 96 | Sending historical data logon request message. | 2015-05-18 09:31:02 HD Request # 96 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: USO | 2015-05-18 09:31:02 HD Request # 96 | Decompressing data. | 2015-05-18 09:31:02 HD Request # 96 | Receiving Intraday data for USO starting at 2015-05-18 07:40:55 | 2015-05-18 09:31:02 HD Request # 96 | Timestamp of first Intraday data file record written: 2015-05-18 07:40:55 | 2015-05-18 09:31:02 Socket (69) | Shutdown and closed. | 2015-05-18 09:31:02 The network socket for historical data has been closed. | 2015-05-18 09:31:02 HD Request # 96 | Received 246 records from 2015-05-18 07:40:55 to 2015-05-18 09:16:00 (95.1 minutes) and wrote 246 records for USO | 2015-05-18 09:31:02 HD Request # 96 | Intraday download COMPLETE for USO. Completion time: 0s. Unique request ID: 79 | 2015-05-18 09:31:02 Removed historical data download ID 79 | 2015-05-18 09:31:02 Real-time Intraday chart data file updates started for USO | 2015-05-18 09:31:02 HD Request # 97 | Downloading Intraday chart data for FSL to the file FSL.scid. Service: equities.us | 2015-05-18 09:31:02 HD Request # 97 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-18 09:31:02 HD Request # 97 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:31:02 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:31:02 Socket (70) | Connected. | 2015-05-18 09:31:02 HD Request # 97 | Sending historical data logon request message. | 2015-05-18 09:31:02 Symbol settings received. | 2015-05-18 09:31:02 HD Request # 97 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: FSL | 2015-05-18 09:31:02 HD Request # 97 | Decompressing data. | 2015-05-18 09:31:02 HD Request # 97 | Receiving Intraday data for FSL starting at 2015-05-14 09:30:10 | 2015-05-18 09:31:02 Processed received symbol settings | 2015-05-18 09:31:02 Socket (70) | Shutdown and closed. | 2015-05-18 09:31:02 The network socket for historical data has been closed. | 2015-05-18 09:31:02 HD Request # 97 | Received 11080 records from 2015-05-14 09:30:10 to 2015-05-15 16:02:33 (30.5 hours) and wrote 0 records for FSL | 2015-05-18 09:31:02 HD Request # 97 | Intraday download COMPLETE for FSL. Completion time: 0s. Unique request ID: 80 | 2015-05-18 09:31:02 Removed historical data download ID 80 | 2015-05-18 09:31:02 Real-time Intraday chart data file updates started for FSL | 2015-05-18 09:31:02 HD Request # 98 | Downloading Intraday chart data for ES-201506-GLOBEX to the file ES-201506-GLOBEX.scid. Service: scbcd | 2015-05-18 09:31:02 HD Request # 98 | Download start Date-Time: 2015-05-17 18:08:03.0 | 2015-05-18 09:31:02 HD Request # 98 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:31:02 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:31:02 Socket (71) | Connected. | 2015-05-18 09:31:02 HD Request # 98 | Sending historical data logon request message. | 2015-05-18 09:31:02 HD Request # 98 | Error downloading historical Intraday data for ES-201506-GLOBEX. Historical data logon error: Invalid/missing data for service code: scbcd | 2015-05-18 09:31:03 * Socket (71) | Shutdown and closed. | 2015-05-18 09:31:03 The network socket for historical data has been closed. | 2015-05-18 09:31:03 HD Request # 98 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201506-GLOBEX | 2015-05-18 09:31:03 HD Request # 98 | Intraday download COMPLETE for ES-201506-GLOBEX. Completion time: 1s. Unique request ID: 81 | 2015-05-18 09:31:03 Removed historical data download ID 81 | 2015-05-18 09:31:03 Real-time Intraday chart data file updates started for ES-201506-GLOBEX | 2015-05-18 09:31:03 HD Request # 99 | Downloading Intraday chart data for NQM15 to the file NQM15.scid. Service: cme | 2015-05-18 09:31:03 HD Request # 99 | Download start Date-Time: 2015-05-17 18:02:15.0 | 2015-05-18 09:31:03 HD Request # 99 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:31:03 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:31:03 Socket (72) | Connected. | 2015-05-18 09:31:03 HD Request # 99 | Sending historical data logon request message. | 2015-05-18 09:31:03 HD Request # 99 | Requesting Intraday data. Start Date-Time: 2015-05-17 18:02:15. Record interval: 0. Symbol: NQM15 | 2015-05-18 09:31:03 HD Request # 99 | Decompressing data. | 2015-05-18 09:31:03 HD Request # 99 | Receiving Intraday data for NQM15 starting at 2015-05-17 18:02:15 | 2015-05-18 09:31:03 HD Request # 99 | Timestamp of first Intraday data file record written: 2015-05-17 18:02:33 | 2015-05-18 09:31:03 Requesting market depth updates for: $PFE if supported. | 2015-05-18 09:31:03 Requesting market depth updates for: AAPL if supported. | 2015-05-18 09:31:03 Requesting market depth updates for: CMG if supported. | 2015-05-18 09:31:03 Requesting market depth updates for: IBB if supported. | 2015-05-18 09:31:03 Requesting market depth updates for: SMH if supported. | 2015-05-18 09:31:03 Market Depth data has been rejected for symbol: AAPL. Exchange not authorized. | 2015-05-18 09:31:03 Market Depth data has been rejected for symbol: CMG. Exchange not authorized. | 2015-05-18 09:31:03 Market Depth data has been rejected for symbol: IBB. Exchange not authorized. | 2015-05-18 09:31:03 Market Depth data has been rejected for symbol: SMH. Exchange not authorized. | 2015-05-18 09:31:03 Socket (72) | Shutdown and closed. | 2015-05-18 09:31:03 The network socket for historical data has been closed. | 2015-05-18 09:31:03 HD Request # 99 | Received 15507 records from 2015-05-17 18:02:15 to 2015-05-18 09:21:03 (15.3 hours) and wrote 15505 records for NQM15 | 2015-05-18 09:31:03 HD Request # 99 | Intraday download COMPLETE for NQM15. Completion time: 0s. Unique request ID: 82 | 2015-05-18 09:31:03 Removed historical data download ID 82 | 2015-05-18 09:31:03 Real-time Intraday chart data file updates started for NQM15 | 2015-05-18 09:31:03 HTTP connection to www.sierrachart.com:80 (58) | Closed. No error. | 2015-05-18 09:31:06 HTTP connection to www.sierrachart.com:80 (58) | Shutdown and closed. | 2015-05-18 09:31:06 File >> Disconnect selected. | 2015-05-18 09:38:49 Socket (61) | Shutdown and closed. | 2015-05-18 09:38:49 SC Exchange Data | Disconnected from the server. | 2015-05-18 09:38:49 Socket (60) | Shutdown and closed. | 2015-05-18 09:38:49 SC Exchange Data | Disconnected from the server. | 2015-05-18 09:38:49 SC Exchange Data | Disconnected. | 2015-05-18 09:38:49 NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2015-05-18 09:38:52 SC Exchange Data | Connected. | 2015-05-18 09:38:52 Mapping AAPL to AAPL. Service code: equities.us | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: AAPL. ID: 1 | 2015-05-18 09:38:53 Using username 0 | 2015-05-18 09:38:53 SC Exchange Data | Connecting to the server scdf1.sierracharts.com. Port 10047 | 2015-05-18 09:38:53 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-18 09:38:53 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:38:53 HD Request # 100 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: equities.us | 2015-05-18 09:38:53 HD Request # 100 | Download start Date-Time: 2015-05-18 09:15:57.0 | 2015-05-18 09:38:53 HD Request # 100 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:38:53 Mapping CMG to CMG. Service code: equities.us | 2015-05-18 09:38:53 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: CMG. ID: 2 | 2015-05-18 09:38:53 Mapping IBB to IBB. Service code: equities.us | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: IBB. ID: 3 | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: $PFE. ID: 4 | 2015-05-18 09:38:53 SC Exchange Data | Subscribing to market data in the service client is not supported. Symbol: $PFE | 2015-05-18 09:38:53 Intraday data recording state for symbol $PFE is set to download pending. | 2015-05-18 09:38:53 Mapping UWTI to UWTI. Service code: equities.us | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: UWTI. ID: 5 | 2015-05-18 09:38:53 Intraday data recording state for symbol UWTI is set to download pending. | 2015-05-18 09:38:53 Intraday data recording state for symbol IBB is set to download pending. | 2015-05-18 09:38:53 Mapping SMH to SMH. Service code: equities.us | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: SMH. ID: 6 | 2015-05-18 09:38:53 Intraday data recording state for symbol SMH is set to download pending. | 2015-05-18 09:38:53 Mapping ESPR to ESPR. Service code: equities.us | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: ESPR. ID: 7 | 2015-05-18 09:38:53 Intraday data recording state for symbol ESPR is set to download pending. | 2015-05-18 09:38:53 Socket (73) | Connected. | 2015-05-18 09:38:53 SC Exchange Data | Connected to server. | 2015-05-18 09:38:53 SC Exchange Data | Sending logon request message. | 2015-05-18 09:38:53 Mapping PFE to PFE. Service code: equities.us | 2015-05-18 09:38:53 Socket (74) | Connected. | 2015-05-18 09:38:53 HD Request # 100 | Sending historical data logon request message. | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: PFE. ID: 8 | 2015-05-18 09:38:53 Intraday data recording state for symbol PFE is set to download pending. | 2015-05-18 09:38:53 Intraday data recording state for symbol CMG is set to download pending. | 2015-05-18 09:38:53 Mapping USO to USO. Service code: equities.us | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: USO. ID: 9 | 2015-05-18 09:38:53 Intraday data recording state for symbol USO is set to download pending. | 2015-05-18 09:38:53 Mapping FSL to FSL. Service code: equities.us | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: FSL. ID: 10 | 2015-05-18 09:38:53 Intraday data recording state for symbol FSL is set to download pending. | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: ES-201506-GLOBEX. ID: 11 | 2015-05-18 09:38:53 SC Exchange Data | Subscribing to market data in the service client is not supported. Symbol: ES-201506-GLOBEX | 2015-05-18 09:38:53 Intraday data recording state for symbol ES-201506-GLOBEX is set to download pending. | 2015-05-18 09:38:53 Mapping NQM15 to NQM15. Service code: cme | 2015-05-18 09:38:53 SC Exchange Data | Starting real-time market data updates for: NQM15. ID: 12 | 2015-05-18 09:38:53 Using username 0 | 2015-05-18 09:38:53 SC Exchange Data | Connecting to the server scdf1.sierracharts.com. Port 443 | 2015-05-18 09:38:53 Intraday data recording state for symbol NQM15 is set to download pending. | 2015-05-18 09:38:53 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:38:53 HD Request # 100 | Requesting Intraday data. Start Date-Time: 2015-05-18 09:15:57. Record interval: 0. Symbol: AAPL | 2015-05-18 09:38:53 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-05-18 09:38:53 SC Exchange Data | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-05-18 09:38:53 SC Exchange Data | Successfully connected. | 2015-05-18 09:38:53 SC Exchange Data | Restarting real-time data updates for symbol: AAPL -> AAPL | 2015-05-18 09:38:53 SC Exchange Data | Restarting real-time data updates for symbol: CMG -> CMG | 2015-05-18 09:38:53 SC Exchange Data | Restarting real-time data updates for symbol: ESPR -> ESPR | 2015-05-18 09:38:53 SC Exchange Data | Restarting real-time data updates for symbol: FSL -> FSL | 2015-05-18 09:38:53 SC Exchange Data | Restarting real-time data updates for symbol: IBB -> IBB | 2015-05-18 09:38:53 SC Exchange Data | Restarting real-time data updates for symbol: PFE -> PFE | 2015-05-18 09:38:53 SC Exchange Data | Restarting real-time data updates for symbol: SMH -> SMH | 2015-05-18 09:38:53 SC Exchange Data | Restarting real-time data updates for symbol: USO -> USO | 2015-05-18 09:38:53 SC Exchange Data | Restarting real-time data updates for symbol: UWTI -> UWTI | 2015-05-18 09:38:53 Socket (75) | Connected. | 2015-05-18 09:38:53 SC Exchange Data | Connected to server. | 2015-05-18 09:38:53 SC Exchange Data | Sending logon request message. | 2015-05-18 09:38:53 HD Request # 100 | Decompressing data. | 2015-05-18 09:38:53 HD Request # 100 | Receiving Intraday data for AAPL starting at 2015-05-18 09:15:57 | 2015-05-18 09:38:53 HD Request # 100 | Timestamp of first Intraday data file record written: 2015-05-18 09:16:22 | 2015-05-18 09:38:53 Socket (74) | Shutdown and closed. | 2015-05-18 09:38:53 The network socket for historical data has been closed. | 2015-05-18 09:38:53 HD Request # 100 | Received 37 records from 2015-05-18 09:15:57 to 2015-05-18 09:23:44 (7.8 minutes) and wrote 35 records for AAPL | 2015-05-18 09:38:53 HD Request # 100 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 83 | 2015-05-18 09:38:53 Removed historical data download ID 83 | 2015-05-18 09:38:53 Real-time Intraday chart data file updates started for AAPL | 2015-05-18 09:38:53 HD Request # 101 | Downloading Intraday chart data for $PFE to the file $PFE.scid. Service: scbcd | 2015-05-18 09:38:53 HD Request # 101 | Download start Date-Time: 2015-01-18 08:38:53.0 | 2015-05-18 09:38:53 HD Request # 101 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:38:53 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:38:53 Symbol Error - AAPL is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:38:53 Symbol Error - CMG is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:38:53 Symbol Error - ESPR is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:38:53 Symbol Error - FSL is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:38:53 Symbol Error - IBB is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:38:53 Symbol Error - PFE is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:38:53 Symbol Error - SMH is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:38:53 Symbol Error - USO is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:38:53 Symbol Error - UWTI is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:38:53 Socket (76) | Connected. | 2015-05-18 09:38:53 HD Request # 101 | Sending historical data logon request message. | 2015-05-18 09:38:53 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-05-18 09:38:53 SC Exchange Data | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-05-18 09:38:53 SC Exchange Data | Successfully connected. | 2015-05-18 09:38:53 SC Exchange Data | Restarting real-time data updates for symbol: NQM15 -> NQM15 | 2015-05-18 09:38:53 Symbol Error - NQM15 is unknown, unavailable, or improperly formatted. Exchange not authorized. | 2015-05-18 09:38:53 Socket (76) | Shutdown and closed. | 2015-05-18 09:38:53 The network socket for historical data has been closed. | 2015-05-18 09:38:53 HD Request # 101 | Error downloading historical Intraday data for $PFE. Historical data logon error: Invalid/missing data for service code: scbcd | 2015-05-18 09:38:53 * HD Request # 101 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $PFE | 2015-05-18 09:38:53 HD Request # 101 | Intraday download COMPLETE for $PFE. Completion time: 0s. Unique request ID: 84 | 2015-05-18 09:38:53 Removed historical data download ID 84 | 2015-05-18 09:38:53 Real-time Intraday chart data file updates started for $PFE | 2015-05-18 09:38:53 HD Request # 102 | Downloading Intraday chart data for UWTI to the file UWTI.scid. Service: equities.us | 2015-05-18 09:38:53 HD Request # 102 | Download start Date-Time: 2015-05-18 09:15:54.0 | 2015-05-18 09:38:53 HD Request # 102 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:38:53 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:38:53 Socket (77) | Connected. | 2015-05-18 09:38:53 HD Request # 102 | Sending historical data logon request message. | 2015-05-18 09:38:53 HD Request # 102 | Requesting Intraday data. Start Date-Time: 2015-05-18 09:15:54. Record interval: 0. Symbol: UWTI | 2015-05-18 09:38:53 HD Request # 102 | Decompressing data. | 2015-05-18 09:38:54 HD Request # 102 | Receiving Intraday data for UWTI starting at 2015-05-18 09:15:54 | 2015-05-18 09:38:54 HD Request # 102 | Timestamp of first Intraday data file record written: 2015-05-18 09:16:22 | 2015-05-18 09:38:54 Socket (77) | Shutdown and closed. | 2015-05-18 09:38:54 The network socket for historical data has been closed. | 2015-05-18 09:38:54 HD Request # 102 | Received 172 records from 2015-05-18 09:15:54 to 2015-05-18 09:23:41 (7.8 minutes) and wrote 169 records for UWTI | 2015-05-18 09:38:54 HD Request # 102 | Intraday download COMPLETE for UWTI. Completion time: 0s. Unique request ID: 85 | 2015-05-18 09:38:54 Removed historical data download ID 85 | 2015-05-18 09:38:54 Real-time Intraday chart data file updates started for UWTI | 2015-05-18 09:38:54 HD Request # 103 | Downloading Intraday chart data for IBB to the file IBB.scid. Service: equities.us | 2015-05-18 09:38:54 HD Request # 103 | Download start Date-Time: 2015-05-18 09:10:04.0 | 2015-05-18 09:38:54 HD Request # 103 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:38:54 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:38:54 Socket (78) | Connected. | 2015-05-18 09:38:54 HD Request # 103 | Sending historical data logon request message. | 2015-05-18 09:38:54 HD Request # 103 | Requesting Intraday data. Start Date-Time: 2015-05-18 09:10:04. Record interval: 0. Symbol: IBB | 2015-05-18 09:38:54 HD Request # 103 | Decompressing data. | 2015-05-18 09:38:54 HD Request # 103 | Receiving Intraday data for IBB starting at 2015-05-18 09:10:04 | 2015-05-18 09:38:54 HD Request # 103 | Timestamp of first Intraday data file record written: 2015-05-18 09:22:46 | 2015-05-18 09:38:54 Socket (78) | Shutdown and closed. | 2015-05-18 09:38:54 The network socket for historical data has been closed. | 2015-05-18 09:38:54 HD Request # 103 | Received 4 records from 2015-05-18 09:10:04 to 2015-05-18 09:23:02 (13.0 minutes) and wrote 3 records for IBB | 2015-05-18 09:38:54 HD Request # 103 | Intraday download COMPLETE for IBB. Completion time: 0s. Unique request ID: 86 | 2015-05-18 09:38:54 Removed historical data download ID 86 | 2015-05-18 09:38:54 Real-time Intraday chart data file updates started for IBB | 2015-05-18 09:38:54 HD Request # 104 | Downloading Intraday chart data for SMH to the file SMH.scid. Service: equities.us | 2015-05-18 09:38:54 HD Request # 104 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-18 09:38:54 HD Request # 104 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:38:54 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:38:54 Socket (79) | Connected. | 2015-05-18 09:38:54 HD Request # 104 | Sending historical data logon request message. | 2015-05-18 09:38:54 HD Request # 104 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: SMH | 2015-05-18 09:38:54 HD Request # 104 | Decompressing data. | 2015-05-18 09:38:54 Socket (79) | Shutdown and closed. | 2015-05-18 09:38:54 The network socket for historical data has been closed. | 2015-05-18 09:38:54 HD Request # 104 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SMH | 2015-05-18 09:38:54 HD Request # 104 | Intraday download COMPLETE for SMH. Completion time: 0s. Unique request ID: 87 | 2015-05-18 09:38:54 Removed historical data download ID 87 | 2015-05-18 09:38:54 Real-time Intraday chart data file updates started for SMH | 2015-05-18 09:38:54 HD Request # 105 | Downloading Intraday chart data for ESPR to the file ESPR.scid. Service: equities.us | 2015-05-18 09:38:54 HD Request # 105 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-18 09:38:54 HD Request # 105 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:38:54 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:38:54 Socket (80) | Connected. | 2015-05-18 09:38:54 HD Request # 105 | Sending historical data logon request message. | 2015-05-18 09:38:54 HD Request # 105 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: ESPR | 2015-05-18 09:38:54 HD Request # 105 | Decompressing data. | 2015-05-18 09:38:54 Socket (80) | Shutdown and closed. | 2015-05-18 09:38:54 The network socket for historical data has been closed. | 2015-05-18 09:38:54 HD Request # 105 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESPR | 2015-05-18 09:38:54 HD Request # 105 | Intraday download COMPLETE for ESPR. Completion time: 0s. Unique request ID: 88 | 2015-05-18 09:38:54 Removed historical data download ID 88 | 2015-05-18 09:38:54 Real-time Intraday chart data file updates started for ESPR | 2015-05-18 09:38:54 HD Request # 106 | Downloading Intraday chart data for PFE to the file PFE.scid. Service: equities.us | 2015-05-18 09:38:54 HD Request # 106 | Download start Date-Time: 2015-05-18 08:59:20.0 | 2015-05-18 09:38:54 HD Request # 106 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:38:54 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:38:54 Socket (81) | Connected. | 2015-05-18 09:38:54 HD Request # 106 | Sending historical data logon request message. | 2015-05-18 09:38:54 HD Request # 106 | Requesting Intraday data. Start Date-Time: 2015-05-18 08:59:20. Record interval: 0. Symbol: PFE | 2015-05-18 09:38:55 HD Request # 106 | Decompressing data. | 2015-05-18 09:38:55 HD Request # 106 | Receiving Intraday data for PFE starting at 2015-05-18 08:59:20 | 2015-05-18 09:38:55 HD Request # 106 | Timestamp of first Intraday data file record written: 2015-05-18 09:19:00 | 2015-05-18 09:38:55 Socket (81) | Shutdown and closed. | 2015-05-18 09:38:55 The network socket for historical data has been closed. | 2015-05-18 09:38:55 HD Request # 106 | Received 8 records from 2015-05-18 08:59:20 to 2015-05-18 09:23:20 (24.0 minutes) and wrote 7 records for PFE | 2015-05-18 09:38:55 HD Request # 106 | Intraday download COMPLETE for PFE. Completion time: 1s. Unique request ID: 89 | 2015-05-18 09:38:55 Removed historical data download ID 89 | 2015-05-18 09:38:55 Real-time Intraday chart data file updates started for PFE | 2015-05-18 09:38:55 HD Request # 107 | Downloading Intraday chart data for CMG to the file CMG.scid. Service: equities.us | 2015-05-18 09:38:55 HD Request # 107 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-18 09:38:55 HD Request # 107 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:38:55 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:38:55 Socket (82) | Connected. | 2015-05-18 09:38:55 HD Request # 107 | Sending historical data logon request message. | 2015-05-18 09:38:55 HD Request # 107 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: CMG | 2015-05-18 09:38:55 HD Request # 107 | Decompressing data. | 2015-05-18 09:38:55 Socket (82) | Shutdown and closed. | 2015-05-18 09:38:55 The network socket for historical data has been closed. | 2015-05-18 09:38:55 HD Request # 107 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CMG | 2015-05-18 09:38:55 HD Request # 107 | Intraday download COMPLETE for CMG. Completion time: 0s. Unique request ID: 90 | 2015-05-18 09:38:55 Removed historical data download ID 90 | 2015-05-18 09:38:55 Real-time Intraday chart data file updates started for CMG | 2015-05-18 09:38:55 HD Request # 108 | Downloading Intraday chart data for USO to the file USO.scid. Service: equities.us | 2015-05-18 09:38:55 HD Request # 108 | Download start Date-Time: 2015-05-18 09:16:00.0 | 2015-05-18 09:38:55 HD Request # 108 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:38:55 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:38:55 Socket (83) | Connected. | 2015-05-18 09:38:55 HD Request # 108 | Sending historical data logon request message. | 2015-05-18 09:38:55 HD Request # 108 | Requesting Intraday data. Start Date-Time: 2015-05-18 09:16:00. Record interval: 0. Symbol: USO | 2015-05-18 09:38:55 HD Request # 108 | Decompressing data. | 2015-05-18 09:38:55 HD Request # 108 | Receiving Intraday data for USO starting at 2015-05-18 09:16:00 | 2015-05-18 09:38:55 HD Request # 108 | Timestamp of first Intraday data file record written: 2015-05-18 09:16:28 | 2015-05-18 09:38:55 Socket (83) | Shutdown and closed. | 2015-05-18 09:38:55 The network socket for historical data has been closed. | 2015-05-18 09:38:55 HD Request # 108 | Received 55 records from 2015-05-18 09:16:00 to 2015-05-18 09:23:39 (7.6 minutes) and wrote 54 records for USO | 2015-05-18 09:38:55 HD Request # 108 | Intraday download COMPLETE for USO. Completion time: 0s. Unique request ID: 91 | 2015-05-18 09:38:55 Removed historical data download ID 91 | 2015-05-18 09:38:55 Real-time Intraday chart data file updates started for USO | 2015-05-18 09:38:55 HD Request # 109 | Downloading Intraday chart data for FSL to the file FSL.scid. Service: equities.us | 2015-05-18 09:38:55 HD Request # 109 | Download start Date-Time: 2015-05-15 19:59:30.0 | 2015-05-18 09:38:55 HD Request # 109 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:38:55 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:38:55 Socket (84) | Connected. | 2015-05-18 09:38:55 HD Request # 109 | Sending historical data logon request message. | 2015-05-18 09:38:55 HD Request # 109 | Requesting Intraday data. Start Date-Time: 2015-05-15 19:59:30. Record interval: 0. Symbol: FSL | 2015-05-18 09:38:55 HD Request # 109 | Decompressing data. | 2015-05-18 09:38:55 Socket (84) | Shutdown and closed. | 2015-05-18 09:38:55 The network socket for historical data has been closed. | 2015-05-18 09:38:55 HD Request # 109 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FSL | 2015-05-18 09:38:55 HD Request # 109 | Intraday download COMPLETE for FSL. Completion time: 0s. Unique request ID: 92 | 2015-05-18 09:38:55 Removed historical data download ID 92 | 2015-05-18 09:38:55 Real-time Intraday chart data file updates started for FSL | 2015-05-18 09:38:55 HD Request # 110 | Downloading Intraday chart data for ES-201506-GLOBEX to the file ES-201506-GLOBEX.scid. Service: scbcd | 2015-05-18 09:38:55 HD Request # 110 | Download start Date-Time: 2015-05-17 18:08:03.0 | 2015-05-18 09:38:55 HD Request # 110 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:38:55 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:38:55 Socket (85) | Connected. | 2015-05-18 09:38:55 HD Request # 110 | Sending historical data logon request message. | 2015-05-18 09:38:55 Socket (85) | Shutdown and closed. | 2015-05-18 09:38:56 The network socket for historical data has been closed. | 2015-05-18 09:38:56 HD Request # 110 | Error downloading historical Intraday data for ES-201506-GLOBEX. Historical data logon error: Invalid/missing data for service code: scbcd | 2015-05-18 09:38:56 * HD Request # 110 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201506-GLOBEX | 2015-05-18 09:38:56 HD Request # 110 | Intraday download COMPLETE for ES-201506-GLOBEX. Completion time: 1s. Unique request ID: 93 | 2015-05-18 09:38:56 Removed historical data download ID 93 | 2015-05-18 09:38:56 Real-time Intraday chart data file updates started for ES-201506-GLOBEX | 2015-05-18 09:38:56 HD Request # 111 | Downloading Intraday chart data for NQM15 to the file NQM15.scid. Service: cme | 2015-05-18 09:38:56 HD Request # 111 | Download start Date-Time: 2015-05-18 09:21:03.0 | 2015-05-18 09:38:56 HD Request # 111 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:38:56 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:38:56 Socket (86) | Connected. | 2015-05-18 09:38:56 HD Request # 111 | Sending historical data logon request message. | 2015-05-18 09:38:56 HD Request # 111 | Requesting Intraday data. Start Date-Time: 2015-05-18 09:21:03. Record interval: 0. Symbol: NQM15 | 2015-05-18 09:38:56 HD Request # 111 | Decompressing data. | 2015-05-18 09:38:56 HD Request # 111 | Receiving Intraday data for NQM15 starting at 2015-05-18 09:21:03 | 2015-05-18 09:38:56 HD Request # 111 | Timestamp of first Intraday data file record written: 2015-05-18 09:21:05 | 2015-05-18 09:38:56 Socket (86) | Shutdown and closed. | 2015-05-18 09:38:56 The network socket for historical data has been closed. | 2015-05-18 09:38:56 HD Request # 111 | Received 506 records from 2015-05-18 09:21:03 to 2015-05-18 09:28:55 (7.9 minutes) and wrote 504 records for NQM15 | 2015-05-18 09:38:56 HD Request # 111 | Intraday download COMPLETE for NQM15. Completion time: 0s. Unique request ID: 94 | 2015-05-18 09:38:56 Removed historical data download ID 94 | 2015-05-18 09:38:56 Real-time Intraday chart data file updates started for NQM15 | 2015-05-18 09:38:56 Requesting market depth updates for: $PFE if supported. | 2015-05-18 09:38:57 Requesting market depth updates for: AAPL if supported. | 2015-05-18 09:38:57 Requesting market depth updates for: CMG if supported. | 2015-05-18 09:38:57 Requesting market depth updates for: IBB if supported. | 2015-05-18 09:38:57 Requesting market depth updates for: SMH if supported. | 2015-05-18 09:38:57 Market Depth data has been rejected for symbol: AAPL. Exchange not authorized. | 2015-05-18 09:38:58 Market Depth data has been rejected for symbol: CMG. Exchange not authorized. | 2015-05-18 09:38:58 Market Depth data has been rejected for symbol: IBB. Exchange not authorized. | 2015-05-18 09:38:58 Market Depth data has been rejected for symbol: SMH. Exchange not authorized. | 2015-05-18 09:38:58 Current selected Data/Trading service: Interactive Brokers | 2015-05-18 09:40:04 Checking for new symbol settings for ib | 2015-05-18 09:40:04 Socket (75) | Shutdown and closed. | 2015-05-18 09:40:04 SC Exchange Data | Disconnected from the server. | 2015-05-18 09:40:04 Socket (73) | Shutdown and closed. | 2015-05-18 09:40:04 SC Exchange Data | Disconnected from the server. | 2015-05-18 09:40:04 SC Exchange Data | Disconnected. | 2015-05-18 09:40:04 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-05-18 09:40:04 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-05-18 09:40:04 Socket (87) | Connected. | 2015-05-18 09:40:04 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2015-05-18 09:40:04 Interactive Brokers | TWS server version: 76 | 2015-05-18 09:40:04 Interactive Brokers | Connected. Waiting for account information. | 2015-05-18 09:40:04 Interactive Brokers | Received Open orders end message. | 2015-05-18 09:40:04 IB Account information received. | 2015-05-18 09:40:04 Interactive Brokers | Received 5 Trade Accounts from TWS. | 2015-05-18 09:40:04 Interactive Brokers | Connected to Live account. | 2015-05-18 09:40:04 Interactive Brokers | Year-Month last connected to Live account: 2015-05 | 2015-05-18 09:40:04 Interactive Brokers | Connected to Financial Advisor account. | 2015-05-18 09:40:04 Next valid order ID: 1 | 2015-05-18 09:40:04 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2015-05-18 09:40:04 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2015-05-18 09:40:04 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2015-05-18 09:40:04 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2015-05-18 09:40:04 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2015-05-18 09:40:04 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2015-05-18 09:40:04 Next valid order ID: 1 | 2015-05-18 09:40:04 IB Account information received. | 2015-05-18 09:40:04 Interactive Brokers | Received 5 Trade Accounts from TWS. | 2015-05-18 09:40:04 Interactive Brokers | Connected to Live account. | 2015-05-18 09:40:04 Interactive Brokers | Year-Month last connected to Live account: 2015-05 | 2015-05-18 09:40:04 Interactive Brokers | Connected to Financial Advisor account. | 2015-05-18 09:40:04 Interactive Brokers | Starting real-time market data updates for: AAPL. ID: 1 | 2015-05-18 09:40:05 Interactive Brokers | Subscribing to Symbol: AAPL, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-18 09:40:05 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-18 09:40:05 HD Request # 112 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: equities.us | 2015-05-18 09:40:05 HD Request # 112 | Download start Date-Time: 2015-05-18 09:23:44.0 | 2015-05-18 09:40:05 HD Request # 112 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:40:05 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:40:05 Interactive Brokers | Starting real-time market data updates for: CMG. ID: 2 | 2015-05-18 09:40:05 Interactive Brokers | Subscribing to Symbol: CMG, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-18 09:40:05 Interactive Brokers | Starting real-time market data updates for: IBB. ID: 3 | 2015-05-18 09:40:05 Interactive Brokers | Subscribing to Symbol: IBB, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-18 09:40:05 Interactive Brokers | Starting real-time market data updates for: $PFE. ID: 4 | 2015-05-18 09:40:05 Interactive Brokers | Subscribing to Symbol: $PFE, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-18 09:40:05 Intraday data recording state for symbol $PFE is set to download pending. | 2015-05-18 09:40:05 HD Request # 113 | Downloading Intraday chart data for $PFE to the file $PFE.scid. Service: ib | 2015-05-18 09:40:05 HD Request # 113 | Download start Date-Time: 2015-01-18 08:40:05.0 | 2015-05-18 09:40:05 HD Request # 113 | Requesting a total of 120 days and 4800 seconds. | 2015-05-18 09:40:05 HD Request # 113 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 10286400. | 2015-05-18 09:40:05 HD Request # 113 | Requesting 1 Day of data at 30 secs with ending Date-Time at 2015-01-19 08:30:05 for $PFE | 2015-05-18 09:40:05 Interactive Brokers | Starting real-time market data updates for: UWTI. ID: 6 | 2015-05-18 09:40:05 Interactive Brokers | Subscribing to Symbol: UWTI, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-18 09:40:05 Intraday data recording state for symbol UWTI is set to download pending. | 2015-05-18 09:40:05 HTTP connection to www.sierrachart.com:80 (88) | Connected. | 2015-05-18 09:40:05 Intraday data recording state for symbol IBB is set to download pending. | 2015-05-18 09:40:05 Interactive Brokers | Starting real-time market data updates for: SMH. ID: 7 | 2015-05-18 09:40:05 Interactive Brokers | Subscribing to Symbol: SMH, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-18 09:40:05 Intraday data recording state for symbol SMH is set to download pending. | 2015-05-18 09:40:05 Interactive Brokers | Starting real-time market data updates for: ESPR. ID: 8 | 2015-05-18 09:40:05 Interactive Brokers | Subscribing to Symbol: ESPR, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-18 09:40:05 Socket (89) | Connected. | 2015-05-18 09:40:05 HD Request # 112 | Sending historical data logon request message. | 2015-05-18 09:40:05 Intraday data recording state for symbol ESPR is set to download pending. | 2015-05-18 09:40:05 Interactive Brokers | Starting real-time market data updates for: PFE. ID: 9 | 2015-05-18 09:40:05 Interactive Brokers | Subscribing to Symbol: PFE, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-18 09:40:05 Intraday data recording state for symbol PFE is set to download pending. | 2015-05-18 09:40:05 Intraday data recording state for symbol CMG is set to download pending. | 2015-05-18 09:40:05 Interactive Brokers | Starting real-time market data updates for: USO. ID: 10 | 2015-05-18 09:40:05 Interactive Brokers | Subscribing to Symbol: USO, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-18 09:40:05 Intraday data recording state for symbol USO is set to download pending. | 2015-05-18 09:40:05 Interactive Brokers | Starting real-time market data updates for: FSL. ID: 11 | 2015-05-18 09:40:05 Interactive Brokers | Subscribing to Symbol: FSL, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-18 09:40:05 Intraday data recording state for symbol FSL is set to download pending. | 2015-05-18 09:40:05 Mapping ES-201506-GLOBEX to ESM15. Service code: cme | 2015-05-18 09:40:05 SC Exchange Data | Starting real-time market data updates for: ESM15. ID: 12 | 2015-05-18 09:40:05 Using username 0 | 2015-05-18 09:40:05 SC Exchange Data | Connecting to the server scdf2.sierracharts.com. Port 443 | 2015-05-18 09:40:05 Intraday data recording state for symbol ES-201506-GLOBEX is set to download pending. | 2015-05-18 09:40:05 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:40:05 Interactive Brokers | Starting real-time market data updates for: NQM15. ID: 13 | 2015-05-18 09:40:05 Interactive Brokers | Subscribing to Symbol: NQM15, SecType: STK, Expiry: , Exchange: SMART, Currency: USD, Multiplier: | 2015-05-18 09:40:05 Intraday data recording state for symbol NQM15 is set to download pending. | 2015-05-18 09:40:05 HD Request # 113 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 5. | 2015-05-18 09:40:05 HD Request # 113 | Error downloading historical Intraday data for $PFE. The symbol is unknown to the server. | 2015-05-18 09:40:05 * HD Request # 112 | Requesting Intraday data. Start Date-Time: 2015-05-18 09:23:44. Record interval: 1. Symbol: AAPL | 2015-05-18 09:40:05 HD Request # 113 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $PFE | 2015-05-18 09:40:05 HD Request # 113 | Intraday download COMPLETE for $PFE. Completion time: 0s. Unique request ID: 96 | 2015-05-18 09:40:05 Removed historical data download ID 96 | 2015-05-18 09:40:05 Real-time Intraday chart data file updates started for $PFE | 2015-05-18 09:40:05 Symbol Error - $PFE is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-05-18 09:40:05 Message from IB: No historical data query found for ticker id:5. IB Error Code: 366. Request ID: 5. | 2015-05-18 09:40:05 HD Request # 114 | Downloading Intraday chart data for NQM15 to the file NQM15.scid. Service: ib | 2015-05-18 09:40:05 HD Request # 114 | Download start Date-Time: 2015-05-18 09:28:55.0 | 2015-05-18 09:40:05 HD Request # 114 | Requesting a total of 0 days and 5470 seconds. | 2015-05-18 09:40:05 HD Request # 114 | IB Backfill - Seconds requested: 5470. Seconds Remaining: 0. | 2015-05-18 09:40:05 HD Request # 114 | Requesting 5470 Seconds of data at 30 secs with ending Date-Time at 2015-05-18 10:50:05 for NQM15 | 2015-05-18 09:40:05 Symbol Error - $PFE is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-05-18 09:40:05 Socket (90) | Connected. | 2015-05-18 09:40:05 SC Exchange Data | Connected to server. | 2015-05-18 09:40:05 SC Exchange Data | Sending logon request message. | 2015-05-18 09:40:05 HD Request # 112 | Decompressing data. | 2015-05-18 09:40:05 HD Request # 112 | Receiving Intraday data for AAPL starting at 2015-05-18 09:23:44 | 2015-05-18 09:40:05 HD Request # 112 | Timestamp of first Intraday data file record written: 2015-05-18 09:24:12 | 2015-05-18 09:40:05 Socket (89) | Shutdown and closed. | 2015-05-18 09:40:05 The network socket for historical data has been closed. | 2015-05-18 09:40:05 HD Request # 112 | Received 5 records from 2015-05-18 09:23:44 to 2015-05-18 09:25:04 (80.0 seconds) and wrote 4 records for AAPL | 2015-05-18 09:40:05 HD Request # 112 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 95 | 2015-05-18 09:40:05 Removed historical data download ID 95 | 2015-05-18 09:40:05 Real-time Intraday chart data file updates started for AAPL | 2015-05-18 09:40:05 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-18 09:40:05 Symbol Error - NQM15 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-05-18 09:40:05 Symbol Error - NQM15 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2015-05-18 09:40:05 HD Request # 115 | Downloading Intraday chart data for UWTI to the file UWTI.scid. Service: equities.us | 2015-05-18 09:40:05 HD Request # 115 | Download start Date-Time: 2015-05-18 09:23:41.0 | 2015-05-18 09:40:05 HD Request # 115 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-18 09:40:05 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-18 09:40:05 Socket (91) | Connected. | 2015-05-18 09:40:05 HD Request # 115 | Sending historical data logon request message. | 2015-05-18 09:40:05 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-05-18 09:40:05 SC Exchange Data | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-05-18 09:40:05 SC Exchange Data | Successfully connected. | 2015-05-18 09:40:05 SC Exchange Data | Restarting real-time data updates for symbol: ES-201506-GLOBEX -> ESM15 | 2015-05-18 09:40:05 Requesting symbol settings for ib. Overwrite = on. | 2015-05-18 09:40:05 HD Request # 115 | Requesting Intraday data. Start Date-Time: 2015-05-18 09:23:41. Record interval: 1. Symbol: UWTI | 2015-05-18 09:40:05 HD Request # 114 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 14. | 2015-05-18 09:40:05 HD Request # 114 | Error downloading historical Intraday data for NQM15. The symbol is unknown to the server. | 2015-05-18 09:40:05 * HD Request # 114 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQM15 | 2015-05-18 09:40:05 HD Request # 114 | Intraday download COMPLETE for NQM15. Completion time: 0s. Unique request ID: 106 | 2015-05-18 09:40:05 Removed historical data download ID 106 | 2015-05-18 09:40:05 Real-time Intraday chart data file updates started for NQM15 | 2015-05-18 09:40:05 Message from IB: No historical data query found for ticker id:14. IB Error Code: 366. Request ID: 14. | 2015-05-18 09:40:05 HD Request # 116 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: ib | 2015-05-18 09:40:05 HD Request # 116 | Download start Date-Time: 2015-05-18 09:25:04.0 | 2015-05-18 09:40:05 HD Request # 116 | Requesting a total of 0 days and 5701 seconds. | 2015-05-18 09:40:05 HD Request # 116 | IB Backfill - Seconds requested: 5701. Seconds Remaining: 0. | 2015-05-18 09:40:05 HD Request # 116 | Requesting 5701 Seconds of data at 30 secs with ending Date-Time at 2015-05-18 10:50:05 for AAPL | 2015-05-18 09:40:05 HD Request # 115 | Decompressing data. | 2015-05-18 09:40:05 HD Request # 115 | Receiving Intraday data for UWTI starting at 2015-05-18 09:23:41 | 2015-05-18 09:40:05 HD Request # 115 | Timestamp of first Intraday data file record written: 2015-05-18 09:24:22 | 2015-05-18 09:40:05 Socket (91) | Shutdown and closed. | 2015-05-18 09:40:05 The network socket for historical data has been closed. | 2015-05-18 09:40:05 CMG Daily #17 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data | 2015-05-18 09:40:05 HD Request # 115 | Received 5 records from 2015-05-18 09:23:41 to 2015-05-18 09:24:48 (67.0 seconds) and wrote 4 records for UWTI | 2015-05-18 09:40:05 HD Request # 115 | Intraday download COMPLETE for UWTI. Completion time: 0s. Unique request ID: 97 | 2015-05-18 09:40:05 Removed historical data download ID 97 | 2015-05-18 09:40:05 Real-time Intraday chart data file updates started for UWTI | 2015-05-18 09:40:05 Intraday data recording state for symbol UWTI is set to download pending. | 2015-05-18 09:40:05 HD Request # 117 | Downloading Intraday chart data for IBB to the file IBB.scid. Service: equities.us | 2015-05-18 09:40:05 HD Request # 117 | Download start Date-Time: 2015-05-18 09:23:02.0 | 2015-05-18 09:40:05 HD Request # 117 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-18 09:40:05 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-18 09:40:05 HD Request # 118 | Downloading Historical Daily chart data for CMG. Starting date: 2015-05-14. Service: ib | 2015-05-18 09:40:05 HD Request # 118 | Using user Barchart Historical data account. | 2015-05-18 09:40:05 HD Request # 118 | Requesting historical Daily data for CMG starting at 2015-05-13 | 2015-05-18 09:40:05 Socket (92) | Connected. | 2015-05-18 09:40:05 HD Request # 117 | Sending historical data logon request message. | 2015-05-18 09:40:05 IBB Daily #7 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data | 2015-05-18 09:40:05 HD Request # 117 | Requesting Intraday data. Start Date-Time: 2015-05-18 09:23:02. Record interval: 1. Symbol: IBB | 2015-05-18 09:40:05 HD Request # 116 | Processing historical data message from TWS | 2015-05-18 09:40:05 HD Request # 116 | Receiving Intraday data for AAPL starting at 2015-05-18 09:15:30 | 2015-05-18 09:40:05 HD Request # 116 | Timestamp of first Intraday data file record written: 2015-05-18 09:25:30 | 2015-05-18 09:40:05 HD Request # 116 | Received 50 records and wrote 29 records from 2015-05-18 09:15:00 to 2015-05-18 09:39:30. | 2015-05-18 09:40:05 HD Request # 117 | Decompressing data. | 2015-05-18 09:40:05 HD Request # 117 | Receiving Intraday data for IBB starting at 2015-05-18 09:23:02 | 2015-05-18 09:40:05 HD Request # 117 | Timestamp of first Intraday data file record written: 2015-05-18 09:23:02 | 2015-05-18 09:40:05 Socket (92) | Shutdown and closed. | 2015-05-18 09:40:05 The network socket for historical data has been closed. | 2015-05-18 09:40:05 HD Request # 117 | Received 1 record from 2015-05-18 09:23:02 to 2015-05-18 09:23:02 (0.0 seconds) and wrote 1 record for IBB | 2015-05-18 09:40:05 HD Request # 117 | Intraday download COMPLETE for IBB. Completion time: 0s. Unique request ID: 98 | 2015-05-18 09:40:05 Removed historical data download ID 98 | 2015-05-18 09:40:05 Real-time Intraday chart data file updates started for IBB | 2015-05-18 09:40:05 Intraday data recording state for symbol IBB is set to download pending. | 2015-05-18 09:40:05 HD Request # 118 | Receiving historical Daily data for CMG starting at 2015-05-13 | 2015-05-18 09:40:05 Writing historical Daily data for CMG to the file CMG.dly | 2015-05-18 09:40:05 HD Request # 118 | Received 3 records from 2015-05-13 00:00:00 to 2015-05-15 00:00:00 (3.0 days) and wrote 2 records for CMG | 2015-05-18 09:40:05 HD Request # 118 | Daily download COMP |
| [2015-05-20 03:24:34] |
You need to update Sierra Chart to the latest version. Use Help >> Download Current Version.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-29 14:32:43
| [2015-05-29 14:22:44] |
| User69487 - Posts: 21 |
It was working and again this morning I see: Software version: 1259 | 2015-05-29 10:21:02 Uses New Spreadsheets | 2015-05-29 10:21:02 Usage end date: 2015-06-10 | 2015-05-29 10:21:02 Enabled for: Advanced Features. | 2015-05-29 10:21:02 Enabled for: Sierra Chart Historical Data Service. | 2015-05-29 10:21:02 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2015-05-29 10:21:02 Enabled for: CME, CBOT, NYMEX, COMEX exchanges for trading accounts. | 2015-05-29 10:21:02 Enabled for: BATS exchange. | 2015-05-29 10:21:02 Received 1 data feed usernames. | 2015-05-29 10:21:02 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-05-29 10:21:02 Active service: SC Exchange Data | 2015-05-29 10:21:02 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-05-29 10:21:02 2015-05-29 07:21:02 Local computer clock time | 2015-05-29 10:21:02 2015-05-29 14:21:02 GMT time | 2015-05-29 10:21:02 2015-05-29 10:21:02 Time zone adjusted time | 2015-05-29 10:21:02 Time difference to server time: 0 seconds. | 2015-05-29 10:21:02 Program path: C:\SierraChart\ | 2015-05-29 10:21:02 Data Files path: C:\SierraChart\Data\ | 2015-05-29 10:21:02 OS Version Number: 6.1 | 2015-05-29 10:21:02 Locale Information: C | 2015-05-29 10:21:02 Checking for new symbol settings for scbcd | 2015-05-29 10:21:02 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-05-29 10:21:02 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-05-29 10:21:02 Requesting symbol settings for scbcd. Overwrite = on. | 2015-05-29 10:21:03 Symbol settings received. | 2015-05-29 10:21:06 Processed received symbol settings | 2015-05-29 10:21:06 NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2015-05-29 10:21:07 SC Exchange Data | Connected. | 2015-05-29 10:21:07 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-05-29 10:21:10 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-05-29 10:21:10 |
| [2015-05-29 16:30:39] |
We need to understand what the specific problem is. If you are referring to this message: NOTICE: Not connected to Live trading account to receive CME real-time futures data. and you want to get the CME real-time futures data at the reduced exchange fees you must connect to a trading account as is explained here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-29 16:32:05] |
The specific problem is that once again I am unable to get equities (not futures) tick information from SC.
| [2015-05-29 16:41:10] |
With the Service set to the "SC Exchange Data" service you need to use the BATS symbols. For example: IBM.BZ This is documented here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#StockSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-08-15 08:04:08] |
| phaedonk - Posts: 352 |
I am probably facing the same problem. I have activated BATS, use BZ at end of symbol (AA.BZ, GOOG.BZ) but SC tries to download stock charts through IB and fails. I use SC 1284
| [2015-08-15 22:10:44] |
Restart Sierra Chart. Only open a chart for one of those symbols. After that provide us a copy of the Message Log through a new Support Request and we will look into this. This thread is closed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
