Date/Time: Tue, 17 Nov 2026 08:59:28 +0000
New User Questions Regarding Relative Volume Study
View Count: 1257
| [2015-05-15 18:39:52] |
| User463662 - Posts: 50 |
Hello, I'm new to Sierra Charts. I've been able to figure out a lot on my own, but still struggling with the following: 1. I have the code to create my own relative volume study on my chart. However, every time I try to add that file to Sierra Charts it doesn't seem to work. How do I go about creating my own study? 2. I also want to figure out how to setup and name my trades. For example, if I want an automatic stop/loss of 2 points and target of 4 points each time. How do I create this trade setup and label it? 3. How do I zoom out so I can see the rest of the chart? I know how to change time frames and how to adjust the scale, but I want to zoom out and look at multiple days using the 5 or 15 min chart instead of looking at the daily chart. Is there a zoom out button? 4. Today, the market was at the very top right hand corner of my screen. I wanted to adjust my screen and pull the market portion of the chart down to the middle of my screen b/c I couldn't view the numbers above the market or put a sell order in, in case the market went that high. When I used Tradestation, you'd get the "hand" tool out and just move the screen where you wanted it. That didn't work using the hand tool for Sierra Charts. Is there a tool for that? Thank you in advance for any and all help! |
| [2015-05-15 21:11:08] |
1. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html 2. Refer to this section here about Trade Window configurations: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations 3. Refer to: Working With Charts: Changing Bar Spacing 4. Refer to the section here for Interactive Scaling: Chart Scale and Scale Adjusting: Interactive Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
