Date/Time: Tue, 17 Nov 2026 08:59:29 +0000
Why won't Rithmic connect to Ninja Brokerage starting with version 1254 after June 1?
View Count: 3264
| [2015-05-14 03:36:42] |
| IconBob - Posts: 61 |
From the version 1254 notes: Effective with this version, there is no longer support to connect to Ninja Trader Brokerage using Rithmic on or after June 1, 2015. Why? Does this mean I can't connect or SC isn't supporting the connection. I checked with Ninja Brokerage and they said "This decision was not made or influenced by NinjaTrader Brokerage." Is it a Rithmic or SC support issue? I'm using a SC Rithmic connection with TopStep trader will this be affected? The reason I raise the issue is because I'm paying for the Rithmic connection with my brokerage and using your excellent data feed. If I can't connect through Rithmic I will have to pay additionally for a CQG/Continuum to connect SC to Ninja Brokerage. Date Time Of Last Edit: 2015-05-14 03:42:02
| [2015-05-14 18:29:49] |
Ninja Trader has always been a software vendor providing there software to traders. Recently ninja trader has decided to become a brokerage, following that, they have discontinued the service to many brokerages who have supported their service for years, and further have asked many to remove them from their site. We strongly feel that this does not coincide with our policies, core values and/or they way one should conduct themselves. We would like to support those who have supported us, and also list us on their site as an offered platform. Please consider brokers like Optimus Futures, Infinity, AMP and/or others who have shown the willingness to help us. Please remember that we are a development company, and we need to support those who help us while our policies at Sierra do not present a conflict of interest to them. Your Rithmic connection to Top Step Trader will not be affected. Please let us know if you would like a refund after the month of May 2015. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-15 20:57:57] |
| User80386 - Posts: 9 |
IconBob, you must payed $20/m. fot "RITHMIC API + FEE" in Ninja Trader Brokerage if you connect with Sierra Chart. For the CQG/Continuum to connect with Sierra Chart - the fee is the same. |
| [2015-05-15 21:01:21] |
What we are going to do is extend the date until July 1 so as to give you time to make any necessary arrangements. You can also use any version before 1254 and be able to connect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
