Date/Time: Wed, 25 Nov 2026 21:45:56 +0000
[Programming Help] - ACSIL - Use Attached Orders
View Count: 1989
| [2015-05-04 22:53:14] |
| eagle - Posts: 92 |
Using ACSIL, how can I detect the status of the Use Attached Orders check box on the Trade Window?
| [2015-05-05 03:45:18] |
This is not possible to do.
| [2024-11-26 13:56:57] |
| User642165 - Posts: 2 |
has this been implemented?
| [2024-12-01 05:30:48] |
| Sierra_Chart Engineering - Posts: 25483 |
No but we could add this.
| [2024-12-01 11:44:36] |
That would be great, thanks
| [2025-05-16 16:20:33] |
| User438120 - Posts: 19 |
Is there a way to enable/disable the "Use Attached Orders" checkbox in the Trade Window with ACSIL?
| [2025-05-16 16:32:45] |
There is no support for specifically setting the "Use Attached Orders" option. But refer to the following that you may find helpful: ACSIL Interface Members - Variables and Arrays: sc.SupportAttachedOrdersForTrading ACSIL Interface Members - Variables and Arrays: sc.UseGUIAttachedOrderSetting For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
