Date/Time: Wed, 25 Nov 2026 23:19:58 +0000
Old position data shown in Chart (opening line and PnL)
View Count: 1216
[2015-04-27 16:39:45]
User77270 - Posts: 23
Dear support team,
My SC doesn't show the correct entry level for a trade in DAX (CFD with IB) on the chart, however it shows the correct data in "positions and orders tab".
Instead it uses the entry data of an old trade which I entered two weeks ago, but is long closed already.
I sometimes open orders not on SC, but also on mobile TWS.
I tried everything already that is described in http://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#IncorrectlyReportedTradePosition
What can I do that the chart (attached chart trader and opening line) shows the correct entry position?
Thank you
SC shows incorrect data of
imageposition.jpg / V - Attached On 2015-04-27 16:39:35 UTC - Size: 508.92 KB - 580 views
[2015-04-27 17:05:13]
You need to clear the Trade Activity Data for that symbol following the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ClearingtheLog
You should do this when the position is flat, but it is not necessary.
