Date/Time: Wed, 25 Nov 2026 14:42:18 +0000
Undo Button
View Count: 4650
| [2015-04-15 15:39:03] |
| User46129 - Posts: 36 |
To be able to undo deletion or movement of a drawing tool (line, rectangle, etc) would be a nice addition. Also would be nice to be able to merge profiles by dragging. Thanks,
| [2015-04-15 17:30:54] |
Undo for Chart Drawings is supported. Refer to the documentation here: Chart Drawing Tools: Undoing and Redoing Chart Drawing Operations There is little chance we would add the ability to merge TPO Profiles by tracking. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-15 17:31:17
