Date/Time: Wed, 04 Nov 2026 10:45:18 +0000
Higher frequency alert
View Count: 1457
| [2015-03-31 16:30:11] |
| dimeetrees - Posts: 27 |
I noticed there is a pause between my sound alerts on the consolidate time and sales filter. Is there any way to make no delay between alert sounds? I want multiple alerts at a higher frequency to reflect the tape, it would help me trade better with sounds.
| [2015-03-31 16:44:29] |
I'm testing it out now and the alerts really don't go off every time they are supposed to.
| [2015-03-31 17:48:59] |
Try disabling Global Settings >> General Settings >> Alerts >>Wait for Prior Alert Sound to Finish Before Playing Next Queued Sound.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-31 17:49:15
| [2015-03-31 17:54:50] |
It is already disabled.
| [2015-03-31 18:05:09] |
Therefore we cannot provide any further help with this then. It is out of our control.
| [2015-04-01 20:04:33] |
Ok I figured out the problem and I believe you can help. The "Highlight & Alert" function in Time & Sales does not read combined record output when they are selected, it continues reading unfiltered T&S. Is there any way to correct this? If you can not help, can I create a custom study for this?
