Date/Time: Sun, 11 Oct 2026 09:58:20 +0000
Many commands in Trading Keyboard Shortcuts are not working
View Count: 10591
[2015-03-30 20:09:54]
User78286 - Posts: 15
I am using SC Version 1242
I am programming Trading Keyboard Shortcuts for keyboard trading, I have "Trading Keyboard Shortcuts Enabled" checked on my Trade DOM.
I am able to use shortcuts for the following commands:
- buy/sell market
- buy the bid
- sell the ask
- flatten
The following commands shortcuts are not working, I used different combinations of ALT, CTL, SHFT, with numbers, letters, F-keys, numpad-keys, but all have failed to work:
- reverse
- cancel
- moving the stop *)
- moving the target *)
- order quantity buttons
- use attached orders
- buy/sell bid/ask +/- n tick
see attached image for an example of shortcut for "Buy Bid -1 Tick", which does not work. When I said they don't work, I mean when I pressed the shortcut keys programmed for these commands, with the DOM window receiving the active focus, nothing happened.
I understand that some commands would only work when there are trade positions on the DOM, for example, "move target up 1 tick" requires that there is at least one long or short position on the DOM and there is one target order on the DOM, I have tested these commands under such appropriate conditions, those listed above as not working are all not working.
Please help!
Date Time Of Last Edit: 2015-03-30 20:16:48
imageSNAG-3-30-2015 4.07.26 PM.jpg / V - Attached On 2015-03-30 20:08:26 UTC - Size: 102.63 KB - 2276 views
[2015-03-30 22:57:05]
You need to go to the chart or Trade DOM and enable Trade >>Trading Keyboard Shortcuts Enabled. This option is specific to each individual Trade DOM and chart.
Date Time Of Last Edit: 2015-03-30 23:57:03
[2015-03-30 23:12:05]
I did that, as stated in the second sentence on my original post above. That was not the cause.
After numerous hours of trial and error, I finally discovered some combinations that worked.
The problem is:
SC has reserved many combinations of keys for internal use, which cannot be used for custom shortcuts.
SC didn't provide a list of these combinations, they can be CTL+SHFT+letters, ALT+SHFT+numbers, ALT+F-keys, and many others, so that leaves us with a very time consuming task to test out numerous combinations that don't work and find those that work, this is very frustrating!
On top of that, there are combinations that are not used by SC, that also can not be used for custom shortcuts, and SC never provide a guideline what combination patterns should be avoid, we were forced to perform hours of trial and error until we rule out the combinations that don't work and discover those that work.
I wasted the entire day today, plus 3 hours overtime, just to finally figured out some of the combinations that worked.
I search the support forum, it had been requested by members for SC to provide a list of combinations of keys that had been used by SC defaults, but SC's response was to see the manual for such list, but I was not able find such list in the manual or and SC documentation.
It would be nice if SC can provide a list of default shortcuts that have been reserved and cannot be used for custom shortcuts (unless the user clears the default shortcuts, which is not a desired solution because we do want to use some of the default shortcuts). I don't think that is too much to ask for.
Date Time Of Last Edit: 2015-03-30 23:18:34
[2015-03-31 00:03:32]
Yes, we do see this after looking at your post again. It was very long. And nevertheless, that was the only reasonable conclusion as to the problem and we wanted to make sure it was enabled for the specific Trade DOM.
In regards to your other comments, all of what you are describing is going to be operating system related and we would have no way to know this. This is the first time we are hearing of this.
Sierra Chart does not reserve any particular keys or shortcuts for other uses. They are all defined in Global Settings >> Customize Keyboard Shortcuts.
How are we to know this?. First we have heard of this. We do know that there can be problems when using the Alt key because some uses of that is reserved by the operating system but it does not necessarily mean there would be a problem using it within an application.
If the intent of this comment is to be critical of us, this is most definitely not fair to us at all. Not in any way.
You must be looking at a very old and not relevant post.
There are none. If there is a conflict you immediately see it in the "Key Currently Used By" box when you configure that keyboard shortcut.
Date Time Of Last Edit: 2015-03-31 00:06:25
[2015-03-31 00:20:46]
Also we tried the keyboard shortcut you posted in the image and it worked for us.
[2015-03-31 00:58:45]
It was much later, after I had spent almost 10 hours trying out countless combinations of keys to find out which ones work and which one don't, I finally found this list of SC Default Shortcuts that, can not be used as custom shortcuts.
Unfortunately, I attached a wrong image, I meant to attached the image that show the "CTL+ALT+SHFT+A (and all letters A-Z)" combination do not work, but ""CTL+ALT+SHFT+8 (and all number 0-9)" do work, but unless we test each combination out individually, there is no way of knowing which ones work and which ones don't work, I showed that as example, because I had to test many more other combinations to find enough working combinations for all the commands I need shortcuts for.
This is a partial list of shortcuts used by SC that can not be used as custom shortcuts:
Misc/Windows
Alt-F4 Close Window/App
Ctrl-F4 Close Chart
Ctrl-F6 Next Chart
File Menu
Ctrl-H New/Open Historical Chart
Ctrl-I New/Open Intraday Chart
Ctrl-B Open Chartbook
Ctrl-S Save (chartbook)
Ctrl-A Save All (chartbooks)
F11 Connect to Data Feed
Ctrl-F11 Disconnect (from data feed)
Ctrl-P Print
Edit Menu
Ctrl-C Copy
Ctrl-X Cut
Ctrl-V Paste
Alt-Shift-C Copy Chart Values
Ctrl-Alt-Z Undo Erased Chart Drawing
Ctrl-D Clear Contents From Selection
Alt-R Reload All Charts
Screen Images Sub-Menu
Alt-Shift-8 Upload Chart
Alt-Shift-9 Upload Chart with Overlays
Alt-Shift-0 Upload Desktop
Chart Menu
F5 Chart Settings
Ctrl-G Use Evening/Full Session
Alt-Shirt-H Horizontal Grid
Alt-Shift-V Vertical Grid
Insert Reload and Recalculate
Ctrl-E Set Charts To Same Symbol
Ctrl-R Replay Chart
+ Next File
- Previous File
Ctrl-8 Daily
Ctrl-9 Weekly
Ctrl-0 Monthly
Shift-Left Arrow Page Scroll Left
Shift-Right Arrow Page Scroll Right
Down Arrow Decrease Spacing
Up Arrow Increase Spacing
Page Down Large Decrease Spacing
Page Up Large Increase Pacing
Home Goto Beginning of Chart
End Goto End of Chart
Ctrl-Alt-G Goto Date/Time
Ctrl-Alt-D Detach/Attach Chart Window
Alt-Shift-R Reset Scale
Ctrl-End Scroll All Charts To End
Analysis Menu
F6 Studies
Tools Menu
Alt-1 Pointer
Alt-3 Chart Values/Crosshair
Alt-0 Adjust Regions
Alt-H Hand
Alt-Z Zoom
Alt-4 Trendline
Alt-6 Extending Trendline
Alt-2 Chart Calculator
Alt-8 Horizontal Line
Ctrl-4 Vertical Line
Ctrl-Y Type Text
Ctrl-J Stationary Text
Alt-7 Fib 2 Point Retrace/Extention
Alt-Shift-7 Fib 2 Point Retrace/Extention 2
Ctrl-Alt-P Fib 3 Point Retrace/Extention
Alt-Shift-4 Fib 3 Point Retrace/Extention 2
Ctrl-F Gann Fan
Ctrl-Shift-F Fibonacci Fan
Ctrl-N Linear Regression
Ctrl-7 Arrow
Ctrl-Alt-V Cycle
Ctrl-Alt-1 Fibonacci Time Zones
Ctrl-Alt-2 Zig-Zag
Ctrl-Alt-3 Gann Grid
Ctrl-6 Pitchfork Tool
Alt-Shift-6 Pitchfork - Schiff Median
Alt-Shift-5 Pitchfork - Modified Schiff
Ctrl-Alt-4 Rectangle Highlight
Ctrl-Alt-T Extending Rectangle Highlight
Ctrl-Alt-5 Ellipse Highlight
Ctrl-Alt-6 Angle Ellipse Highlight
Ctrl-Alt-7 Tool Settings
Ctrl-T Active Tool Color
Ctrl-Alt-8 Chart Drawing Properties
Alt-M Move Line/Text
Ctrl-5 Adjust Line
Ctrl-Alt-9 Extend Trendline
Alt-P Make Line Parallel
Alt-S Snap To High/Low
Ctrl-Alt-S Snap Side to High/Low
Ctrl-Alt-C Snap to Close
Ctrl-Alt-O Snap to Open
Ctrl-L Copy and Move Line/Text
Alt-Shift-1 Copy and Adjust Line
Alt-Shift-2 Alerts
Alt-Shift-3 Modify Text
Alt-5 Erase Lines/Text Mode
Ctrl-Delete Erase Last Line/Text
Delete Erase Single Line/Text
Alt-Shift-T Erase All Text
Alt-Shift-L Erase All Lines
Ctrl-3 Global Cursor On
Worksheet Menu
Ctrl-1 Fix Column
Ctrl-Alt-I Open Intraday Chart
Ctrl-Alt-H Open Historical Chart
Ctrl-2 Sort
Ctrl-C Copy
Ctrl-X Cut
Ctrl-V Paste
Trade menu
Ctrl-Shift-T Open Trade Window for Chart
Ctrl-Shift-C Chart Trade Mode On
Ctrl-Shift-D Trading Chart DOM On
Ctrl-Shift-O Show Filled Orders
Ctrl-Shift-R Trade Orders Window
Ctrl-Shift-P Trade Positions Window
Ctrl-Shift-A Trade Activity Log
Ctrl-Shift-L Trade Service Log
Ctrl-Shift-G Global Trade Settings
Global Settings Menu
Ctrl-Alt-Q Clear Alert Sound Queue
Window Menu
Ctrl-Alt-X Maximize
Ctrl-Alt-R Restore
F4 Previous Chart
F9 Next Chart
F7 Previous Chartbook
F8 Next Chartbook
Ctrl-M Show/Hide Message Log
Ctrl-Alt-A Show/Hide Alert Log
F3 Chart Values Window
Alt-V Tool Values Window
Ctrl-W Windows and Chartbooks
Help Menu
F1 Table of Contents
[2015-03-31 01:16:33]
That was not the intent, the intent was to help SC to become a better company by providing some better information for this subject, so that other users don't had to go through the same that I had gone through.
No company is perfect, by better helping customers, companies also get better in the process, and customers become happier customers, it's a win-win situation.
[2015-03-31 02:45:06]
OK understood, but there is no additional information that can be provided and after this support request there still is no additional information that can be provided. Our only conclusion is you are running into some system specific issue relating to keyboard shortcuts.
[2015-03-31 04:24:38]
Thank you for your help. My system is a very typical high end Intel I7 CPU with Windows 7 64 bit OS, so I I would think my "system Specific issues" must be common to other power users.
I do have one additional SC trading shortcut command issue: the Target Oder Tick-up command:
When I have 2 working targets, the "Target Order Tick Up" command only moves one target order but not both, it moves the second target specifically, is this by design? is it possible to move multiple targets up or down simultaneously? with that shortcut? or move the target that is closest to the current price and not the target that is farthest? (it would make much more sense to move the closest target first, because that is the one that would be hit first before the targets farther away get hit, so they can wait, as of now, the closes target cannot be moved by keyboard shortcuts, only the targets that are farther away get moved with the shortcuts)
Thank you again for you help!
Date Time Of Last Edit: 2015-03-31 04:36:08
[2015-03-31 08:00:54]
All we can say in regards to the keyboard shortcut issue is we could not duplicate the problem. And the conversion of a keyboard shortcut to a command is handled at the operating system level.
We did a test and we modified a target order by keyboard and it was the one nearest the current price.
We gave this some thought and we realized with the problem is in your case. It has to do with using a TT FIX Adapter and that the raw prices have larger values. An adjustment has to made to the prices to make this work correctly. This will be out in the next release.
[2015-03-31 12:54:07]
Thank you very much for addressing the issue and the resolution!
I am glad that you have identified the cause for the issue and I look forward to the next release.
Thank you so much again for helping me!
